Question about Panasonic PT-47WX49 47" Rear Projection Television
Panasonic ct-34wx54j led blinks eight times.....what is the diag code?
5 Suggested Answers
phil_frye
  • 295 Answers
SOURCE: Panasonic plasma 50PZ85 power led blink 10 times
Either a bad power supply or a bad processor board.
A Good Service Shop should know what the 10 blinks are indicating.
May be a repair cost between $200 and 400 dollars.
Be prepared -
Blessings,
A/V Media Guy
Posted on Nov 22, 2009
  • 139 Answers
SOURCE: I have a panasonic CT-34WX54J and The Power LED
sounds like the horizontal deflection circuit is not running. this circuit powers the rest of the set. this will require advanced troubleshooting
Posted on Dec 28, 2009
welcomejee
  • 10594 Answers
SOURCE: What are the error codes for a Panasonic PT-47WX 42 TV
3 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Click Part Store to see an image of required chip and price info.
Local tv tech is recommended if you have no experience of working in tv circuit boards.
Thanks.
Posted on Apr 18, 2010
Testimonial: "Thanks"
Hello I have a Panasonic PT47WX53G and when I turn it on the red led (Power) comes on and then blinks 5 times, then it turns Off. After a few seconds the red led turns on again blinking 5 times. This cycle repeats until I unplug the TV.
Thank You Willie
Posted on Jun 01, 2010
SOURCE: I have a Panasonic CT-36hL43G TV that just turned
i hope your tv is more than 4years old ....... in all CRT TV's or CRT monitors after 4years a component called flyback transformer (see picture ) becomes weak - its work is to supply voltage to tube............. then following are the signs ...
(1) in some TV's only front LED's blinks - no picture no sound.... (2) in some TV's picture comes slowly after few seconds or after few mins or after few hours......... (3) in some TV's suddenly picture & sound goes temporarly & after some time again it appears ...... etc in case of (2) & (3) only flyback transformer needs to be replaced .....100% GUARANTEE again TV works normallyBUT in case of (1)... --------------- YOUR CASE (a) either only flyback transformer gets deffective or (b) flyback transformer & another component called transister ( will be near flyback transformer & its back portion is attached to aluminium metal ) gets defective or (c) along with flyback & transistor -- 3 or 4 more components (resistors, diodes, some times ICs ) gets deffective so replacing flyback transistor is a must .. & to find whether any other component is deffective or not completemainboard has to be checked ....... so if you are a technical person & having expierence in servicing line then you can do it yourself otherwise approach good tv service engineer ........... your TV is really very good one ... so don't think of buying new TV .... just goahead for repairing it it is worth & it works for atleast 2 more yrs....... try this & tell me what happened switch off your TV ... remove power cord from socket ,,,,.ware some mat or chapples to your feet ..... remove your TV's back side cover ......... observe carefully for any physically damaged components .... if you find then don't do anything ... close tv cover & approach tv service engineer ............. but if no physically damaged components are visible then take a suitable screew driver & rotate 2 (or 3) Knobs on flyback transformer in clockwise or anticlockwise direction - very little ( 4 or 5 degrees ) - you have to do this without touching any cable or any part of your tv .......... then fix..... back side TV cover ........connect power cord - stay at a distance & switch on your tv ......... if you get picture atleast for few seconds then in your case only flyback transformer needs to be replaced otherwise complete mainboard has to be checked. to find other deffective component ............. so your tv problem is a harware problem - it cannot be solved using remote control or any buttons on your tv ..... if you are finding difficult to get it repaired then you can remove your tv mainboard with the help of some technician & send to me ...... i will replace deffective components .... & send back to you ....you only have to bare the shipping charges .....it will take maximum 12days (5days - to recieve + 2 days servicing + 5 days to send back to you )....
Posted on Aug 16, 2011
My Panasonic Plasma HD TV will not display a picture. The red light is blinking eight (8) times. What does this code mean and is it a quick fix? Thanks!
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. Otherwise, you might have to go through more than 4800 posts it contains.
Oct 28, 2015 | Panasonic Televison & Video
I have a Panasonic Model # TC-P50U50T and it will not turn on.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Sep 18, 2014 | Panasonic TC-P50U50 50" VIERA U50 Series...
TV won't turn on
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Apr 02, 2014 | Panasonic CT-32HXC14 32" TV
The tv wont come on the light just flashes green
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Feb 22, 2014 | Panasonic CT-24SL13 24" TV
I have a panasonic tv CT-34wx54j red light 5 blinks
The power supply probably has failed. The clicks indicate it is trying to start up but can't.
Dec 30, 2013 | Panasonic Viera TH-50PZ85U Plasma TV
I need the tv code number to put into my Jensen Universal remote control for a Panasonic TV on cable, TV Model# CT-27S18S. I also need to know how to program these numbers into the Jensen remote Remote...
the panasonic numbers are one of the following
0051, 0250, 0055and to program it you need to do
Turn on the component that you want to set up.
Press and release the component key you would like to configure. The red LED will blink once.
Press and hold the "Setup" key until the red LED blinks twice, then release.
Enter the first 4-digit code number for the device you are trying to program. The LED will blink one on each digit entered, except for the last digit where it will blink twice to confirm that a valid code has been programmed.
Now test the code by pressing the "Power" key. If the component turns off, you've got the right code. Follow the same instructions to set up your other components. If the component doesn't turn off, return to step 3 and use the next 4-digit code listed.
Mar 16, 2011 | Panasonic (TH-50PZ700U) Television
I dont have a remote for my tv and it wont turn on manually the led light blinks 9 times and stops and starts again what should i do?
The blinking lights are a service code. You should first try to unplug your TV and leave it unplugged for at least 4 hours... then plug it back in again.
If the blinking light is still there and no picture, time to have the TV serviced. Good luck!
Oct 10, 2010 | Panasonic CT-34WX54 34" TV
TV Has no picture
http://www.bruzziforum.com/vbf/showthread.php?t=79
Panasonic probably uses the same code on your model.
Jan 11, 2008 | Panasonic CT-27HL14 27" TV
Tv switching off
This particular unit has a built-in diagnostic. The LED in front will blink for a set number of times following the failure. The blink code is:
1 Flash Power+140
2 Flashes Low B+ D.C
4 Flashes Hi Voltage Hhs
5 Flashes Ic4511
6 Flashes Ic4518
8 Flashes Audio Amp
Can you possible tell how many flashes there are following the instant shutdown?
Bill
Nov 25, 2007 | Panasonic CT-27HL14 27" TV
Panasonic PT-47WX49 47" Rear Projection Television Logo
69 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
