Question about Dryers
2 1/2 year old Kenmore stackable front load dryer. Just started a loud, grinding, whining when dryer was turned on. This is not a problem in Sears "Avoid Service Checklist". Any thoughts or ideas? Many thanks
  • mrspenny Jun 24, 2008
    Will respond again when my husband starts to take it apart! He appreciated possible problems/solutions. Many thanks.
  • 525 Answers
I attempted to locate an answer to resolve the issue for you, but you have not provided me with enough information to access my service database. Please observe the TIP below, and post me back and I will be happy to assist you further. Should you require more extensive consultation to help resolve your complaint(s), you may contact me through our premium chat service.
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint.
Below is a link that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
http://www.repairclinic.com/0088_8_1.asp#Level1_7
If your dryer is noisy, check these:
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time.
Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it.
Glides Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them.
Rear drum bearing Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn.
Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 21, 2008
Sears stackable one peice unit. washer top load on bottom and dryer front load on top. The proble is when the washer is in the spin cycle it make a teriable load noise. Like it is grinding becase of a...
Your brearings are possibly worn, when the machine is off open the door and grab a hold of the drum (metal part on the inside) lift this drum if your bearings are worn it will have some play within its housing, i.e. it will move before the inner tub does and mannually rotate it you should here the bearings rumble if so also. they wear over time. you may be able to get them replaced but check prices first as it may be cheaper to get a new one bearing changes can be labour intensive.
Sep 07, 2009 | Kenmore 98702 Stacked Washer/Dryer
Squeaky Kenmore Dryer
The idler rollera and belt tensioner have got bearings. One of them is failing.
Jul 07, 2009 | Dryers
It takes at least 2 60 minute cycles to dry clothes. Not even 2 years old yet. Not a new problem has always been this way. What is the deal.
Check the blower fan which is mounted underneath the drum on my DLE2514W front loading LG dryer. I experienced poor drying along with a loud thump at the start of each cycle. At first I thought it was a bad roller but later found that the blower fan had separated from its bracket so it was not turning with each turn of the moter but rather spinning freely.
Apr 14, 2009 | LG DLE3777 Electric Dryer
Front loading dryer making a'sandy, grinding' sort of sound
possible problem has a dent on top of panel and is grinding on drum and top panel ,, do not put anything on top of dryers ,,,
Nov 08, 2008 | Kenmore Elite HE4 Electric Dryer
Owners Manual for Sears Kenmore Stackable Washer/Dryer
how do you seperate the stackables for moving
Oct 13, 2008 | Washing Machines
Washer and dryer
go to sears and get the stack kit the directions are in the kit
Apr 25, 2008 | Washing Machines
Purchasing a stackable dryer that fits on Kenmore/Frigidaire 417.44102300 washer
there still models out there from sears that go on the same way as the old one trust me i know 4 a fact
Mar 05, 2008 | Frigidaire ATF6000ES Front Load Washer
Dryer making very loud noise.
We had the exact same noise all of a sudden start coming from our 2 year old dryer. We checked everything, rollers, pulleys, motors, etc. I was certain it was coming from the upper left. Finally we found a loose screw had fallen into the front felt ring. Problem solved!
Good luck.
Jan 20, 2008 | Kenmore 63942 Dryer
THIS COULD BE THE MOTOR IF IT IS UNDER WARRANTY LET THEM PAY FOR THE REPAIRS
Dec 27, 2007 | Kenmore 98702 Stacked Washer/Dryer
Dryers Logo
82 people viewed this question
Top Dryers Experts
