Question about HP Photosmart 3310 Printer
I have an HP Photosmart 3310 that scans yellow
There is a yellow bar on everything I scan. when I first scan someing in the morning its fine but the yellow line starts and grows with each scan. HELP!! Thank you
  • 2 more comments
  • cejjresale Jun 20, 2008
    Before I spend more money on this I would like to see what the other 5 people think except I can't seem to get past the first reply.
    UGH
  • cejjresale Jun 27, 2008
    I have gotten 3 different what is wrong. Get a new scanner is a good answer but gee I knew that before I came and paid 9.99 for that great advise. will I use this service again? Not likely
    Genius:
  • 1,665 Answers
Have a look for updated drivers at link below
http://www.hp.com/
Posted on Jun 20, 2008
  • 197 Answers
That progressive yellow line, is a clear indication(the other experts are accurate here) that there is a thermal issue with your scanning engine. this is NOT a User friendly change, however.
  • P.Michael D'Acre
    P.Michael D'Acre Jun 20, 2008
    sounds like you have all the info you need.
    Master:
  • 848 Answers
There is some thermal problem in your printer ........
  • gopinath pasupathy Jun 24, 2008
    The problem might be with your print head nozzles. Lines across a printed image are a tell-tale sign of clogged print head nozzles. This usually happens when the printer has not been used for some time. You may try cleaning the nozzles using the procedure given here:http://printerinkcartridgesblog.printcou...
  • HP Master
  • 6,487 Answers
I think it will be better if you take this to a repair center near you because it needs to be repair by aprofessional or have it replace if its still under warranty , sorry if I cannot provide you the exact trouleshooting...
hope that helps...
    Genius:
  • 1,036 Answers
This sounds like a thermal problem with the reader bar. It may need replacing.
Is it along the scan as if there is a fault with reading, or as a full width "blip"
If it is full width, it can be a break in the ribbon cable.
  • 487 Answers
Ok this can be a 2 sided problem.
One your cartridge can be leaking or the photosensitive reader is broken. This is not just a matter of cleaning but this needs to be serviced by a proffesional. Sorry that there is not an easy fix. You might be better off buying a new printer unless you still have warranty
  • eric bosman
    eric bosman Jun 20, 2008
    for about 80 dollars at staples you have a comparable printer/scanner
  • eric bosman
    eric bosman Jun 27, 2008
    please check my respones
    Sergeant:
  • 243 Answers
Most likely if light is not leaking in when you scan. Its a led or led indexing problem. you can still use it for printing but if you need it to scan. but you can buy a comparable HP replacement for about 40 dollars.
  • Nathan Ayers
    Nathan Ayers Jun 21, 2008
    As I have given you what is likely wrong, and also the best economic solution. I hope you will reconsider the rating as you should have at least found it helpful. If you need anything else don't hesitate to ask.
    Thanks again,
    Nate
Can't launch fax with HP solution Center
I'm having the same problem... did you ever fix it?
Jul 26, 2009 | HP Photosmart 3310 Printer
Scanning produces 1/2 page yellow
uninstall the drivers in add remove programs and restart the computer then re install the drivers ignore the new hardware wizard when it pops up close it. then run the cd. it sounds like the driver got corrupted
Jul 18, 2009 | HP Photosmart 3310 All-In-One InkJet...
I can't scan!
Uninstall the driver and re- install again...good luck
Jul 07, 2009 | HP Photosmart 3310 Printer
Can't scan PLEASE HELP!
SOLUTION: Download the latest version (v 7.7.2) of the HP software from the HP website at www.hp.com. Uninstall the previous software and then reinstall the downloaded software. WORKAROUND: Follow the steps below:
  1. Load the slides or negatives in the TMA and place it on the scanner glass.
  2. Open Image Zone and click on Scan Picture to scan everything.
  3. After the scan is completed, change the settings from glass to scan slide/negative from TMA. The unit will scan again and show the four slides or negatives in the preview.
  4. Click on the first picture in the scan preview and make the following changes:
    • change the dust and scratch removal/sharpness to none
    • change the resolution to 72 dpi
  5. Click on the second picture in the scan preview and make the same changes described above.
  6. Click on the third picture and then the fourth picture and make the same changes.
  7. Click Accept . The correctly scanned slide or negative images will be saved in the Gallery.
May 21, 2009 | HP Photosmart 3310 All-In-One InkJet...
HP photosmart 3310
It could be not power to the power supply. Do you have a way of testing it?
Jun 30, 2008 | HP Photosmart 3310 Printer
Here is the yellow line I am getting when i scan.
Yes If it starts small, and grows, it's thermal.
You're not sitting the scanner on anything that heats up are you?
It may also be a component that is generating heat within the scanner - thus warming the bar when it is parked - possibly the stepper motor?
Do you do a lot of scans when you use it? - you may need a different model to cope with the higher load.
Hope this helps you.
Jun 20, 2008 | HP Photosmart 3310 Printer
HP 3310 All in One Printer with Scanner
yeppers..go to HP site, add your model number, and download the larger of the two. should do it nicely.
http://www.hp.com
Also...more self help here
Feb 07, 2008 | HP Photosmart 3310 Printer
HP Photosmart 3310 Printer Logo
145 people viewed this question
Vinaya Kumar...
Vinaya Kumar...
Seeker5211
Seeker5211
