Question about Gateway 450ROG Notebook
Coolonh=g Assembly First my Gateway 450ROG would freeze up I sent it to be checked by an I.T person, I was told it was the because the computer was over heating so I replaced the cooling assembly. I download the laptop monitor and it say that the fan on the cooling assembly is not working so I put the old one back in it does not work either. Would this mean that the problem is still the cooling system or the motherboard, as you do hear the swarlling of the fan when you turn on the laptop.
  • Susan Kennedy Jun 21, 2008
    Hi
    Do you have a business address and what are your rates
    The guy I sent it to before said what was wrong but could not fix it.
  • Marieelena Mathena Nov 22, 2008
    screen loads very slow, then flickers, and can not open any other screens cause then it will freeze and take forever to ctrl, alt, del. I tried removing running task bar programs and deleted all neccessary file history, etc. removed used desktop items, removed all non-used programs. Still does it and doesn't let the cursor lead the typing on the screen it freezes too.
I put Silver Oxide thermal compound on the CPU because it was old and wearing off. Someone on here suggested that it could help. Not that my cooling assembly was not working. IT DID NOT FIX THE PROBLEM!!! My 450rog is about 5 to 6 years old and only now it started to have that problem. However thanks to DaeTrayder I am going to try this new approach. I am pretty sure that it could help as nothing seems to be wrong with the laptop except for the occuring of crazy screen lines and freezing up. It really sucks that they slacked off on putting this thing together. I will get back to you all and let you know if it really worked.
Posted on Nov 23, 2008
I've been seeing more laptop computers with this elusive and hard to diagnose problem, everybody has a different opinion as to what's causing it. Its sad because I've read all over the internet about people spending money on all the wrong hardware and still have the same problem..
If your problem is like the one I've seen it comes on slowly, and intermittently. Sometimes when it freezes the screen has lines flashing up and down the screen, other times it will just go blank. If you touch or jiggle the computer right when it happens the screen clears up, or sometimes it gets worse.
You can tell by the behavior that its a connection problem of some kind.
Sadly, this problem has affected most of the Gateway 450ROGs that were manufactured. This exact problem also plagued several thousands of iBooks manufactured from 2002 and 2003. The common link is the ATI video chip. This was the time they started using the "flip chip". Its a low profile chip that sits so close to the motherboard you think they crazy glued it down. They are not socketed because they wanted to get away from that. The shorter traces made it more efficient. Each trace is a tiny little ball of solder lined up in a matrix. Problem is, the chip begins to seperate from the motherboard.
Solution: Direct heat on the chip for 5 or 10 minutes will help. Enough to cause the solder to soften up and make a better connection upon cooling. I've seen people use heat guns (very carefully of course) or a hot iron. You can get around the problem temporarily by just applying pressure to the chip. I put two little squares of thin cardboard on the chip and put the laptop back together on top of it, it creates enough pressure to make contact. This isn't a permanent solution, a laptop chassis twists a little just from being picked up... its a matter of time before you start having trouble again.
This blog is very old but I know that I appreciate it when people share their knowledge.
Good luck, I hope this helped those that posted before.
Posted on Oct 26, 2008
  • 85 Answers
It could be that the cooling fans were both faulty, or the thermostat on the motherboard could also be at fault.
In either case it would need to be investigated by a engineer as it would be impossible to tell with out seeing the unit.
Posted on Jun 20, 2008
Gateway 450ROG cpu upgrade
This computer is ancient. You could buy a refurbished computer for $80 and it would still be at least 4 times better than this computer. Just buy a new computer.
Feb 02, 2013 | Gateway 450ROG Notebook
I reinstalled winxp sp3 on a gateway 450 rog. I was able to install all the drivers except the network controller and it also won't recognize the wireless adapter, any thoughts or ideas?
I had the same problem.
The "Network Controller" in my case had to do with the wireless network driver on my 450ROG.
None of the drivers that are available for 450ROG on the Gateway Support site worked correctly.
Here's what I did to solve the problem:
1. Flip the computer over. 2. On the back, you may see a little module that says "Fitted with Intel WM3B2100 802.11b". That's the built-in wireless network card (had no idea this computer had one, I inherited it). 3. Go to the Intel support site:http://downloadcenter.intel.com/ 4. Do a search for the "WM3B2100" driver. 5. Download and install the driver.
Fixed it for me!
Full info about the Gateway 450ROG is available at: http://support.gateway.com/s/Mobile/Gateway/450ROG/3501353sp66.shtml This helped get me on the right track.
Oct 17, 2010 | Gateway 450ROG Notebook
How does one change the CMOS battery of the Gateway 450ROG PC Notebook
One should not need to. Laptop cmos batteries should last for many years. Some cmos batteries are soldered directly to the board, you would need to dissasemble the laptop to find out.
Not many manufacturers provide service manuals, they dont want the average person to try to take the laptop to bits.
However, i have found your service manual in case you wish to try http://tim.id.au/laptops/gateway/gateway%20450rog.pdf
Aug 26, 2010 | Gateway 450ROG Notebook
How to find the inverter part number on a Gateway notebook
you can find them at gateway.com or inside the computer but i dont reccomend taking it apart! good luck!
Dec 18, 2009 | Gateway 450ROG Notebook
Replaced harddrive in Gateway 450rog and now wireless doesnt work
Simply reinstall windows xp over. I did it many times.
Mar 27, 2009 | Gateway 450ROG Notebook
Gateway laptop 450ROG freezes up after it gets hot & screen frzs
This definitely sounds like a heat problem. The system fan should cool it, but there may be a lot of dirt in the heat sink or along the path that the fan blows air. The first thing I would try is to get a can of canned air and blow it into all the vents under and on the side of the computer. If it is dusty, keep your face away.
You didn't say, but if you let the system cool down for a while (maybe 15 minutes or so) and start it up again and the same thing happens, it['s definitely a heat issue.
Feb 08, 2009 | Gateway 450ROG Notebook
Gateway 450ROG laptop turing on and off
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jan 16, 2009 | Gateway 450ROG Notebook
Confused on how to install gateway hardrive
Instructions on how to replace the hard drive:
http://support.gateway.com/s/Mobile/Gateway/450ROG/3501353faq85.shtml
Click on this link or copy and paste the complete link into your browser.
Thanks, Joe
Jan 10, 2009 | Gateway 450ROG Notebook
Gateway 450ROG notebook repair
I would personally say that it was the motherboard, but it would be impossible to guareente that unless an inspection was carried out.
The support I could offer if you wanted me to take a look would be for you to send the laptop and power cables to us, we would take a look. If we cant fix it we will return it to you with no charges. If it can be fixed you would be informed of the cost before we go ahead and do it.
Please note that you will have to pay for the delivery to us in any case.
Regards
Simon
Rytech UK
Jun 23, 2008 | Gateway 450ROG Notebook
Gateway 450ROG Notebook Logo
99 people viewed this question
Top Gateway Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
