Question about Brother Office Equipment & Supplies
Can not print from pc - Brother Office Equipment & Supplies
    Master:
  • 848 Answers
You might have not installed the drivers properly for printer ...so better reinstall the driver files
Posted on Jun 20, 2008
    Genius:
  • 3,422 Answers
Can you please describe your problem
  • Priya darshan Jun 20, 2008
    Please try unplugging all the cords for 30min and then plug them back in and see if you can print now or else please try reinstalling the drivers.
    If you need anymore help let me know.
Got my HP laser jet P1005 plugged into 1 PC prints fine. But 2nd PC is networked to it and it takes ages to print! How can I speed up send PC print job? Both PCs Only ever print single pages.
Well, that really depends upon how you are "networked". Obviously, the primary PC is USB 2.0 connected direct to the printer. When you send a print job, the PC merely starts the print job and sends it to the printer on the fly. The other PC must first spool the entire job, packet it up, send it to the network, then network sends it to the first PC, where it must unpacket it, and send it to the printer. This is definitely going to be slower than a direct connection. And if your network connections are wireless rather than wired, even longer.
Feb 19, 2016 | HP Office Equipment & Supplies
Printer will print a document but when it reaches halfway it stops printing. Only way to finish printing the document is to restart my pc. Why does this happen? Can this problem be resolved?
When you restart your PC does the printing continue from where it had abruptly stopped printing or does the printer print a fresh copy .
In any case the clean the Print Cartridge Carry Assembly Mount Rod and try freeing up more space on your PC hard Disk for spooling the print data
Jun 28, 2015 | Lexmark X2650 All-In-One InkJet Printer
When printing from the PC my PC says "the print spooler service is not running"the PC i'm using was communicating with the admin PC. is it possible for me to connect to the printer trough the offi
When you try to install a printer and get an error message "Print Spooler is not running" then Print Spooler need to be configured. Open Print Spooler as detailed above and click on the General tab then select these items - Startup type select Automatic Service status click Start Then click OK
You can also try this WEB site
MICROSOFT PRINT SPOOLER FIXES
http://support.microsoft.com/kb/934885
Apr 02, 2013 | Office Equipment & Supplies
How can print with toshiba 230? from pc!!
it very easy. connect the printer to the pc with a usb cable, ensure that u have the driver of the printer that will be install on the pc. put the printing paper to the print and send print from your pc.
Feb 06, 2011 | Toshiba Estudio 200L Copier
Toshiba Estudio166 networking issue
Toshiba es166 is local USB printer. You can print from designated PC and you have to share printer if you want to print from other printer in your network. Because of low machine memory (16Mb) it could be some conflicts,if you use more than 2 PC in network. That is why Toshiba has es167 model on which you can add network print controller. You can also use USB hub if you want to print from more PC's. (only 2 brands of USB hubs provide this, see toshiba site)
Sep 17, 2009 | Toshiba e-STUDIO166 Printer
Will not print with black at pc connected to, but will remote
it only shows that your printer is working,the problem is in you pc,reinstall the printer driver where it doenst print correctly then reinstall it.
Sep 08, 2009 | Canon BubbleJet i560 InkJet Printer
Printing blank pages
Hey,
Try installing the toner/pc drum once more, then print something and when printing open first cover and take out pc drum, look the pc drum, if the pc drum is clean, then the laser wount reach it. laser is located above the pc drum. when you close front cover then there is a little swich in right side what opens laser cover, try to makse sure that it works.
if there is a print marks in pc drum, hten the problem is in transfer rollerits located behind the pcdrum.
Oct 05, 2008 | Konica Minolta PagePro 1350W Laser Printer
Printing from pc
Perhaps you are giving the Print command from Print icon on your Standard toolbar and your document is too big. Try print from the file>Print and select print current page. If the problem persists, reinstall the printer driver after uninstalling it.
Feb 06, 2008 | Office Equipment & Supplies
Printer gets stuck with a "Printing ..." or "PC Print ..." message on the LCD display
I have the same problem with mine. Another option is to "Log Off Administrator" at the PC or "Restart" the PC and prior to shutting down it seems to pfrint all my jobs ... better than cancelling.
Jan 26, 2007 | Samsung SCX 4521F All-In-One Laser Printer
16 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
