Hi Guys
I have a Panasonic DMR-EX75EB DVD/HDD recorder. It is 17 mths old. When I turn it on it make a 'clunk clunk' noise and a message flashes up on the screen implying that the disc cannot read/copy and says press pwr off to try again - there isn't even a disc in there, the display is showning that there is.
I can't use the DVD player at all. The HDD bit is working fine.
Any ideas
ta
Worz
SOURCE: Playing HD Video
This machine won't play HD-DVD. What it Will do is to play standard discs and upconvert them to your HDMI format...accordianman
SOURCE: DVD player/ recorder problems... PLEASE HELP!!!
I have now had two Panasonic recorders
3 years apart and both have gone down with this same fault.
It's a shame as they are a fantastic recorder, I would have thought Panasonic
would have put this right by now. It now 5 years on since I bought my
first one and it sounds as if they still have the same fault.
Why the hell can't they just fit a standard computer dvd drive that’s cheap to
replace, and not this abortion they fit.
I was looking on E-bay for Panasonic recorders that where faulty and found
around twenty.
ALL WITH THE SAME FAULT
"DVD drive faulty"
I’m now looking for a new one but don’t know what to do as I
have a ton of discs that need to be finalized, may just forget about them and
keep clear of Panasonic in future.
SOURCE: My DMR EX75EB it fails
This is one of several error codes generated by the main microprocessor IC which are
tripped by corruption, preventing proper operation and which may require the
processor to be reset (where practical) or replaced.
The U81 and U80 codes don't
mean anything in particular because the corruption error could be caused by a number of different reasons. It does not point to any specific
one fault. This is where the confusion sets in as to the origin of the
'error code' in any device.
U81 means (in technical terms) 'microprocessor communication malfunction' on the universal asynchronous receiver/transmitter' or 'microprocessor feedback information error'.
This is not something the user should undertake to repair
themselves; it should really go to an authorised Panasonic repair centre. The
cost depends on the parts used and the labour, however, it is not
unfixable. You can always get a quote on this and a second opinion, then decide for yourself if it is economical or not.
I posted this 'advice' for this model previously. The DMR-EX75 and DMR-EX85 are prone to U81 - which is a common error code.
Testimonial: "Many thanks for your input, after speaking to Panasonic, you are correct, they tell me it would cost approx £100 to repair so its a bin job:-("
SOURCE: Panasonic DVD Recorder Model NO DMR-EX75EB/DMR EX85EB
Go to www.partsourceplus.com they have a wide selection of original remotes.
same problem...display reads "no disc" or unrecordable disc message comes up when i try to program..."no disc " msg. comes up when i put in my newest recorded dvd! I also hear the clunk clunk noise..worked fine for about a year, then ka plooey! vcr works fine.
trying to format disc come up with error message can't formt disc now thinks has dvd still in disc drive & makes a clunking noise when switched on please help
I too have the same problem. It occurred after copying to disc from HDD. Message came up that "part of the last recording may be lost due to scratches, dirt or quality of disc". Since then dvd player thinks there is a disc in the tray and tries to read the disc with message "no read" resulting. DVD symbol also appears in display. Also first message above still occasionally appears after 2 weeks. I have tried a lens cleaner, but of course it can't read the disc. All other functions work. I have had the Panasonic recorder for 27 months. Much appreciate it someone has the answer.
