I have a Kenmore Elite front loading washing machine. I noticed plastic in with my wash and I noticed the drum was hanging low. Upon further inspection I could tell that the drum deflector was all broken. What do I need to do to replace this. Is it as simple as replacing just the deflector or is there normally something else too. Let me know. Thanks.
  • 1,036 Answers
Is this the part that's broken?
Posted on Jun 20, 2008
Noticed plastic slivers in the drum and under the rubber boot.Is the from the drum being unbalanced
Could be that the 'spider' mount for the drum is broken and the drum is catching on the surrounding plastic outer drum.
Mar 15, 2016 | Kenmore Elite 45986 Front Load Washer
42936- My kenmore elite he front-load washer w/steel tub-has scrapping/unbalanced like sound coming from washer when in spin cycle, then after completed there is shredded plastic/fiberglass like mater
Sound like one of the wights has come off or is loose and damaging the drum and other parts take a under the machine and you may see the problem
Jul 29, 2014 | Kenmore Washing Machines
Kenmore elite quiet pan 4 he4t plastic piece replacement
There can be a loose bearing between the drum and the outer wall of the machine but, there is definitely something loose. I know that this is not what you would like to hear but, the best advice anyone can give you is have your machine looked at by a specialist. Moreover, going to your washing machine retail store, should have the equipment you are looking for, or you can search for it online and compare prices.
Mar 21, 2014 | Kenmore Elite 45986 Front Load Washer
Kenmore elite washer troubleshooting
Sounds like your bearings are worn and need replacing... a horrible job. The frayed plastic may mean a new drum. To replace the bearings you must remove and separate the drum which requires removing the top, front, and back panels. Lots of clips, screws, hoses, wires.... I'd take it on if this were my unit; but for a client, I'd say get a new one. This is not uncommon for these units. Sorry.
Feb 16, 2014 | Washing Machines
I notice F22 error message on washer. Door seems to be jammed and will not unlock
This is a door lock failure code and it means the door lock is broken or just failed to unlock. Click on the links below for the detailed instructions for manually unlocking the door and replacing the door lock and switch assembly if it has indeed failed.
Manual Door Unlocking of Whirlpool Duet and Kenmore Elite front-Load Washing Machines
Replacing the Door Lock and Switch Assembly on Whirlpool Duet and Kenmore Elite front-Load Washing Machines
Mar 12, 2011 | Kenmore HE2 Plus Front Load Washer
Two 8182233 plastic baffles broke
This is a common problem on front loaders,Once you get the new baffles they just snap in.They have clips.
Jan 08, 2010 | Kenmore Elite 45986 Front Load Washer
Water drains during spin cycle, but tub does not spin and appears to have dropped down. Machine does aggitate.
If you can move the tub by hand laterally - the rear main bearing has likely failed - or the drum rollers are worn.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 30, 2009 | Kenmore Elite 45986 Front Load Washer
Plastic in drum
Nov 25, 2008 | Kenmore Elite 45986 Front Load Washer
F6 flashing and won't spin
There may be a bra wire stuch between the drums. Try to pull it out through one of the holes and keep in mind that if it is a bra wire, that it is curved and will need to be pulled out at an angle.
Oct 23, 2007 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
