Microtek 997M monitor doesn't stay on...
I have a 19" Microtek 997M monitor that only stays on for a second or two then goes to a black screen.
If I turn the power off and back on the screen turns on a gain for a second or two and turns off again. At the same time the power on light continues to stay on.
I saw the other remedies to fix this problem but want to know if it will also work for the Microtek as there are 6 capacitors (pairs of two) next to the transformer.
I can't tell what size twwo of them are as there is only jibberish stamped on the can.
Any suggestions? The monitor light shows green meaning it is on and ready.
I boot up my mac mini, the "Chang" sound is heard, the light on the monitor turns yellow, then in 2-3 seconds a bright green light and then no light is shown. not another light.
1. checked power cord, O.K.
2. checked the signal cable connection, O.K.
3. adjusted brightness and contrast controls..but the monitor is black screen, no use there.
4. don't have a power saving mode?
  • shelley65 Jun 21, 2008
    Same!
  • zooj Mar 12, 2009
    I have exactly the same problem. Tried the monitor on another computer and same thing. If you power off the monitor on it's own switch and turn the power back on it flashes up the desktop image so the computer has started successfully.
  • 46 Answers
The inverter is the most common item to fail on a LCd monitor. Capacitors usally fail the most. Are the tops of any of them popped up. If you had any shorted transistors the fuse would probably be blown. Usally labeled F1. I would replace all the capacitors first and go from there. Capacitors are cheap.
Posted on Jun 21, 2008
My MICROTEK 997M monitor would not stay on. Opened it up and found two capacitors bulged on top from heat located next to the transformer. Bought them at $050 ea. and changed the two caps marked (470uf 25volts 105deg C) The monitor is now working perfectly. The other three in there but not changed are as follows: (two caps 1200uf 10volt 105deg C) one cap 330uf 25volt 105deg C) THANKS FixYa !!!! and members posting.
Posted on Nov 19, 2009
Dont buy princeton i have it for 2 years and now its useless i have a dell and 6 years still working
Posted on Jun 28, 2008
Screen keeps turning out
the problem is the power supply of your main board...you can replace the bulging/leak capacitors...to acces the power supply open the back cover of your tv..the power supply board is the pcboard which the mains supply is connected..you can also replace the whole power supply with a new one..resolder the board for its loose connections..
hope this helps good luck..
please rate my help...tnx for using fixya.
May 30, 2010 | Microtek 997M 19" Flat Panel LCD Monitor
My hp w1907 19' monitor goes black light stays green
it sounds as if you may have a backlight problem..i have two of them that the wire going to the backlight had burnt off at the bulb..I had to take the lcd screen apart to solder the wire back on the blub.. be carefull the lcd screen and bulb are frigile... ther is 4 lights two on the top and two on the bottom..good luck
Nov 10, 2009 | HP w1907 LCD Monitor
? to turn off key lock?
Enter in main menu, settings, touch protection. This should help you
Sep 14, 2009 | Microtek 997M 19" Flat Panel LCD Monitor
Microtek monitor 997m
Try pressing and holding the menu Key for 15 seconds, that is how masy OSDs lock and unlock
Jul 01, 2009 | Computers & Internet
Screen goes black after 2 seconds
This could be one of two problems, the light in your monitor has a loose cable, or the light is dying. I have seen cold cathode lights that are about 10-15$ to buy and many instructions on putting them in yourself.
Solution 2, your cable is loose on the back of the monitor. Make sure you have the screws tightened on either side of the vga or dvi cable, both on the back of your monitor and on the back of your computer or laptop.
Jun 28, 2009 | Planar PE191M 19" Flat Panel LCD Monitor
I have connected my microtek lcd monitor to my dell laptop computer. the monitor is plugged into electric outlet. the green light on the front of the monitor blinks. and i get a report of "no signal" but...
Have you tried pluging in the monitor in to the laptop before even starting the computer or Putting the computer in to "Stand by" then pluging in the monitor and then bringing the laptop out of "Stand by" or yet when you do have the computer on with the monitor pluged in, try "Fn" and a button hat has like two screens on it with a small bar in between them? All these should work.
Jan 04, 2009 | Microtek 997M 19" Flat Panel LCD Monitor
MICROTEK 19 "C783
19" LCD comes on and goes out right away
Sep 06, 2008 | HP vs19 (Silver) 19" LCD Monitor
I have an HPW19 wide screen monitor that goes to black.
I have the same monitor and it is only 3 month's old, the power lock button continues to fail and they have replaced it 3 times with the same issue, What a piece of ****!!!!
May 26, 2008 | HP w19 19" LCD Monitor
19 in lcd mag monitor
You need to try another monitor, any type. If you find another monitor does functions return the 19" monitor. Most monitors come with a 1 year warranty.
Feb 12, 2008 | Mag Innovision LT976S 19" Flat Panel LCD...
Computers & Internet Logo
1,041 people viewed this question
David Payne
David Payne
