Question about Sony Audio Players & Recorders
Hard to turn on and often turns off
Often I have to take the computer batteries out or turn them insitu to get the radio to work. Sometimes a squeeze of the casing gets it going. The radio has strong sentimental value otherwise I wouldnt bother you. The tone slider switch doesnt work either ( maybe needs a service).
Thankyou for the prompt reply but I have discoverred that Sony have a service centre in Auckland City so I'll give them a go and see if it can be fixed there. Regards.
Rick.
Posted on Jun 21, 2008
Radio wouldnt turn off even with the car off the radio still played. drained my car battery so i disconnected it is it the player or wiring?
Unlikely to be the wiring if it is still all original.
If the radio is a new fitment it should be noted some radios should not be fitted to some cars without modified wiring because a flat battery will result...
Sometimes the on/off switch of an older radio will fail.
The modern original fitment radios are computer controlled and try to anticipate what the driver wants. If the radio won't turn off it will either be the radio or the controlling computer. Dealer level diagnostic equipment might be able to locate the problem and a wiring diagram might be helpful.
Oct 19, 2015 | Car Audio & Video
Radio not working. On the computer dash it tells me audio low battery. What is wrong
hiya sometimes they have a reset button this can be on the radio pannel or if u pop the face off it might be behind it press that then try turning it on it might work mine did
Jul 31, 2015 | Cars & Trucks
1997 Toyota Camry will not turn over battery is charged
are you sure the battery is good , there is a big difference for say the radio etc working and the battery being able to turn engine over , if you've had the battery condition checked out then i'd say the starter motor would be the next thing to look at , try giving it a few hard strikes with a heavy hammer , this can sometimes jolt loose the bendix spring , if no go get a new starter
Jun 20, 2014 | Cars & Trucks
2001 e320 cdi estate changed battery turned on and abs and bas warning up on computer and cars revving round to 5000rpm and sticks there no real response from throttle ?
You may just need to reset your throttle sensor. There is no hard connection between the gas pedal and the engine its electronic. To reset :
All auxiliary systems must be off (radio, lights.aircon, etc) no electrical drains or CAN signals can be triggered during the process.
Turn the Key to the "on" position (the position right before you start your engine)
Press and hold your gas pedal down for 5-10 seconds
Turn Key to "off" position (dont remove the key) and then release the gas pedal. than wait 2 minutes, for the system to reset. Again without touching anything or having anything on.
Thats should do it. When you replace the battery you usually have to do the radio code, yaw steering sensor, throttle and sometimes transmission. On my last battery just had to do the radio but was expecting to do all.
Oct 01, 2013 | 2000 Mercedes-Benz E-Class
2008 Mitsubishi eclipse radio not working after battery change
Unfortunately in newer vehicles, they sometimes need to have the computer re-flashed IF you unhook the battery with the radio on. It's a crummy deal. The dealership will probably have to re-flash the computer. You could try turning the stereo off, then disconnect the cables on the battery for a minute, then re-connect and POSSIBLY it could reset the system and it may work again. Don't get your hopes up, this may not fix it.
Nov 11, 2012 | 2008 Mitsubishi Eclipse GT
Cobra microtalk frs120 won't turn on. Has sat for an extended period; there was a bit of dried battery acid in the battery compartment of both radios. One radio works, but even after replacing th
Sometimes that highly corrosive battery acid gets on the boards and trashes them. I have lost remotes like that and now remove the batteries on those units I do not use often - remotes are expensive!
And if it happens to an expensive piece of equipment, that really bites.
Sep 04, 2017 | Cobra Radio Communications
Fan belt squeezing when I start my car in the morning and sometimes cuts off and I need to start it again.fter I start it the second time it appears to run ok but later start squeezing again.
Might need a new belt.
Might be something else squealing like the alternator. Could be not putting out enough juice to charge the battery and is working hard at it. Could be the battery is bad and the charging system needs to work harder.
Or, do you start you vehicle with the A/C on? If so, try turning it off.
Aug 25, 2011 | Ford Freestar Cars & Trucks
No power , computer will not turn on
Hi, IF the system is not turning on any more, try removing the power cable, then press the power button for 10 seconds. then try to power it on again . If it is still not powering up there could be an issue wiht the power supply of the computer. But if it start to turn on, like showing the Sony logo then windows but not going to the desktop. you can try to log on using safemode. you can go there by pressing F8 on the keyboard after turning on the computer. If it still not turning on even on safe mode. there couldbe an issue with the operating system of the computer and needs to be reinstalled.
Thank you for using Fixya, your recommendation is highly appreciated for the free support.
Aug 20, 2011 | Sony VAIO V2M (VGCV2M) PC Desktop
Car won't start!!!
mine is doing the same... all i did was reconnect the battery...and it worked fine...but know my hood wont open!!! so i cant fix the cable on the battery!!! i pull on the darn cable so hard and the hood still wont budge!!!
Mar 18, 2009 | 1995 Oldsmobile Cutlass Supreme
54 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
