Question about Acer Aspire One PC Notebook
How do i connect dial up connection - Acer Aspire One PC Notebook
    Scholar:
  • 83 Answers
If you want to connect your pc/laptop with a dial-up connection you need to make a dial up connection but you didn't mention your operating system.But no problem just go to control panel and there you find network connections in it you notice a create a new connection then new wizard will open press next then select which ever connection you want make then it ask how to connect to internet in it choose set up connection manually press next then choose appropriate option then its done. Your connection is just made up try to connect and you internet will start working.
Posted on Nov 19, 2010
SOURCE:
When i connect to laptop i get connection terminated with error code 734
If you try to establish a Point-to-Point Protocol (PPP) dial-up connection, you may receive the following error message: Error 734: The PPP link control protocol was terminated. As a result, you cannot establish a dial-up connection.
This issue may occur if either of the following conditions are true:
  • Multi-link negotiation is turned on for the single-link connection.
    -or-
  • The dial-up connection security configuration is incorrectly configured to use the Require secured password setting.
To resolve this issue:
  1. Click Start, point to Settings, and then click Network and Dial-up Connections.
    NOTE: For Windows Server 2003, click Start, point to Control Panel, and then point to Network Connections.
  2. Right-click the appropriate dial-up networking connection, and then click Properties.
  3. Click the Networking tab, and then click Settings.
  4. Click to clear the Negotiate multi-link for single link connections check box (if it is selected).
  5. Click OK, and then click OK.
  6. Double-click the connection, and then click Dial.
    • If this procedure resolves the issue and you can establish a dial-up connection, you do not have to follow the remaining steps in this article.
    • If this does not resolve the issue and you cannot establish a dial-up connection, go to step 7 to continue to troubleshoot this issue.
  7. Right-click the connection, and then click Properties.
  8. Click the Security tab.
  9. Under Security options, click Allow unsecured password in the Validate my identity as follows box, and then click OK.
  10. Double-click the connection, and then click Dial to verify that you can establish a dial-up connection.
May 11, 2011 | Computers & Internet
My sierra modem won't connect. it shows - Error 734: the PPP Link Control Protocol was terminated
hi there.
    -or-
To resolve this issue kindly follow the below steps and do not skip any of them:
Dec 19, 2010 | AT&T Computers & Internet
When i dialled up inter net then error 734 was coming and say subscribe packet data first now ???
  1. Click start, settings and the network and dial up connections
  2. Right-click the appropriate dial-up networking connection, and then click properties
  3. Click networking Tab then settings.
  4. Click to clear the Negotiate multi-link for single link connections check box (if it is selected, it must be uncheck).
  5. Click ok, then ok.
  7. Right-click the dial up connection, and then click properties.
  8. Click security tab.
  9. Under security options, click allow unsecured password in the validate my identity as follows box, then click ok.
  10. Double-click the connection, and then click dial to verify that you can establish a dial-up connection.
Jul 23, 2010 | Computers & Internet
When i connect to internet there is an error code 734
Feb 27, 2010 | Nokia E51 Smartphone
Dial up connection ok but wireless will not open explorer Dell computer 2000XP Eircom connection
The dial up connection may be corrupt
delete the dial all the existing dial up connections from
internet explorer>Tools>internet options>Connections>
remove existing dial connections in Dial up and virtual private network settings
add a new dial up conection and set it up again
It show be up and running
Feb 11, 2010 | Dell Dimension 2400 PC Desktop
Pvc selection keeps changing to dial up mode
  • delete the dial up connection on the internet option
  • click tools-internet options on the internet explorer - click connections tab, delete all dial up on the box, and select never dial a connection
Aug 04, 2009 | Siemens SpeedStream 2624 Router...
My wifes laptop is trying to use DUN instead of network cable
Open up Internet Options (from the Tools menu in IE or right-clicking the desktop icon and selecting Properties, or through the Control Panel). On the Connections tab, select 'Never dial a connection.' When you want to connect to your ISP you will be required to manually start the dial-up connection.
Apr 14, 2009 | Computers & Internet
Having Limited Connectivity On My Vista Laptop When I Use Dial Up Connection
It may be the speed of your connection....dial up...
Try connecting somewhere else and see what you get...
If that does not work, check your dial up settings....
Jul 20, 2008 | HP Pavilion dv6000z Notebook
Wizard wont create a dialup connection using vista i have updated the modem drivers and the modem is in my device manager
Hi
Follow these instructions to create a dial-up connection on your computer. Then you can get on the Internet to receive/send email and browse the web.
From the Start menu, click on Connect To
Click on Set up a connection or network
Click Set up a dial-up connection
Click Next. Enter the required information for the connection:
Dial-up phone number: 513-520-1135
User Name: (the NCF accountID that was assigned to you)
Password: (the password chosen by you when you registered)
Remember this password(check this box)
Connection Name:NCF Internet - Libertel
Allow other people to see this connection: Check this if you want this connection for all users on your computer (recommended)
Note: if you have Call Waiting, temporarily disable it for the duration of your NCF connection byusing *70,,613-520-1135 as the phone number.
*The NCF dialup phone number is in area code 613 in Ottawa. Please note that long distance charges may apply to modems outside of your local calling area.
Click Connect to create and save this connection.
You have successfully created a Dial-up Connection in Windows Vista.
To connect to the NCF using the connection you have now created, follow these steps:
  1. Click on Start, and then Connect To.
  2. Left click on the NCF Internet - Libertel dialup-up connection and select Connect at the bottom.
  3. The Dial-up windows will come up. Simply click on Dial and your computer will connect to the NCF
Jyothish
Jul 18, 2008 | Computers & Internet
Acer Aspire One  PC Notebook Logo
164 people viewed this question
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
