Question about Panasonic TH37PX60 37 in. Plasma Television
I have a 37" plasma panel which has given trouble free running up till now.
It's about 6 years old, wall mounted, being run from an panasonic tuner box. Picture fine when it works. responds to remote stby light green in normal operation.
Runs for about 5 mins then goes dark. the stanby light next to on switch now flashes red, one short flash followed by one long flash . unit will not respond to remote.
switch off then on provides a reset and picture returns.
any ideas
SOURCE: Panasonic TH-50PZ Plasma TV won't come on.
I had the same issue twice with a TH 42PWD5. turns out it was my UPS that was killing the switching power supply. Warranty covered it but when I removed the UPS not a single issue in 3 years.
Posted on Jul 01, 2008
  • 8457 Answers
SOURCE: 50 in philips hd plasma with ambilight model number 50PF9631D/37
The backlight inverter board is going just not dead yet.
U need a new board.
Posted on Sep 10, 2009
  • 1447 Answers
SOURCE: half of my screen plasma TV 50
Your Television problem on vertical section.
Solve: If you repair itself replace vertical IC or thoroughly resolder dry any components.
Posted on Jan 10, 2010
Hi, Usually any "Pops" are an Electrolytic Capacitor "blowing up" quite literally, or "Gassing" as it is called. This happens due to some sort of power problem. Capacitors hate AC Voltage and Current, and Heat and Over Voltage. All of which, I have no doubt it was exposed to before it went "Pop" This is only a symptom of a far greater problem, to come, no doubt, soon, the rest of the set will fail too. Please DO NOT USE. this set any more, you risk fire or explosion or both. If you MUST use it at least unplug at bed time. Theses days home repair except for the most rudimentary problem is not feasible, setting aside the safety aspect. In my professional opinion, I would recommend, that you get a "Quote" for repair from a Philips Authorised Service Agent This is very important, that you contact a Philips head office and ask for a referral. This way at least you can make a decision to repair or replace.
Posted on Apr 01, 2010
  • 8619 Answers
SOURCE: Panasonic Plasma TH-42PX60U, got a power surge.
Thanks for using FixYa.These kind of issues in plasma usually happens due to bad cap on any of the boards inside. However, to check what has gone bad you’ll have to open the back of the unit
you’ll need to check bulged/swollen capacitors on power supply board. As the unit won’t show anything for a long time so it means that it is the power board which is causing this issue. These issues usually happens due to overheating in plasma TVs after sometime, as these sets are very hard working device and produces a lot of heat.Please do accept the solution if the issue is resolved or post a comment for further assistance.
Posted on Jun 04, 2010
Panasonic Plasma tv model TH-37PX50U. Black vertical line about 3 inches wide runs up middle of screen about 1/3 of the way to the top. What is causing this?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Line, faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Line faults to all LCD screen are similar, irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jan 22, 2016 | Panasonic TH-37PX50U 37 in. HD-Ready...
How do I remove tv from stand Panasonic th-37pe30 tv
Disassemble procedure to many popular brand TVs and other devices are given in detail with illustrations.
Nov 28, 2014 | Panasonic TH-37PE30 37 in. Plasma...
Have a Panasonic TH-50PX500U plasma TV. Color go's to blues
check and reseat all the connections on your T-con board which is located in the midle top of your unit there will be a cable from the mainboard and 1 or 2 from the top to the panel carful those connectors are cheap clean with rubbing alcohol
Dec 01, 2009 | Panasonic TH-50PX500U 50 in. Plasma...
2 yr old Panasonic Viera 37 in - has very narrow
This is a fault developing within the screen, the only remedy is to have the screen replaced, there is no exact answer to why this has happened, it is just the nature of a plasma screens make-up that sometimes a fault can develop like this within the characteristics the display
Nov 16, 2009 | Panasonic TH37PX60 37 in. Plasma...
Panasonic Plasma Viera - screen is 3/4 and then a 1/4...split. what do I do??
i lost picture on main scream in panasonic th-37 pd 25 ,what i can dothanks
Sep 08, 2009 | Panasonic TH-37PD25U/P 37 in. EDTV-Ready...
Vertical Lines - Differnt Colors TH-42PHD7WK & TH-42PWD8GS
hi,im a hdtv technician i have encountered already for that kind of trouble.the problem of your lcd is the panel.the panel is defective replace it with a new one lcd panel. (olevia,syntax and kolin lcd thats the brand i assingn.)
Aug 01, 2009 | Panasonic TH-42PHD7WK 42 in. Plasma...
I have a panasonic 58 inch plasma that is a little over one year old. About 2" x 8" area on the top right does not display blue color any more. What is the problem? A expensive fix?
probable bad panel. take it to aPanasonic authorized servicer. Also contact Panasonic maybe they will help you out with the cost of the repair. Since the panel is not cost effective to replace.
Jun 26, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Panasonic VIERA TH-37PX80B 42" plasma telly
What ever sounds the best to you!. If you have a particular question regarding sound, let me know?
Jun 24, 2009 | Panasonic VIERA TH-37PX80B 37 in. Plasma...
Plasma TV with vertical lines
chake to make sure it is hooked up right and not lose
Feb 02, 2009 | Panasonic TH-37PX60U 37 in. Plasma HDTV
Panasonic TH37PX60 37 in. Plasma Television Logo
309 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
