Question about Eclipse EA3422 Car Audio Amplifier
Need help in installing amp.
I am new and i got one amp EA3422 from Eclipse and i don't know how to install..
can u please help me...
  • 48 Answers
Depending on the power consumption of the amp u will need to run a 4-12 ga wire to the positive battery terminal. then u need to ground it with a wire connected to a clean ground like a chassis bolt. next u need preamp outputs on ur deck to send audio signals to the amp. lastly u need to hook up a remote wire to the blue wire in ur cd player harness
Posted on Jun 20, 2008
I have a 4 channel amp that id like to know how to bridge.. I have two 12 inch
to bridge it you would connect one wire to the positive from one of the two terminals and one to the neg from the OPPOSITE terminal
May 15, 2011 | Eclipse EA3422 Car Audio Amplifier
EA3422 Car Audio Amplifier: Keep popping fuses...
Check your ground and power wire connections. It will most likely be a bad ground, if grounded in the trunk, get a longer wire of equal or greater thickness and ground to either chassis or battery. Also if you have the amp at full gain try dropping it a little back if getting a better ground doesnt help
May 18, 2010 | Eclipse EA3422 Car Audio Amplifier
How to wire for 3 ch mode
this is the manual and you will find all you need in it.
http://www.fixya.com/support/p78783-eclipse_ea3422_car_audio_amplifier/manual-18248#
Jan 29, 2010 | Eclipse EA3422 Car Audio Amplifier
Car Ampli Problem
forget hooking this on a subwoofer. this amp produces only 50 watts per channel at 4ohms or 70 watts per channel at 2 ohms RMS...
If you try bridging the sub, it will only give out maybe 100watts bridged.
So..... if your sub is, lets say 1000watts RMS, youre just going to bust your amplifier to smoke...
Find a more decent and powerful amp. This amp is only intended for separates and lowend subs with an RMS of 80 to 150 watts
Sep 08, 2009 | Eclipse EA3422 Car Audio Amplifier
Sony xplod XM ZR602
What ohm is your sub running at. Sounds like your runnig your amp to low an impedance causing it to thermally shut down, when it cools a bit it turns back on. Either that or you have wires crossed somewhere. Check your wiring and make sure the load of the speaker does not fall below the rcommended ohm of the amp. Usually 4ohms mono and 2ohms stereo
Sep 07, 2009 | Eclipse EA3422 Car Audio Amplifier
Need to know how to install new radio in a 2001 mitsubishi eclipse
call 1888mitsu2001 and hit option #4, then hit * (star), give them the last 8 digits of your vin and they will provide the code for FREE.
DO NOT PAY FOR THE CODE ONLINE OR GO TO A DEALER (they will also charge).
May 09, 2009 | 2001 Mitsubishi Eclipse
Disconnected my battery last night to install some headlights but when i hook the battery back up the front speakers don't work it doesn't sound the same
that strange i dont know is some instruct you that way but wht you did has nothing to do with the spk the only think i can say if amp working fine re-tune system
Mar 26, 2009 | Eclipse EA3422 Car Audio Amplifier
Eclipse Ea 3532 Amp
reconnect the new wire or check the component inside the amp....component number are f41
Jan 01, 2008 | Eclipse EA3422 Car Audio Amplifier
Compatibility
this is a safey feature in your amp. you are drawing too much power for the amp to put out so i shuts off when the breaking point of the total rms calue is reached. i would suggest getting a more powerfull amp, a larger ground/powerwire combo, or a farad capacitor to balancethe powerin andthe power out.
Sep 04, 2007 | Eclipse EA3422 Car Audio Amplifier
Problem with an eclipse EA3422 amplifier
Your problem is with your stereo/radio, not your amp... Take a friend amp and connect it up as you have yours and see if it does the same thing.
Aug 10, 2007 | Eclipse EA3422 Car Audio Amplifier
Eclipse EA3422 Car Audio Amplifier Logo
364 people viewed this question
Top Eclipse Car Audio & Video Experts
xxxxxx xxx
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
