Question about Maytag M6Q10F2A Air Conditioner
Replacement Filters My filter is cracked and extremely dirty. Where can I purchase a new filter?
  • 40 Answers
Home Depot. If it is a special filter go straight to the manufacturer
Posted on Jun 20, 2008
My S7580 vacuum cleaner is very noisy
Hey, this is Jeremy with Crucial Vacuum,
To remedy a noisy vacuum cleaner there are typically four main areas to check to restore proper functionality. By following the steps below it should be back to normal in no time!
1. Dirty Filters- If your vacuum has suddenly become very loud, check the filter, as it may be dirty. When the filters on a vacuum become excessively dirty, the vacuum may start running louder because it is working hard to create suction. If your filters are dirty, your vacuum is likely not suctioning appropriately, either. To fix this problem, simply remove the filters in your vacuum, rid them of the dust and debris and rinse them out with warm water.
2. Clog- Clogs are often the reason as to why your vacuum cleaner is being extra noisy. While vacuuming, something may get sucked up such as a button or a small toy, for example. Additionally, the clog may be making the vacuum work harder. Check all tubes and hoses in the vacuum to make sure there are no obstructions.
3. Broken Brush Bearing- When a brush bearing breaks, the vacuum cleaner gets loud and starts to vibrate. To remedy the problem, remove the brush and replace it
4. Broken Fan- The fan in the motor of your vacuum may be broken, causing the vacuum to run louder than normal. When dirt runs through the motor of the vacuum, it can collect on the fan, causing it to break. If the fan in your vacuum motor is broken, it will need to be replaced. This is a slightly more tricky process and may require you to bring in your vacuum to a repair shop to have the part replaced.
You can purchase replacement parts for Miele direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/miele.html?limit=60
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Jun 09, 2015 | Miele Vacuums
Which replacement filters are best
As this is a near new vehicle i suggest sticking with the Genuine Lexus filters, the only exception would be the Air filter, you can buy an aftermarket K&N type which will allow your motor to breath easier and helps with power and economy.
Mar 09, 2012 | 2011 Lexus LX 570
Engine is pumping oil back through the air filter unto the ground Generac GP 9000 with OHU1 Low Pressure shutoff.
I am thinking that your air filter is extremely dirty. The engine creates a suction and if the air filter is so dirty that air cannot pass through it, then it will start to **** from the engine block and oil will come into the manifold and drip out through the filter and onto the ground. Have you tried to start and run the engine without the filter (in a clean location only and for a short time) to see if the problem still exists without the air filter? This will determine if the engine is pumping the oil out. If it runs fine without excessive oil being drawn into the manifold, then I would purchase a new air filter (do not reuse these filters) and try it out.
Jan 31, 2011 | Generac 5626 GP Series GP7000E 8,750 Watt...
When should 2005 Pontiac Sunfire air filters & fuel filters be changed?
the air filter should be changed when visibly dirty, and I recommend fuel filter replacement every 30000 miles depending on if your car even has one. starting in 2005 gm deleted alot of its fuel filters
Feb 16, 2010 | 2005 Pontiac Sunfire
Vacuum turns off after short amount of use
Check the vacuum for a clog somewhere, check any filters to see if they are dirty (i understand filters are going to be dirty after use, but i mean extreme dirty in this case), these are common things to look for when you have this problem
Aug 17, 2009 | Electrolux Guardian Bagged Canister Vacuum
Dirty range hood filters
You can purchase grease filters for only a few pounds from many super markets, these can be cut to size to suit your hood. Changing charcoals filters is more expensive but should be done every couple of years depending on your usage.
Mar 18, 2009 | Kitchen Ranges
Not so quiet anymore
If the filters was very dirty, you might have got some dirt in to the motor, best to have it checked
Dec 17, 2017 | Bissell Upright Vacuum - The Pet Hair...
Smell Coming From Intertherm Furnace
It could be several things.
The most alarming being a cracked heat exchanger allowing the exhaust fumes to enter the living space.
Exhaust fumes that contain carbon monoxide.
I HIGHLY RECCOMEND that you purchase carbon monoxide detectors, and/or check the batteries in any you might already have.
Carbon monoxide can be deadly at high concentrations.
It could be burning wires, but would smell like burnt rubber.
It could be mold/mildew but would smell musty like dirty socks.
It could be a build up of dust oil etc on the heat exchanger, but that is usually only smelled when it is started up for the first time in months.
Make sure the filters are clean. Dirty filters can cause overheating of the heat exchanger and sometimes cause smells.
This is one of those times I will recommend you have a professional look at your unit.
Specifically the heat exchanger to look for cracks.
A pro will know where to look, where the usual stress points are etc.
Dec 10, 2008 | Kitchen Appliances - Others
Where do I purchase replacement charcoal water filters for my coffee maker?
Cuisinart DGB-600 replacement charcoal water filters is Cuisinart DCC-RWF 6 pack charcoal water filters, 12 filters.
Oct 17, 2008 | Cuisinart DGB-600 Coffee Maker
Maytag M6Q10F2A Air Conditioner Logo
76 people viewed this question
Top Maytag Heating & Cooling Experts
gbob59
Bill Long
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
