Question about HP Photosmart C3150 Printer
Not printing the printer doesn't seem to be connection to the computer so it doesn't print
  • 197 Answers
Ok...unplug from computer...shut down printer...turn printer back on after 3 min, then plug back into computer. should see the printer and then just do a test page.
Posted on Jun 20, 2008
Text missing when document is printed from Brother MFC-9840CWD
Hello,This issue may becaused by poor connection. Check to see if all interface connection cables arein the printer. If the printer doesn't establish good connection with thecomputer print quality will decrease.Second thing you can check are thesettings on the computer. Are they matching with settings in Brother MFC-9840CWD.This is issue is not caused from the toner cartridge or drum unit.
May 09, 2012 | Brother MFC-9840CDW Laser Printer
Hi. I have a wildfire s and want to print photos using a USB connected straight to my printer put the option just doesn't seem to be there when they are connected. Can anyone please help?
There is no way you can do that. It does not have usb host mode. What you can do is connect via usb to your computer, select disk mode and browse for the files (usually in DCIM folder) and print them using the default image managing sw on your computer.
Feb 23, 2012 | HTC Cell Phones
The printer doesn't print when you tell it to from the computer. When you mess with the buttons, then it will sometimes print a day later.
Its not a net work printer, they how you are connected this printer for all computers & laptops?. It might be connected to one system from there its shared..right. In this situation if any computer fired print command it has to reach the local computer where printer connected. If the local computer shut down, printer unable to print due to no print command.. or else if any net work related issue with in your systems you wont get prints.. Find out were you are stuck. If printer is printing well from the local system you cannot suspect the printer. Just you start from local system, then check in all systems. Pl get back to us for further remedies..best of luck..
Feb 04, 2012 | HP LaserJet 3050 All-In-One Printer
Changed the ink cartridge and now the printer doesn't recognize the computer.It says the printer is idle. What do I do?
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Jan 29, 2012 | Lexmark X4650 InkJet Printer
Not able to print
  4. Reboot computer.
Jan 25, 2012 | Lexmark X8350 Print, Scan, Copy and Fax...
My Lexmark z2300 sends to the printer & it says it's printing, but it doesn't actually print. I've tried several file types & programs to print from but none of them work.
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed.
Sep 14, 2011 | Lexmark Z2300 InkJet Printer
Lexmark X4650 prints fine & used to scan to computer, now when press scan>scan to computer>downloading application list & seems to freeze.
4. Reboot your pc.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list again, then try to print again.
Aug 31, 2011 | Lexmark X4650 InkJet Printer
I have an epson stylus TX110 and it was printing fine today, but then as is sent a job from adobe it prepared to print (made usual noises) but then didnt take any paper and just went quiet. I've tried...
Try purging your temp files. If it's a usb connection try a different usb port. Since it can print from scan and do a test nozzle print then it's not getting data from the pc to the printer. If a different port doesn't work either, and if purging your temp files doesn't work try it on a different computer if possible. You may need to reinstall the driver for it.
oh and make sure you don't end up with one of those 'oh duh' moments :) ... check both ends of the cable to make sure it didn't become loose or unplugged :)
Jun 05, 2011 | Epson Stylus Photo R1900 InkJet Printer
I have installed HP 1220c printer on windows 7 in several ways. Printer seems istalled OK, when I try to print test page or other, the printer doesn't react. Although the print appears and dissapears...
Unistall any previous you have installed for your device.
The Driver for Your Product Is Included in the Windows 7 Operating System (i.e. Win 7-32bit & 64bit).
Simply connect the printer to your computer with a USB cable, and Windows Update automatically installs the driver for your product.
Hope it helps.
May 30, 2011 | HP DeskJet 1220c InkJet Printer
HP Photosmart C3150 Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
