Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
Currently have 5 computers (3 Apple's and 2 PC's) and everything works fine. Bought a new MacBook, and could not get the wireless to work. Apple tells me for better security they only accept WPA wireless now, and I need to change from WEP. How do I do this? Model is Belkin Version 2000 Model F5D6231-4
    Problem Solver:
  • 11 Answers
Type to get into settings default password is blank
Posted on Dec 24, 2008
  • 85 Answers
Ok, access your routers web management page.
From the menu on the left, select Wireless, then Encryption.
You should be able to change the settings there.
As im sure your aware, you will have to reconfigure the other 5 clients to use WPA after doing this. I would recommend having a least on client connected by ethernet to the router so that if changes make the wireless inaccessable, you can still access the routers configuration.
Posted on Jun 20, 2008
Wont allow me to connect 2 additional computers and need pin name or number
Two methods to solve your problem:
Method 1:
(1) Using your currently connected and working computers, access the wireless router security page at (page 8 of 44 from the WRT54G2 manual), default password "admin" (page 7 of 44 from the WRT54G2 manual)
PDF file of the Linksys/Cisco Wireless-G Broadband Router User Guide:
You'll need Adobe Acrobat Reader to view/print this file - free from
(2) get the WEP or WPA password, and enter it into the wireless LAN (WLAN) settings on your 2 additional computers.
Method 2:
Alternatively, access the WEP or WPA key on one of your working PC, by
(1) make sure the printer is working, powered up and online.
(2) invoke "Network Setup Wizard"
(3) wind thru various steps (click-ing NEXT), then select "Print Network Settings"
(4) use the printed WEP or WPA key in the WLAN settings on your additional 2 PCs.
Jan 02, 2011 | Linksys WRT54G2 Wireless Router
Need a network password so i can get internt on my
If you are trying to access the page via wireless connection then I'm afraid it won't work.
You need to be connected to the router before you can access the routers set-up page.
You have 2 options.
1. Connect your macbook to the router with a ethernet cable then access page or
2. On the back of the router is a small hole. (Reset Button) Using a needle or paper-clip press this button for about 10 seconds then release. This will reset the router to factory default settings and usually (Although not guaranteeing this as can be configured differently depending on where the router came from) mean that wireless is "OPEN" in other words no wep/wpa required.
Then you can access the page and set things up with passwords etc you can remember.
Also underneath the router should be the default wep key "IF" the wireless is passcode enabled.
And despite using 2 different netgear routers and updating the firmware. I have to now tell you.
They constantly locked up and dropped my broadband connection so bad I purchased different equipment.
Just FYI if you get connection issues.
Jul 17, 2010 | NetGear DG834G Router
I have a D-Link DIR 615 wireless router i am trying to connect my daughters DS to the wifi but it keeps asking me for a WEP KEY???? i dont know the wep key i put the serial number in and the password but...
When you will make WEP key then you have to put this key on your pc first for connect to internet. It is very easy steps & your network will make secure.
First check your network option also.
Right click on your network then you see the property then go to security See dropdown menu If you have wep key then follow these steps if you did not see thi.
WPA is same as WEP
You need to sign in your router first. a web-browser such as Internet Explorer and enter the IP address of the router (
2. Select "Admin" from the drop-down menu and then enter your password. Leave the password blank by default.
Now you can see your D-LINK webpage where you find your wep key.
Clik setup then wireless setting
Now you see on this page
1. Wireless Security mode then drop-down-menu Set Enable WEP
2. Authentication - Choose Shared Key.
3. WEP Encryption - 64 Bit.
4. Key Type - HEX
5. Default WEP Key - WEP Key 1
6. Now Make a key( You can choose any password but remember only 10 charcters allowed)
7. Now Save setting. then your router gonna boot up make sure let it boot. It connected after 5 minute.
You should write your password in paper first then you will have to add this key into your pc. network.
You can not connect internet because you have to put these Key(password) into your pc first.
