Question about Karcher 2500 PSI Pressure Washer
Coleman Pressure Washer Problem
I have a: Coleman Powermate® 2400 PSI 5.5HP Pressure Washer Item #6212 http://www.toolsnow.com/browse.cfm/4,2219.html -recenly it would not put out any pressure. When running it still worked but only put out regular hose pressure as if it was not pumping it. It worked the day before...but the next morning...no pressure. I heard of fixes for other pressure washers that involves taking out a part and greasing it with some kind of white grease that fixes the same problem on this, but of course, mines not like the other oones and i have no clue as to what it is. I apptrciate any help! Thanks
  • police6743 Oct 29, 2008
    i have a coleman powermate 2200 w/ the HONDA 5.5 engine and 2.1 gpm i also used my machine a couple of days ago with out any problem,, then today nothing more then tap pressure. i,m sure there is some simple fix,,,and would like to know if any one else has dealt with this successfully ? thank you ,,, kevin
  • JERRY ABELL
    JERRY ABELL May 11, 2010
    hello! so tell me what is your pressure washer is doing wrong;
  • 33 Answers
Your pressure relief valve is stuck open. i know that may sound too simple but it depends on if you use a cleaner with the water when your using it , not flushing with clean water after use can cause the housing of the aluminum housing of the relief valve to corrode. the valve can't move back and forth as it should because the o ring won't slide.
Posted on Apr 21, 2009
Need the manual
A model number would have been helpful; however this may be your manual:
http://www.powermate.com/pdfs/2007/11/10/manual_pw0501400.pdf
If the above is not your manual, check your unit for a model number and then review or search the list here:
http://www.powermate.com/productmanuals.php?cat_id=6
Jun 28, 2011 | Coleman Powermate DuraBuilt 1400 PSI...
Coleman powermate wont restart spraying after release trigger
Make sure your fluid level in the pump is changed and at the right level.
Sep 24, 2009 | Coleman Garden
I have a coleman powermate 2400. It started fine
Did you try a new spark plug. Old one may have fouled.
Jun 25, 2009 | Karcher 2500 PSI Pressure Washer
Lance
Here is a link where you can look up your exact model and replacement parts from coleman...
http://www.ppe-pressure-washer-parts.com/coleman-powermate-pressure-washer-parts
Looks like your model may be out of production though so here's a generic kit that will 99% work with your washer...
http://www.silverbin.com/FAIP-PowerWasher-Universal-Pressure-Washer-Gutter/A/B000EEQ9KM.htm
Hope that helps...
Feb 09, 2009 | Coleman Powermate DuraBuilt 1400 PSI...
Karcher 2500 PSI Pressure Washer Logo
834 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
