Question about SanDisk Sansa m250 MP3 Player
Sandisk sansa m250 not working properly
On boot my player says "finalizing update" for a few seconds and then turns off. It also won't be recognized by my computer.
Here is the story that led to that. I was copying music into my player by copy pasting files as if it's a mass storage usb device, rather than going through media player. When I was done I unplugged it from the usb, turned it on, and listened to my new songs. While it was playing one of the songs (after having successfully played several), it said "error" and died. Ever since, it only says "initializing" when you turn it on, then "finalizing update" and then dies. Is there something I can do to fix it?
  • gobstopper Jun 22, 2008
    Unfortunately, I cannot set my player to MSC mode. It doesn't boot up to let me make any change to the settings. All it does when I turn it on is say:"initializing", then "finalizing update" and then it dies.
  • Anonymous Jun 27, 2008
    no start
Try upgrading the firmware as follows:
Before installing the player must be in MSC (Mass Storage Class) mode to run the firmware.All files will be deleted. Backup your files.
(To switch modes, Go to Menu > Settings > USB > The two options are MSC and AUTO DETECT (MTP) : select MSC)
Installation Instructions:
1. Download and run firmware from:
2. Follow instructions in installation.
Hope that helps!
Posted on Jun 21, 2008
  • eelda Jun 24, 2008
    ah i had the same problem - if you plug in the mp3 player *while* holding down the power button, it will force it to connect in MSC mode (it should say on the player that it is connected in MSC mode if it works).
My Sansa M250 is only 1 month old and won't recognize Music folders now when I plug it in. My PC does recognize the device but now it only shows Audible, Config and Record. Before it showed playlist,...
reset the device to factory defaults thats it....
check your usb ports are working properly in not i recommend to re instal the usb device drivers also
Jun 27, 2011 | SanDisk Sansa m250 MP3 Player
SansaDisk Sansa m250 (2GB) "Finalizing update"
You need to go to the Sandisk support site and down load the Updater program. Run the updater on your player. This in a way reinstalls the software on the player kind of like reinstalling the operating system. [
Jul 20, 2010 | SanDisk Sansa m250 MP3 Player
Stuck on finalizing update and computer wont recognize.
yet i don´t know much about your mp3 ..
is there any reset "button" if so try that
May 25, 2009 | SanDisk Sansa m250 MP3 Player
What Can I do if My Mp3 sansa m250 froze
This is an ongoing issue and its better that you called Sandisk about this to have it replaced under warranty.
Jun 17, 2008 | SanDisk Sansa m250 MP3 Player
Sir My sandisc has been forzen saying its Finalizing update
the software may have got corrupted.
better get it reprogrammed to bring it back to working condition
Finalizing updat
Firmware upgrade needed to solve your problem
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out:
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Apr 25, 2008 | SanDisk Sansa m250 MP3 Player
My m250 player won't work when I turn it on.
Try holding the power button down for at least 10 to 15 seconds. That should turn it off. Turn it back on. If this doesn't work, try taking the battery out for a few seconds. If that doesnt work i will recommend that you update the firmware on your device..
To update the firmware follow the link below
Should you need additional information you can contact sandisk..
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Apr 03, 2008 | SanDisk Sansa m240 MP3 Player
Sansa - sandisk m250 troubleshooting
Try doing a hard reset on a Sansa m250:
  1. Turn off the Sansa. Just pull the battery out for a second and then reinstall the battery without pushing any further buttons.
  2. Plug the Sansa into a computer, and open "My Documents" in the computer.
  3. Open the Sansa file as if it were a drive, then go to the "MUSIC Specific storage" file.
  4. Right click the "MUSIC Specific storage" file, and press "Format."
This should hard reset the Sansa m250. This solution has worked for me.
I do not know if this will work on other Sansa m200 type .mp3 players.
Dec 20, 2007 | SanDisk Sansa m250 MP3 Player
Mine froze in play position, but no sound.
Here's what worked for me. Mine is the Sansa M250
1)Plugged the player into the PC and removed all the MP3s
2)Downloaded update program from Sansa link below
3) Install the program
4) Plug the Sansa into your PC.
5) Program automatically starts and allows you to check for software update. Do so and let the program update your player.
Fixed my freeze problem. Player working perfectly now.
Hope this helps.
Dec 05, 2007 | SanDisk Sansa m250 MP3 Player
Sansa m250 freeses on power up
throw it against the wall because sandisk is aware of this problem and does nothing about it... they should replace them for free but they don't... race condition in that firmware screws the player up...
Jun 17, 2007 | SanDisk Sansa m250 MP3 Player
SanDisk Sansa m250 MP3 Player Logo
140 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
