Question about Scosche Industries (UBHP) Consumer Headphones
UBHPK: Rechargeable battery replacement
AFAIK, capacity of the rechargeable battery to hold charge will diminish with time and eventually it will have to be replaced.
So I was trying to find some instructions as to how they can be replaced.
IT would be great if I could know ;
- the type of batteries used in the headset and transmitter ;
- where I can buy them and ;
- how I can replace the batteries(how to open up the headset and transmitter so that I can get to the batteries)
Rechargeable lithium battery goes off after 3 minutes
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Apr 09, 2013 | Audio Players & Recorders
Will not hold a charge and the scren went black
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Feb 21, 2013 | Fujitsu Siemens LifeBook Computers &...
Battery not holding charge
Jan 26, 2013 | SanDisk Sansa e250 MP3 Player
Battery is not fully charged
Jan 19, 2013 | Audio Players & Recorders
Battery will not hold charge
If the rechargable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Nov 14, 2012 | Sony Nwz-w262 Water Resistant Mp3 Player...
Nwz-w262 battery will not hold charge
Nov 14, 2012 | Audio Players & Recorders
Will not hold charge
Nov 02, 2012 | Kodak EasyShare DX6440 Digital Camera
My eclipse cld 4gb mp3player wont hold a charge
Oct 17, 2012 | Mach Speed Trio Eclipse 4GB CLD MP3 Purple...
Battery not holding a charge
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.Since you did not supply details of your device and the type of battery I cannot advise where to purchase the battery.
I suggest you Google the Internet for the rechargeable battery you require.
Apr 15, 2012 | Televison & Video
My contoller charges but does not stay on afterwards. it shuts down and stays powerless.
It sounds as though the battery inside the controller is bad. When rechargeable batteries run out of life (it happens to all of them eventually) they take on what is called a "memory" and while they will take an active charge, even show a full charge, the capacity to hold a charge can diminish to nearly no time at all. Sounds like you need a replacement. In the mean time, you should be able to operate the controller while the charging cable is connected.
May 05, 2011 | Computers & Internet
Scosche Industries (UBHP) Consumer Headphones Logo
Top Scosche Industries Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Scosche Industries Audio Player and Recorder Expert? Answer questions, earn points and help others
