Question about LG L1915S 19" LCD Monitor
CTX monitor menu locks
It's a silver LCD CTX S762A monitor, for some reason the green screen menu box appears all the time saying "press" and an ENTER button drawing, than it disappear and another box appears saying "key lock".
I tried calling the support and they said I should press 2 buttons together when I turn on the monitor but no luck there.
Any help?
Thank you
Hold the enter and esc keys while turning on the monitor should relase the key lock
Posted on Jul 29, 2008
My lcd screen switch goes green and a message appears "going to sleep" and the switch light goes yellow
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or flashing, but nothing displays, borrow a monitor from a friend. If that works, your monitor needs replaced.
May 10, 2014 | CTX S762A 17" LCD Monitor
Screen locked
I would suggest turning the monitor off and unplugging it. Then retry the settings.
Try this manual:
http://support.octek.com.au/Downloads/Files/CTX/S762A.pdf
Jan 07, 2012 | CTX S762A 17" LCD Monitor
I am facing problem with my Samsung LCD monitor, when I switched on my Computer it shows the bootup screen, after booting the LCD screen goes blank, when i turned off the monitor and again turned ON the...
Try to do this: Just before the Windows start up screen (after the bios loading) press F8 and log in at safe mode settings. If at this mode you can see your screen change the resolution settings at a lower set. Save and reboot normally. Now try step by step to increase your resolution. In case of a blank screen appears at a new setting, don't do anything; after some seconds the monitor will come back to the previous settings. Save and go on.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Mar 05, 2010 | CTX S762A 17" LCD Monitor
Ctx monitor
try lowering the screen resolution
Oct 19, 2009 | CTX S762A 17" LCD Monitor
Monitor turns off and power button light flickers on and off and
When does it do this? Is it a power saving mode? Check the connections to the VGA cable are secure.
Jul 20, 2009 | CTX S762A 17" LCD Monitor
Videos (like on youtube) stops after 2 seconds and reloads
this is not your monitor problem this is your system CD Drive lens so plz check drive and clean cd lens
plz call 09944377607
Jul 25, 2008 | CTX S762A 17" LCD Monitor
Hp pavilian f1703 monitor
Press the menu button again (or when done adjusting) and it will go away.
May 09, 2008 | CTX S762A 17" LCD Monitor
Dark
It could be a few things, it may be the monitor itself, which naturally has dark picture.
Or by factory default the monitor has low brightness.
Try going into the menu and putting the brightess up.
Most monitors have low brightness by default.
have a happy new year.
Dec 29, 2007 | CTX S762A 17" LCD Monitor
LG L1915S 19" LCD Monitor Logo
543 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
