Question about KitchenAid KCM514 Coffee Maker
Brew time My Kitchenaid kCM514OB seems to be brewing very slow. what is the normal time to brew 14cups. MIne takes like 30 to 40min. I don't remember it being this slow befor. I just got it back like a wk ago and it seemed it brewed alot faster. But we were only brewing 6-12 cups. Could the pump be going out? or is this the norm for these coffee makers? Thanx Tammy
  • Tammy Gray Jun 20, 2008
    Ok i am not sure what you mean by descale. Can you explain to me what that is and what it is i have to do to do that?
    thanx,
    Tammy
  • 487 Answers
This is not the norm. Sounds like a blockage problem. Descale the machine twice!!!! one after the other. and that should take care of it
Posted on Jun 20, 2008
  • eric bosman
    eric bosman Jun 21, 2008
    that means getting rid of the limescale build up in the machine.
    When the limescale becomes to much the machine slows dow.
    buy a descaling solution at your local convenience store or grocery store. Use it as adviced on the bottle but do this twice in a row because a 30-40 minute brew means a lot of blockage. When you do it the second time turn the machine off after half the solution has gone through. Let stand for about 30 min and than turn machine on again. Flush twice with full pot of clean water and you will see that is will improve your time.
My brew station leaks water all over the counter top before it is brewed.
Mine Too! So frustrating. I have to take out the coffee filter, then remove the piece that it sets in. Make sure and clean the spring and the hole in the bottom. This seems to cure the problem until the next time. It seems to get plugged up quickly. I have learned to rinse it out every time I make coffee.
Feb 12, 2015 | Hamilton Beach Brew Station 12 Cup 48465
Tip
My Italia, Classic, Palazzo, has a slow drip into my cup (Brewing)
<span>If you make a pre-ground shot but don't put any coffee in it, and it does the same thing you have a blockage in the brew head.<br />If it run normally, your grind is to fine. Turn the grinder knob to a larger number. It takes 3 times to change to the new grind.<br />If it still dribbles, remove the brew unit (behind the <a href="/#"><span>door</span></a>)<br />Holding the handle, the top left side is the brew head. There is an outlet pipe that exits the front side towards the door with a rubber tip. 2 or 3 screws hold it to the top. Remove the screws while holding the manifold. Once they are removed, lift the l assembly off (becareful, there is a spring and inside a steel ball (don't loose it or your out of luck). Turn the brew unit upside down while holding the brew head in your other hand and the steel ball should fall out. If it doesn't come out put a towel down and tap the brew unit on the towel. This should force it out.<br />Now remove the brew screen, by holding the screen with your finger and twisting the thumbscrew (remember thumbscrew, DON'T use the key to <a href="/#"><span>install</span></a> the screen, use your fingers.....<br />Once the screen is out look at where the screen was. There are 2 holes. 1 big one in the center and a small one to the side.<br />Now use air to blow back through the opening where the steel ball was to clear the opening. Once its open, clean then reassemble. Brew unit on towel right side up. Drop the steel ball in first. Then the spring.<br />Then place the manifold on top of that with the pipe towards the door. Insert your screws (I turn them backwards a little with a little downward pressure until they feel like they drop into the threads. They should turn down easily, if not back them up a little more ( we are trying to find the old threads) and tighten. Install screen, and tighten with your fingers. The screen just needs to be flush with the bottom of the brew head.<br />Run another pre-ground without the coffee and rinse it out. Do this once in a while to prevent this.<br /></span>
on May 07, 2011 | Starbucks Saeco Italia Digital Barista...
Gevalia 12 cup coffee maker slow brewing
The pipes are blocked with build up scale or water dirt. You can try to descale the machine by adding in the water half cup of lemon juice and brew it without coffee leave if for 20 min and the clean it by brew it with fresh water these will make a diference then try this again in a week.
May 16, 2012 | Gevalia CM-500 12 Cup Coffee Maker
Slow brewing
The coffee maker has three contributory factors for brewing experiences. First, putting enough water in container prior to brewing is expected to dispense in to coffee capture cup. Second, installing the component parts after inserting coffee leaflets should not hinder brew seepage into the cup. Third, allowing enough time for the brew to dispense is a requisite means to coffee impressions. Furth, coffee leaflets require appropiate numbers inserted at the container area lest the machine takes time to sock and dispense. However, refer to the device user guide for appropiate manufacturers instructures to user as expectations during brewing. Also, refer to the user guide to ascertain any conditions that may be signs of damage preventing fast brewing.
Jan 22, 2011 | Oster HDX23 12-Cup Coffee Maker
We have an Odea Giro in the office. When we got it I remember the coffee tasted amazing. After few months the taste started to decline and after some time we stopped to use it altogether. I wanted to...
you are supposed to go through the "before first use" instructions....which include filling the resevoir with water and brewing only water until its all gone. then start using the machine normally...remembering that the machine takes a few brew cycles to adjust properly to the coffee being used (this assuming this is the giro plus model which has the feature-"aroma something or other...)
also, descaling would help and removing the brew group and rinsing it out...
