I have a Carver C-1 Preamp and M 1.5t amp. When I adjust the volume, I get some static. Can you tell me what the problem is.
Spray volume controls with static cleaner
Posted on Aug 29, 2008
How to hook up a Marantz AV 8003 pre amp to a carver TFM 45 amplifier
Marantz preamp out, to Carver amp(or line in). Have you tried this and had problems?
Jan 08, 2015 | Marantz Audio Players & Recorders
Carver TFM 35 amp what is the best way to hook it to a Marantz AV8003 pre app
No. You should use the line(or preamp output) to the Carver input. The only way you could use the tape output is if the Carver has input volume controls.
Dec 21, 2014 | Marantz Audio Players & Recorders
Sub static at low volume fine at high volume
Prob always there just can't hear it at higher volumes. Check the grounds of the amps an the Caps if you have them. Then check the preamp wires from the head unti to the amp. Keep it as shielded from power wires as you can. Some times tying a ground from the amp back to the head unit ground can fix a hiss or static
Dec 25, 2013 | Kicker 02S10L74 Car Subwoofer
Can I run two stereo amps from same preamp?
yes, and do tell, what speakers are you powering with these amps?
Jul 09, 2013 | Bose 901 EQ1915 Home Equalizer
My turntable connect to Carver Preamp, I bought a
If you can hear music with the volume up, but like it was turned down low (from the power amp), then yes there is something up with it. If it's the same on both left & right channels, then it's something common to both. For instance the power supply, or an IC that has both channels going in it.
If however the power amp does produce sound normally with another device, then either the turntable has a fault, or the pre-amp has, perhaps on the pre-amp inside it for the cartridge.
Dec 16, 2009 | Yamaha P-2500 Amplifier
Carver CT-28v Tuner preamp - Has a hum/buzz (soundls like a ground loop) that is heard as soon as the unit is turned on. Does not increase with volume, just stays the same and is continuous. Changing...
Reverse the polarity of the AC plug and try it. Is there a headphone jack on the preamp? Try headphones with the preamp standalone without the amp attached.
Are you sure the preamp is the problem? I assume you also have an amp or you wouldn't hear anything. Power up the amp with nothing but speakers attached. Hum??? It's in the amp. No Hum? Attach just the preamp with no external components. Hum now? It's the CT-28. Turn it off an exercise every switch and knob throughout its range numerous times. Try again. Still humming? Manipulate source selections, Tape Monitor, everything.
Nov 19, 2009 | Audio Players & Recorders
Extreme distortion/static in music.
you might have blown your speakers. Thats what it sounds like, if it got loud with a lot of low-end then it got all staticy and distorted, you fried teh speakers.
May 27, 2009 | Phase Linear PLC 400
Connecting NAD 314 Receiver\ preamp to Carver M-500t to speakers
Dear Tim,
Yes, you can connect your NAD as a preamp to the Carver power Amp.
Connect the NAD's pre-out to the input of the Carver Power Amp. You can then connect the Klipsch speaker to the Carver. Set the gain control on the NAD.
Now you should be able to control all the input and the main volume control from the NAD.
Mar 12, 2009 | Onkyo TX-SR803 Receiver
Carver stereo amp will only play
That should be normal. The main inputs usually go directly to the power amp. If you want volume control, put a mixer with faders beween them... Radio Shack used to have some inexpensive mixers.
Mar 09, 2009 | Carver PM950 Amplifier
405 people viewed this question
