Question about Jenn-Air JED8230 Electric Cooktop
Both burners turn on when only one is needed
I have a 3 year old Jenn-Air convertible cook top with electric griddle and cook top cartridge. After cleaning the cook top, I turned on one of the elements but both elements came on. I swapped out the cook top with the electric griddle, and when I plugged in the grill element the fan came on (as it usually does when using the griddle).
I obviously have a short somewhere. How can I find and fix this problem?
I just had the same problem- when I replaced the whole cartridge.
I repalced the infinite switch- do the one that gets the hottest- or do both.
It is easy to do- just write down the wiring diagram - make sure all power is off- cost of new switch was about $37.00
This solved the problem- however make sure to check the sizng on the new switch shaft as my old knob would not fit properly on the shaft of the new switch.
good luck
Posted on Jul 14, 2008
. Burners will not work unless the down draft fan is turned on and then neither works at full capacity.I flipped the breaker off and on.
Call Jenn-Aire to have a technician troubleshoot your cook top on site. You will save time and aggravation whether your cook top is gas or electric, possibly wired improperly, etc,etc,etc.
Apr 02, 2015 | Jenn-Air Cooktops
A guest used the electric griddle on my Jenn-Air. She made terriaki chicken and now the griddle has balack cooked on stuff ( probably from the sugar in the terrikaki sauce. I've had this griddle for...
if it has slightly raised sides or a fat drain
let it heart up and then used water on the hot surface to steam loosen the crud
you could put a bit of washing up detergent in the water ( just a few drops )to assist in breaking down the surface tension and release any grease
The same as cleaning a BBQ plate before using it
Nov 18, 2017 | Jenn-Air JED8230 Electric Cooktop
I have a older Jenn air electric cook top and I need to replace the burner element on one side. How do I get the old one out and where do I find parts. JEA 800 ADB
get a gas repairer to check for you or you go back to where u bought it and the burners will be replaced or sold to you if the cooktop is still under one year warranty
Jan 19, 2011 | Jenn-Air JED8230 Electric Cooktop
How do i replace my burner on my jenn air ceramic cook top . it has the down draft feature in the centre
1) turn off power at the breaker. 2) remove hold down screws 3) pop up cooktop out of counter top 4) remove knobs and downdraft grille 5) remove ceramic top (screws around outside and also in side grille opening) 6) unplug burners replace with new burner
Sep 17, 2009 | Jenn-Air JED8430 Electric Cooktop
Jenn-Air JED8345 one burner does not come on
The switch for the burner is bad and needs to be replaced.
Jun 25, 2017 | Jenn-Air JED8345 Electric Cooktop
Jenn-Air surface cooking elements look rusty and ugly
they make a special cleaner - polish just for the "solid" type burners. it looks like shoe polish and will make the burners look like new again. not sure where you can find it online but go to your local appliance parts houseand they will know what it is your needing.
Dec 27, 2008 | Jenn-Air JED8230 Electric Cooktop
Wearing burner
no fix other than replacing the cook top with a new one
May 05, 2008 | Jenn-Air JED8430 Electric Cooktop
Jenn-Air JED8230 Electric Cooktop Logo
374 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
jason
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