Nov 23, 2010 | Saeco Odea Giro Plus Coffee Maker
Saeco Majic - My machine is very slow and drips the coffee. What do I do?
If you make a pre-ground shot but don’t put any coffee in it, and it does the same thing you have a blockage in the brew head.
If it run normally, your grind is to fine. Push the grinder lever to a larger number.
If it still dribbles, remove the brew unit (behind the door)
Holding the handle, the top left side is the brew head. There is an outlet pipe that exits the backside towards the machine (looks like an "L" pipe). 2screws hold it to the top. Remove the 2 screws while holding the manifold ("L" pipe assembly). Once they are removed, lift the l assembly off (becareful, there is an O-ring, spring and inside a crystal ball (don’t loose it or your out of luck). Turn the brew unit upside down while holding the brew head in your other hand and the crystal ball should fall out. If it doesn’t come out put a towel down and tap the brew unit on the towel. This should force it out.
Now remove the brew screen, by holding the screen with your finger and twisting the thumbscrew (remember thumbscrew, DON’T use the key to install the screen, use your fingers.....
With the brew unit upside down over the towel insert a paperclip into the small hole and force anything out the other side. I have gotten worms almost a 1" long from this passage. The paper clip has to go from this side to prevent damage to the seat on the other side.
Clean then reassemble. Brew unit on towel right side up. Drop the crystal ball in first. Then the spring small end first on the crystal ball.
Now the O-ring over the spring, then place the manifold on top of that with the pipe towards the machine. Insert your screws (I turn them backwards a little with a little downward pressure until they feel like they drop into the threads. They should turn down easily, if not back them up a little more ( we are trying to find the old threads) and tighten. Install screen, and tighten with your fingers. The screen just needs to be flush with the bottom of the brew head.
Jul 26, 2010 | Saeco Magic De Luxe Espresso Machine
Saeco Spidem Villa brews very slow
Hi
Yep.
Remove the brew unit. Holding the handle, the top left side is the brew head. There is an outlet pipe that exits the front side towards the door (looks like a long "L" pipe). 2screws hold it to the top. Remove the 2 screws while holding the manifold ("L" pipe assembly). Once they are removed, lift the l assembly off (be careful, there is an O-ring, spring and at the end a black rubber disk or crystal ball).
Now remove the brew screen, by holding the screen with your finger and twisting the thumbscrew (remember, thumbscrew), DON’T use the key to install the screen, use your fingers.
Once the screen is out look at where the screen was. There are 2 holes. A big one in the center and a small one to the side.
With the brew unit upside down over the towel, insert a paperclip into the small hole and force anything out the other side. I have gotten worms almost a 1" long from this passage. The paper clip has to go from this side to prevent damage to the seat on the other side.
Now the O-ring over the spring, then place the manifold on top of that with the pipe towards the machine. Insert your screws (I turn them backwards a little with a little downward pressure until they feel like they drop into the threads. They should turn down easily, if not back them up a little more ( we are trying to find the old threads) and tighten. Install screen, and tighten with your fingers. The screen just needs to be flush with the bottom of the brew head. That should do it.
Jul 05, 2010 | Saeco Spidem Villa
My tim hortons coffee maker is not brewing as quickly..s there a wayto clean it
Make a 1/2 pot 50/50 mixture of cold water and white vinegar then run it through the machine in normal brewing fashion. Place a clean filter in the brewing cup to catch the white deposits that are removed. Allow the mixture to cool, then repeat the process several times while using the same filter. Finally, run several pots of fresh water through to work out the taste of the vinegar. Repeat whenever the brewing time seems to be excessive.
Feb 02, 2010 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
My hamilton beach brew stations quits after brewing 2 cups of coffee.... we have to turn it off and turn it back on several times to get the whole pot brewed. help.
You just need to run white vinegar through it. Put white vinegar in the same way you do water (but don't put any coffee grounds in the basket). Run it as many times as it takes to get all the vinegar out, and then run it again three or four times the same way. After it runs normally, run water through it until the vinegar smell is gone.
The cause of the slow brewing is that the water you normally use has some amount of hardness to it, and over time the hard water minerals build up on the heating element inside the machine. The buildup prevents the heating element from heating the water as fast as designed. The vinegar will dissolve the minerals and let the heater work at full capacity again.
If you want to avoid this in the future, just run the white vinegar through it once a month or so even if it's not running slow.
Jan 31, 2010 | Hamilton Beach BrewStation 47224 Coffee...
Hamilton beach brewstation deluxe 47474
Yup I have the same problem as well. Tried the cleaners too. Currently getting the run around from customer service. If they get me a solution Ill post it.
Nov 15, 2006 | Hamilton Beach BrewStation Deluxe 47474...
KitchenAid KCM514 Coffee Maker Logo
623 people viewed this question
Top KitchenAid Coffee Makers & Espresso Machines Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De
Are you a KitchenAid Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
