Question about Saeco Odea Go
Descale I am not sure what descale means and what to do. Can you explain what needs to be done and how to do it? Thanx, Tammy
  • 1 more comment
  • Anonymous Feb 15, 2009
    I need help figuring out how to descale my new Odea Go
    thanks,
    Nina
  • jhbiggs Mar 18, 2009
    I lost my manual and need to descale. How do I do it?
  • mmla May 11, 2010
    When we descale the saeco odea go, do we need to change out the water filter?
  • 487 Answers
That means getting rid of the limescale build up in the machine.
When the limescale becomes to much the machine slows dow.
buy a descaling solution at your local convenience store or grocery store. Use it as adviced on the bottle but do this twice in a row because a 30-40 minute brew means a lot of blockage. When you do it the second time turn the machine off after half the solution has gone through. Let stand for about 30 min and than turn machine on again. Flush twice with full pot of clean water and you will see that is will improve your time
Posted on Jun 21, 2008
Talea giro descale already done but red led of descale has not gone
I was told by tech that if you hold the water button in for a few seconds then this resets. It depends on what kind of water you use too. If you use filtered or spring water then you don't need to descale it as often and you can override this by above method. Hope that helps.
Aug 28, 2012 | Saeco Talea Giro Espresso Machine
What does it need when the window reads "descale"
when the display says "Descale" it means that the machine wants to run a cleaning program to remove any limescale build up on the heating elements.
you will need to put a descaleing solution in to the main water tank and run the descale program
follow the instructions in the manual to descale
Note (useing anything but the recommended descaler may void the warranty)
Feb 18, 2011 | Keurig B70 Coffee Maker
When I turn on my Royal plus, the digital screen says Decalcify. What does this mean and how do I do it?
HI
To automatically descale your machine, press the scoop or menu button and hold it down until you enter the menu. Use the arrows to scroll up until you come to Descale. Press enter and the machine will enter the mode to descale your machine. The process takes about 45 minutes. You don't have to do a thing except mix a full water tank with descaling solution and have a container under the steam wand when your start. If you have a cappuccinonatori on your machine you will need two containers. To start the descaling process, simply turn the steam knob. When the process is over your machine will say, "Descale finished". Remove your water tank and rinse it out. Refill it with fresh water. Replace on the machine and start the descaling process over again to rinse your machine. Go back into your menu and scroll up or down 1 to "Signal Descale" and enter. Choose "Yes" and push enter so the machine will tell you when you need to descale again.
Feb 09, 2011 | Saeco Royal Digital Plus Coffee...
Hello , I got a present of a Saeco Royal Professional without an instruction booklet . The machine tells me it needs a descale . Can you please advise as to how . Many thanks , Sean Kavanagh
Hi
Auto descale: To automatically descale your machine, press the scoop button and hold it down until you enter the menu. Use the arrows on the left to scroll down until you come to "Descale". Press enter and the machine will enter the mode to descale your machine. The process takes about 45 minutes. You don't have to do a thing except mix a full water tank with descaling solution and have a container under the steam wand when your start. If you have a cappuccinonatori on your machine you will need two containers. To start the descaling process simply turn the steam knob. When the process is over your machine will say "descale finished". Remove your water tank and rinse it out. Refill it with fresh water. Replace on the machine and close the steam knob then open it again to rinse your machine. When its done exit the descale mode and go to the "Reset descale" just under it and enter. Choose "Yes" and push the enter button to accept. It will tell you when it needs to be descaled again.
If you want to make your machine last a long time, go to the water hardness in the menu and change your water hardness to the #4 and always push the enter button if you want to make your changes permanent. If you don't, no changes will be made and it will still be the same when you exit.
Jan 06, 2011 | Saeco Royal Professional Espresso Machine
Delonghi magnifica eam 3200 won't descale
we are encountering some connection problem that's teh reason why our converastion are always in cut.
if you read this let me know here i can help you to solved your problem.
thanks,
Mar 21, 2009 | DeLonghi EAM3500 Espresso Machine/Coffee...
Got an old saeco magic comfort 7/8 years old -
You are correct to descale the machine. I am not sure how "decalcification" is different, but if the message is still coming up, you may need to have some repair work done. There are some sensors inside that can be cleaned manually if a descaling solution doesn't do the trick. You can do some work if you are mechanically inclined.
Jan 20, 2009 | Saeco Magic Comfort Plus Espresso Machine
Descale
that means getting rid of the limescale build up in the machine.
Jun 20, 2008 | KitchenAid KCM514 Coffee Maker
Descale the machine twice!
Brew time
this is not the norm. Sounds like a blockage problem. Descale the machine twice!!!! one after the other. and that should take care of it
Delonghi EAM 6600
You need to descale the machine with descaling solution.
look at following link for instructions
DELONGHI
May 04, 2008 | Saeco Vienna SuperAutomatica Coffee...
Saeco Odea Go Logo
175 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
