Question about Nikon Office Equipment & Supplies
Computer does not recognise sf-210 - Nikon Office Equipment & Supplies
  • 85 Answers
Which version of your operating system are you running. I most cases, removing and re-installing the drivers will fix this issue
Posted on Jun 20, 2008
Cannot connect laptop to samsung sf5100p fax machine
if your fax model is not sf-5100p it can't be used on a pc. the p is for printing
Feb 07, 2014 | Samsung SF-5100 Plain Paper Laser Fax
Tip
Nikon Coolscan IV ED Jam Solution Do you find your older slides, cardboard...
Do you find your older slides, cardboard slides, or irregular slides jam in the Nikon SF-210 Slide Feeder for your Nikon CoolScan IV ED?
Try this solution:
Take a AAA battery and place it in rear, left side of the slide feeding tray as pictured below:
The slides will fan out nicely, and your Nikon CoolScan IV ED will no longer try to load more than one at a time. Instead it will load them one at a time, 50 per tray, and you can actually walk away from it and let it do its job, just the way you intended to when you bought the SF-210 slide feeder attachment!
I hope that helps.
on Apr 09, 2010 | Nikon Coolscan IV ED Film Scanner
Tip
Nikon Coolscan V ED Jam Solution Do you find your older slides, cardboard...
Do you find your older slides, cardboard slides, or irregular slides jam in the Nikon SF-210 Slide Feeder for your Nikon CoolScan V ED?
Try this solution:
The slides will fan out nicely, and your Nikon CoolScan V ED will no longer try to load more than one at a time. Instead it will load them one at a time, 50 per tray, and you can actually walk away from it and let it do its job, just the way you intended to when you bought the SF-210 slide feeder attachment!
I hope that helps.
on Apr 09, 2010 | Nikon CoolScan V ED Film Scanner
My olympus fe 210 has the lcd screen broken, I would like to fix it by myself, how to replace it?
Hello Fabio,
You can find the replacement LCD screen for Olympus FE210 here:
http://www.pantallas.biz/epages/wwwpantallasbiz.sf/en_GB/?ObjectPath=/Shops/160419/Categories/Olympus
Jun 01, 2009 | Olympus FE-210 Digital Camera
LS5000 ED with slidefeeder sf 210
Hi there I had the same problem with auto focus sf-210.
If tried many things to correct the problem and what I found was that if you you put a small book halfway on the opposite site of the power button then I have maybe 1 or to slides out of focus and the other 35 slides are perfect ! (I used it with HAMA slides other slides I didn't test )
Hope this wil work also for you,
Paul
Dec 15, 2007 | Nikon COOLSCAN 5000 ED Film Scanner
Tip
Nikon Super Coolscan Jam Solution Do you find your older slides, cardboard...
Do you find your older slides, cardboard slides, or irregular slides jam in the Nikon SF-210 Slide Feeder for your Nikon CoolScan 4000?
Try this solution:
The slides will fan out nicely, and your Nikon CoolScan will no longer try to load more than one at a time. Instead it will load them one at a time, 50 per tray, and you can actually walk away from it and let it do its job, just the way you intended to when you bought the SF-210 slide feeder attachment!
I hope that helps.
on Apr 09, 2010 | Nikon Super Coolscan 4000 ED Film Scanner...
Tip
Nikon Coolscan Slide Feeder Jam Solution Do you find your older slides,...
Do you find your older slides, cardboard slides, or irregular slides jam in the Nikon SF-210 Slide Feeder for your Nikon CoolScan 5000?
Try this solution:
I hope that helps.
on Apr 09, 2010 | Nikon Inc Coolscan 5000
Printing from a PC with a Samsung ST-335T
Barry just a suggestion,try downloading the samsung software from the internet and see if that works.It may be just a comand problem.
Oct 24, 2007 | Samsung SF-335T Plain Paper Inkjet Fax
Tip
Nikon SF-210 Slide Feeder Jam Solution Do you find your older slides, cardboard...
Do you find your older slides, cardboard slides, or irregular slides jam in the Nikon SF-210 Slide Feeder for your Nikon CoolScan?
Try this solution:
I hope that helps.
on Apr 09, 2010 | Nikon Sf-210 Slider Feeder For 5000ed...
Tip
Fix that Jamming Slide in your Nikon CoolScan 5000ED / SF-210 Slide Feeder
I balked when someone whispered this tip to me; the thought of putting foreign objects into my Nikon CoolScan 5000ED slide scanner with its SF-210 slide feeder seemed asking for trouble.
After about a thousand slides worth of experience, and many batches that seemed to jam every other slide, I gave it a try and boy did it do the trick.
The SF-210 slide feeder works flawlessly with newer, thicker, plastic slide mounts, but if you are archiving and digitizing older, cardboard slides like I am then here's what wasn't printed in the CoolScan user's manual:
Take a AAA battery and place it in rear, left side of the slide feeding tray as pictured below.
I hope that helps.
on Dec 04, 2009 | Nikon Super Coolscan 5000 ED Film Scanner
27 people viewed this question
Top Nikon Office Equipment & Supplies Experts
Doberman
Jerry Greenberg
Jerry Greenberg
Tanvi Thakur
Are you a Nikon Office Equipment and Supply Expert? Answer questions, earn points and help others
