Question about Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer
Jukebox wil not play . . . all relays buzz when unit is powered up. Might be a bad power supply???
    Champion:
  • Wurlitzer Expert
  • 211 Answers
Is this a Wurlitzer One More Time you are talking about? There are no relays. Well there are, but they are in the credit computer. Is that what you mean?
Dave .
Posted on Jun 21, 2008
Hi I have a rockola 481 jukebox and when you turn it on a very loud deafening buzz constantly stays there ,if u play a record the overload light comes on. Dave
Can be from some mechanical parts, like small electromotors. Or from the supply power frecquency passing audio filters. Usually, changing condensers in power supply unit fix the problem.
Sep 10, 2017 | The Audio Players & Recorders
96 windstar eec wiring scematic
Find another relay with an identical part number(maybe the fuel pump relay)& swap it in place of the suspect EEC relay.See if the buzzing quits.If it does,the EEC relay is bad.There might be a ac WOT cutout relay or fan relay with an identical part number that you can use instead of the fuel pump relay.The fuel pump relay & EEC relay will both have to be in place in order for the engine to start.A relay should click when you turn the key on,but it shouldn't make a buzzing noise.BTW-the EEC relay is energized when you turn the key on and then it supplies ignition on power to the computer,injectors,solenoids and fuel pump relay.Therefore, if the EEC relay is defective, these components are Not going to work.If you don't hear the fuel pump prime when the key is first turned on,that's a sign the EEC relay is bad.One of the injector wires should have battery voltage, if the EEC relay is powering up.If your vehicle doesn't have a matching relay to the EEC relay(except for the fuel pump relay)just pull the FP relay out and slide it into place of the suspect EEC relay for testing purposes.If the buzzing noise stops,then replace the relay because there's no way to test if the car will start without having both relays in place.
Oct 11, 2015 | 1996 Ford Windstar
Display light for totals on cyclone pin ball machine don't display
Assuming the game is playing, but just no displays lit.
1. Check fuses on power supply board for a blown fuse. Sometimes the fuse clips will crack and not provide a snug hold to the fuse.
2. Look for bad (cracked) solder joints on the connector pins on power supply board.
3. There are two 39K resistors on the power supply board that go bad (usually go open circuit). One of those resistors is for the +100 volts and the other one is for the -100 volts. All it takes is one of those resistors to go bad and the displays will be blank. Originals were rated at a half watt, but it is suggested to replace with a higher wattage value, say 39k at 2 watts. If you find only one bad 39k resistor, replace the other one too at the same time because that one will soon fail.
May 29, 2014 | Wurlitzer Jukebox CD Player
My speakers are currently turned on, at normal volume. Whether I try to play music or not, a buzzing noise comes from the speakers.
your power supply is bad for the speakers giving them to much power or there bad speakers plug some headphones up and see if it makes the buzzing if it does then you have a power problem with your computer or sound card
Mar 17, 2010 | Audio Players & Recorders
Wont eject disc
Ouch!
1. power OFF
2. UNplug cord at wall
3. Turn ON jukebox (w/o power cord plugged in)
4. Turn OFF jukebox
5. Plug cord into SURGE PROCTOR (not wall, not simple power strip)
6.Turn ON jukebox.
7. If it doesn't work, try once more; otherwise ... *sigh* repair/replace..
Sep 01, 2009 | Audio Players & Recorders
I have rowe ami jukebox Eagle Laser Star and its amp seems to be dead sin have no sound justa a buzz. Need to find one or how to repair it.
CALL AB JUKEBOX SERVICE--ASK FOR BRUCE--TELL HIM LES FROM RMC VENDING SUGGESTED YOU CALL HIM.-
603-382-6272
Apr 27, 2009 | Wurlitzer Jukebox CD Player
My Wurlitzer 1015 100 cd jukebox wont play cd's
The problem may be in the power supply, it could be dry (cold joints in the USA) joints that are giving you problems. If you have the manual try checking the voltages at the power supply before and after you get the problem. It could be that once the jukebox is aired that the problem starts.
Regards
Alan Hood
ami-man
UK
Jan 13, 2009 | Wurlitzer Jukebox 1015 One More Time...
Fan not blowing
Even when the power is off at the unit outside the thermostat will supply power to the contactor of the outside unit. This may give a hum or buzz as you stated. If when the power is on to the outside unit the fan tries to start but only hums the motor may be bad. Does the compressor start and run?
May 06, 2008 | Weather King 10AJA2501AH Air Conditioner
How do I charge the philips mp3 player?
Connect the supplied AC/DC adapter/charger to the 5V DC jack on your hdd and the power supply. The AC power icon will indicate on display showing that the Jukebox is now adapter operated. It takes 4 hours to fully recharge the hdd and once the battery is recharged fully, the jukebox can play up to 10 hours of music on the move
Dec 30, 2007 | Philips HDD120 MP3 Player
Sanyo DS25390
it looks like a capacitor problem in power supply circuit. the humming and waving of the picture is caused by a faulty filter capacitor in the power supply circuit. have it check and replaced if found faulty. good luck!
Apr 07, 2007 | Sanyo DS25390 TV
Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer Logo
67 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
John Robertson
John Robertson
Level 1 Expert
jasbo
jasbo
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
