Question about Black & Decker B2000 Bread Maker
Black and Decker B2300 Bread maker problem
One of the kneading blades is stuck and won't turn at all. It seems one of the turning shafts on the bread pan is stuck and not turnable. The other turns freely. Could you please tell me how to solve this problem?
Thanks a lot for the help.
  • 3 more comments
  • mcteverett7 Aug 17, 2008
    SEEMS NEITHER ONE OF THE MIXING PADDLES WILL MIX THE BREAD . I CAN HEAR IT WORKING. BUT NOTHING IS HAPPENING. IS THERE A WARRANTY ON THIS MACHINE AND HOW MUCH . I HAVE MY PURCHASE RECEIPT .
  • vdky Aug 22, 2008
    It seems on mine the mixing paddles don't even turn either. In my instance you don't even hear anything happening. beginning to wonder if there is a defect in the programming functions or something else gone wrong.
  • osmerus Aug 27, 2008
    I have the same problem. The mechanism holding the small turning wheel isn't built right so its not locked onto the turning shaft. Poor design. I tried tightening the nut holding it on. The little plastic pieces holdingmetal piece that holds the wheel onto the shaft aren't strong enough. I found them in the botto of the machine.
    Enough problems with B&D. Going to Cuisinart
  • millfred Mar 08, 2009
    Same problem. It worked once, and never again. It just won't mix. We are throwing it out since we don't have a receipt.
  • Walter666 Apr 19, 2009
    One paddle turns properly while the other is loose and does not. Will try taking mechanism below paddles and see what can be tightened. Will also call B & D Monday at 1-800-231-9786. Have had the unit 16 months. Warranty was 1 year.
Black and Decker does not have the necessary replacement part (I called them). Also difficult getting access to it: removing inner liner is necessary for access to screws going down into base. Gluing would involve using one that can also withstand heat. So any ad hoc repairs are not recommended.
My last breadmaker, a Hitachi, lasted 5 years. I tossed it because it was a vertical loaf type. No Black and Decker for me, not even the newer model. All things, it seems, are to be replaced after their warranty period ends with newer one.
Posted on Apr 20, 2009
WHEN EVER I MAKER BREASD IT ALWAYS COME OUT AHARD ON THE OUTSIDE BUT SOFT ON THE INSIDE I CAN EVER HAVE SOFT CRUST
Posted on Jan 09, 2009
Im having the same problem, anyone find the solution?
Posted on Sep 06, 2008
Where to purchase replacement Black and Decker bread maker paddle for model B2300 Thanks!
Replacement parts for your Black & Decker B2300 Bread Maker may be ordered online from the following site:
http://www.directpartsandproducts.com/bread-makers-b2300-c-1_96_115.html
Good luck. Thank you for using FixYa!
Aug 21, 2011 | Black & Decker Bread Machine
Where can I get parts for B2300 Bread machine. eg paddle shaft and seals
1) HAVE YOU TRIED THE BLACK AND DECKER WEB PAGE
2) AMAZON DO SOME PARTS, TYPE IN THE SERCH BAR BREAD MAKER PARTS THERE ARE A FEW PAGES.... GOOD LUCK
Mar 07, 2011 | Black & Decker B2300 Bread Machine
The rotating shafts that hold the kneading blades in place keep sliding through the bottom of the bread maker
The spring washer that holds the spindle in place has probably come off. If you or your husband take off the bottom panel you might find it laying in there. Unplug your machine first of course before attempting any work. If you machine is like most it is a little spring clip that looks like a little horsehoe. Try to get it back on. It fits in a little groove on the very bottom of the spindle.
Feb 15, 2011 | Black & Decker B2300 Bread Machine
Needing the recipe for white 3lb sandwich loaf for the all in one model B2300. Lost the manual and there is nothing online
Hi Lyndseycoone:
Here is the recipe from the manual
3 cups of water (80 to 90 F)
3 tbsp butter or margarine, cut into pieces
1 tsp salt
3 tbsp dry milk powder
4 tbsp sugar
5 1/2 cups bread flour
1 1/4 tsp active dry or bread machine yeast
1. Measure ingredients into bread pan in the order listed
2. Insert bread pan into unit, close lid. Plug unit into wall outlet
3. Select Sandwich setting and appropriate loaf size (3 lb)
4. Press start button
5. The Complete Signal will sound when bread is done.
6. Using pot holders remove bread pan from the unit and carefully remove bread from pan and turn right side up. (Kneading blade may remain in bread. Remove blade when bread is cooled.
7. Allow bread to cool on wire rack until ready to serve at least 20 minutes.
Hope this helps...
Darlene
Nov 06, 2010 | Black & Decker B2300 Bread Machine
Blackndecker b2300 breadmachine
Hi, Take the pan out of the machine and see if you can turn the paddles by hand. If yes that's good...if no then paddles are sticking. Keep pan out of machine and start a kneading cycle. Look through the lid window and see if the motor shafts are turning. If no...then the belts fell off or are loose. If everything is fine then maybe it's the electronic panel. Hank
Mar 28, 2010 | Black & Decker B2300 Bread Machine
Black and Decker B2300 Bread Maker - one of the 2 agitators quit turning. What is wrong?
HI,
It could be the sealed bearing on the bottom of the bread pan is stuck or frozen, or the belt fell off the pulley or has snapped. Hank
Jan 28, 2010 | Black & Decker B2300 Bread Machine
Kneading blade cooks into the loaf
Hi Jessica,
As I read the manual, under the Care & Cleaning section,
"2. If the kneading blades remain in the bread pan, grip the kneading blade and
pull straight up to remove......"
Based on the diagrams and instructions, I don't think you're supposed to pull the blades before baking...why do you want them out? Cosmetics?
If I can be of further assistance, let me know. If this solves the issue, please rate it accordingly.
Thanks in-advance for using Fixya.com,
Jon
Jan 08, 2009 | Black & Decker B2300 Bread Machine
Parts for bread maker
Go to e bay. They have a couple of stores that sell nothing but parts for bread machines.
May 14, 2008 | Black & Decker Kitchen Appliances - Others
Kitchen Appliances - Others Logo
711 people viewed this question
Top Black & Decker Kitchen Appliances - Others Experts
Greg Cann
Greg Cann
Irene Tulloch
Are you a Black & Decker Kitchen Appliances - Other Expert? Answer questions, earn points and help others