Go to your network connection in your pc Choose your network
You see two computer( internet icon) on the desktop
Right click then connect to network then you see so many network & your network ( Which you create).
Right click on your network then you see the property then go to security choose wep key then put the password(KEY).
1. Wireless Security mode then drop-down-menu - EnableWPA
2. Clipher type -TKIP
3. Passpharse - create own password here( don't put any personal info there)
Save setting
Device restart.
Now check Network status. Its working now.
Follow youtube video
Jun 10, 2010 | Computers & Internet
Apple Macbook Pro does not connect to wireless network
The antennas in the Macbook Pros have had an issue with reception due to the aluminum housing of the laptop but, should still receive decent reception just not as much as a plastic Macbook or plastic PC laptop. It could be possible that the antenna's cables have become disconnected from the Airport Extreme card inside your Macbook Pro, that the card itself is faulty or damaged or that the Antennas themselves have been damaged in some way. As always make sure you have the latest updates and have installed any driver updates from Apple regarding your Airport Extreme card. Here's an article that may help eliminate any wireless interference that may be affecting your signal strength. Apple - Wireless Interference hope this helps, if so don't forget to comment, vote, etc. Thank you.
May 28, 2010 | Apple MacBook Mac Notebook
Can not connect to the internet with my new itouch. Have tried all the resets. My password (which is correct) does not seem to work. Says unable to join network. The network is working fine with 2 other...
What kind of wireless password do you have? WEP or WPA? This makes a difference as Apple devices use a different algorithm with the WEP encryption that the rest of the world. If WEP, put a '#' in front and use the hexadecimal version of the password.
-=/ MLF /=-
Oct 20, 2009 | Apple iPod touch
Macbook 13.3" won't log in to wireless
You need to check your network card software your problem may lay there. I've seen this problem many times in the passed. I will install a wireless network card or software on someones computer and two days later it will not connect everything looks fine. No matter what I do it will not connect. Remove net software for the card or on board wireless reinstall and boom it works fine.
routers may need reset or configured off the internet or the start up cd. I take this a wireless router hooked to internet gateway. don't know not enough information you may need to tell me a little more. first try install of net-card software then set you working router to unsecure no pass word need see if you connect then change it to you wpa password protected.
Mar 20, 2009 | Apple aluminum 13-inch MacBook laptop-...
Macbook loses wireless internet connection
Hi 8233 is a good choice for a router
Here's your solution
1. These steps are to be performed strictly from a computer which is wired.
2.Even if you are using your mac book turn of the airport and connect it via a cable.
3. Open your router setup page by typing in on your browser tab or typing i in the run window
4.An rsp will open and on the top right hand corner of the screen it will say Internet status:: connected
5.On the left hand side change you"ll see channell under wireless
6. Select it and change it to 6 or 11 for best signal strength
7.Now to the most important segment 8233 has a piculiar issue with its extra strong security
8.On the left hand side under wireless you"ll will see an option called wi-fi protected setup
9.Select it and turn it off reboot router and wow the problem should definately be resolved .
Then turn on airport and go wireless along with your wife.
10. You will still be secure with your data through security option on your router (wep or wpa )whatever you use .
Thank you and just let me know if it worked or not
Feb 26, 2009 | Belkin (F5D72304F5D7000) Router
Need to Change WEP Data Encrytion to WPA in Wireless Network Connection Properties
Hiya, first thing you should check is that your wireless card/usb on your laptop actually supports WPA. I changed to WPA and 3 out of 5 of my laptops could not log on. Took me an age to find out what was wrong. Try changing back to WEP on both units. If they can both log on then see if you can try to borrow a wireless card that you know supports WPA, change back to WPA settings and see if new card works. Don't even assume that new cards/usb's are all WPA compatible. Friends was bought in Nov and isn't able to run WPA.
Apr 22, 2008 | Gateway 4026GZ Notebook
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
115 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
