Question about Insignia LCDTV26 26 in. Television
Insignia 26" lcd tv
Powers off after twenty minutes by itself
  • meeeeeeeee Jun 24, 2008
    checked polarity, it was correct. correct voltage also, tred a different outlet same results. took to office tried it there same results.:{
    Sergeant:
  • 260 Answers
This sounds like a safety feature built into the television. It may be trying to protect itself from an unsafe electrical source. The more expensive the equipment, the more sophisticated the power supply that converts the power from your outlet into your television. There could have been a lightning strike that has disabled the tv. Or it could be a faulty outlet.
Before called for a technician, I recommend plugging the television into a different outlet. use a good quality extension cord if necessary. You may find that your outlet is not polarized correctly.
If you want to look into this issue further please try our premium service or use our online listings for a technician near your.
Thanks and good luck. :)
Posted on Jun 20, 2008
My Insignia TV model: ns-lcd26-09 starts flickering intermittently for a while after watching, quits after 20 minutes, then starts again.
Definitely sounds like a bad power supply. Especially if it's making any buzzing/hissing noises while it's flickering.
All Insignia products carry a two year manufactures warranty, which Best Buy will gladly service for you. If you're out of warranty, here is a link to a replacement part:
http://stores.orlandopc.net/-strse-3824/INSIGNIA-POWER-SUPPLY-UNIT/Detail.bok
Aug 27, 2011 | Insignia NS-LCD26-09 26 in. HD-Ready LCD...
Technika 26'' lcd tv long time to warm up
the reason maybe a bad capacitor that is taking time to charge up to the nominal voltage. check for capacitors (electrolytic) in the power section (probably smps). it may appear bulgy than the others.
May 31, 2010 | Televison & Video
Insignia IS 26 Inch Lcd TV Problem no signal VGA Input
Most likely this is a resolution issue. Set your computer's output resolution to one that is compatible with the TV, usually 1366x768 for a 720p Insignia TV. More info can be found here.
Mar 05, 2010 | LG 26LG30 26 in. LCD TV
My 26" Insignia LCD TV will not power on.. the little light on the bottom right corner will change from red to blue but the screen itself will not make any change.
The problem can be in the backlight inverter board or the power supply that supplys the power to the inverter board is bad. The indicator is on because the 5v standby power supply is still working at least.
Nov 01, 2009 | Insignia LCDTV26 26 in. Television
26 inch protron lcd will turnoff in 40 min byitself
Could be overheating or the power supply capacitors are crapping out which is commom especially in newer tv's
Sep 11, 2009 | Protron PLTV-26 26 in. HD-Ready LCD...
Insignia tv 26 LCD tv/dvd combo problem
I have an Insignia 26' LCD TV with a built in DVD player and all I get on the screen is a box that says No Database.
Jul 26, 2008 | Insignia LCDTV26 26 in. Television
Turns off between 1 hour and 5 hours
sounds defective, but try the Insignia help line, in case you've accidentally got it on a timer setting:  Call 877-467-4289
May 12, 2008 | Insignia LCDTV26 26 in. Television
Controls Don't Work
I have the same problem as the rest of everyone, too bad Insignia hasn't issued any help anyone that owns their TV over one year. I guess they don't make TV's to last more than 1 year anymore for your $$. I couldn't believe Best Buy continues to sell this disposable HD LCD flat screen when I saw them on the shelf still today.
Anyways, if someone find out that the cost is reasonble to fix this, please relay, thanks "burnt" consumer
Apr 28, 2007 | Insignia LCDTV26 26 in. Television
Insignia LCDTV26 26 in. Television Logo
59 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
