Question about InFocus ScreenPlay 4805 Multimedia Projector
Projector problem Our projector wont turn on...the green light blinks, the fan kicks on for a few seconds..I just replaced the bulb..still doing it. Green blinking light...fan for 2 - 3 seconds, fan stops for about 2-3 seconds, fans starts again for 2 -3 seconds, etc.... projector wont turn on. I tried remote...even changed batteries.
  • 2 more comments
  • baeron Jul 31, 2008
    I have the Infocus Screenplay 4805. The projector would not come on so I went to the manuel to see if I could troubleshhot what the problem was. I found the pages that talked about the red blinking light. Mine was blinking twice, which meant reached lamp hours, replace lamp and reset counter. I replaces lamp, and projector still will not turn on. Red light still blinking twice. Help!!
    Baeron
  • Anonymous Mar 12, 2014
    When trying to use our projector, it starts up fine, but shuts off after about a minute and wont power on again for 30 minutes or so. The bulb was replaced about 2 months ago.
  • Anonymous Mar 19, 2014
    the projector was working and then all of a sudden it stopped working. Th epower light does not blink or do anything. i have tried it with a different wire but it still does not turn on.
I generally fix this by re-seating the bulb housing. Take it out and put it back in. Look for cracking at the base of the bulb on the mirrored surface. It could be a barely functioning bulb that isn't busted, but can't initialize. I would take it to a shop that has the same bub type in a housing and make a quick switch.
Posted on Jul 28, 2008
Why would my projector refuse to start with a seemingly intact light bulb?
If you only have 300 hours on it it should still be under warranty. Before doing something to void that I would check with Optoma techs.
Jul 23, 2014 | Optoma HD20 DLP Projector
Why does my Sanyo PLC-XU51 projector power light blink red?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
May 25, 2014 | Sanyo Office Equipment & Supplies
Sanyo plc xu115 new bulb wont fire. power light turns green at first but after a few seconds it turns flashing red. the old bulb exploded on this projector.
Could be a burnt capacitor on the circuit board. Replace capacitor if you can determine which one it is. There are only a few.
Apr 20, 2011 | Sanyo PLC-XU115 Projector
Optoma hd65 projector new bulb wont turn on...cant reset timer!
I think it's a lamp driver issue from what I've seen others have gone through. I also read that if you go through the sequence of unplugging, plug back in, wait 20 seconds and try to turn on, multiple times, it will finally kick on and work. I just got mine to turn back on by doing this and waiting through the fan cycling without the light turning on. After the 4th sequence the light flickered. After the 7th sequence it finally turned on and is working. Now I can watch the Super Bowl and will look into replacing soon.
Jan 31, 2010 | Optoma HD65 DLP Projector
I turn on the 4805,green led blinks & bulb does not come on?
After a few minuets does the green blinking light turn to a red blinking light?
If so the problem is the lamp did not strike.Either the lamp has failed (most likely) or there is a problem with the power supply (less likely)
Feb 12, 2009 | InFocus ScreenPlay 4805 Multimedia...
Blinking Light on Mitsubishi SL4SU Projector
To jmatthews
Both power light and status light a solid red with no response to any buttons indicates the bulb timer has expired. You need to reset the timer by pressing and holding the left arrow key, the right arrow key and the power button all at the same time for a few seconds.
If there are no problems, the projector will fire up, but you must replace the bulb as it will fail soon and perhaps explode when it does.
Take care
Oct 28, 2008 | Mitsubishi SL4SU ColorView Multimedia...
Lamp will not come on
try pressing and holding the enter button on the projector for about 30 seconds - this resets it. It worked for me!!
Feb 10, 2008 | NEC VT460 Multimedia Projector
InFocus ScreenPlay 4805 Multimedia Projector Logo
481 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
