Question about Maytag M6P09S2ACOM Air Conditioner
Alert light is on and flashing
I was running the ac unit and it just shut off and the alert light is flashing and i need to know why.
  • krishend2002 Jun 22, 2008
    I have figured it out - it is not draining water properly. thanks
Check the water hose and empty any water in the unit and vaccum out the back to remove any dust.
Posted on Jul 30, 2008
  • 40 Answers
Its declaring a fault. Check the breaker. What kind of unit is it. Model
Posted on Jun 20, 2008
Klimaire KSWG012H113 Split System Air Conditioner
Check web site for significance of the four flashes. Could be that it is overheating and shutting down due to excessive current consumption.
Jul 24, 2016 | SNK Klimaire KSWG012H113 Split System Air...
Why are there no audio alerts on my Beltronics Express 795 radar detector? The unit powers up and all alert lights work.. I've checked to ensure the "mute" button is off. I bought the unit new years
I know this sounds silly but check and see if you set it to mute. Most detectors have this option either in the set up sequence or by pushing the volume button down.
but see if you accidentally set it to mute. Most detectors allow a mute setting and only light flash. This can b
Nov 10, 2014 | Express 795 Radar Detector
Two of my smoke alarms went off (no fire/smoke in or near house), one has a green light blinking and one has a solid green light, which need a new battery/reset?
The constant green LED means the alarm has AC power.
A flashing green light every 2 seconds without an audible alert means the unit recently sounded ( was the one activated ) and is now in latching mode to let you know that it was the unit that detected the problem. To clear the latching mode hold down the test button for 5 seconds.
Red LED flashing once per minute means that the back-up battery is connected and functioning.
Red light flashing constantly during alarm means that it is the unit that initiated the alarm siren.
Sep 04, 2014 | Cars & Trucks
We have 2.0 HP inverter wall mounted LG aircon, when we turn on the ac, the indoor unit only is running and shut down after 3 mins. What is the solution?
Hi Marie, does the green indicator light on the front panel flash after it shuts down? If it does...count how many times it flashes this will refer to a fault code diagnostic.
Keith.
Jan 02, 2014 | LG LS-K2430HL Heat Cool Mini Split Air...
First alert 9120b
Hi hislop_amand,
I know this is coming to you late yet I just seen your post and hope the following can still help you or others.
Kind Regards,
SD
FIRST ALERT Model: 9120 9120B
Normal Operation (AC Power)
Green LED ON; flashing Red LED once/ minute
No Audible Alarm
Normal Operation (DC Power - 9120B only)
Green LED OFF; Red LED flashes once/minute
No Audible Alarm
Mar 23, 2013 | First Alert SC9120B Smoke / CO Detector...
Dell studio 17 1745 laptop don't turn on anymore. Just hear DVD drive make a little noise ( normal when turning on ) then light flash as seen in video then dies.
That looks like a pre-programed system alert code to me that activates when a certain problem arises. Check your user's manual for system alerts. If no joy, try contacting Dell and simply ask them what that particular alert means. If they want to charge you (typical of these manufacturers) throw yourself on their tender mercy and say that you are not asking them to repair it, you only want to know where you can find what that alert means. It's worked for me in the past. Also try the Dell website for your model, they may have it posted there.
Feb 25, 2013 | Computers & Internet
My Amana asx 16 seer 4 ton system installed 3 years ago quit working. The alert light is flashing 6 times. What does this mean?
Hi if you are looking at the indoor unit and this is where you see this flashing light, remove the panel. The circuit board is where this led light is. You will also have a 3 to 5 amp fuse plugged into the board. Look for a chart on a panel door. It will be glued there. It will tell you what the problem is according to how many times it flashes. Could be several different safety switches. Make sure there is no door panel switch on the indoor unit, has if there is, the unit will not run after you remove the panel, it kills power to it. You may need to tape it down so you can have power to run it and check it out. Is the indoor unit a gas system or is it a 4 ton heat-pump? If you cant find what I have said, get back to me after checking these things and let me know . Check all breakers. Let me know if this is a package unit or a split, indoor and outdoor unit, or all in one. I will wait to hear back from you on this.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor.
Jun 29, 2010 | Heating & Cooling
Blinking Nature Indicator Light
air conditioner will run fine and then shut off. When it does this the nature indicator light on the unit begins flashing If I attempt to turn it back on the fan revs up and then shuts off 15seconds later. I'm not sure what it's trying to convey with theblinking light but when the AC shuts off...
Jun 14, 2010 | Samsung AS18A6RB Air Conditioner
TOYO TA-09CHS aircon problem
TOYO mini split air conditioner made in Japan is very very good quality and it can runs for 20 years without any problem. You didn't hire a best ac technician to install your TOYO unit. The tubing connection between indoor unit and outdoor unit is not the right torque and refrigerant leak. Your TOYO unit runs out of refrigerant. You need fix the leak and fully charge the system. You will solve the problem.
Jun 09, 2009 | Toyotomi TIN/TIG-329D Air Conditioner
Error code of 6 flashing light on circuit board,
There appears to be a short in the unit. Not sure where. The power to the fan is not interrupted completly when the fan shuts down, still feeding voltage to the fan, keeping it running slow. Before checking the wiring, please turn off power first.
Nov 19, 2008 | Heating & Cooling
Maytag M6P09S2ACOM Air Conditioner Logo
361 people viewed this question
Top Maytag Heating & Cooling Experts
Rick Johnson
Rick Johnson
Bill Long
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
