Question about Maytag SkyBox MBV1976A Beverage Dispenser
Skybox will not get cold.compresser comes on and goes right back off
Skybox vending fridge
IM HAVING A PROBLEM WITH MY SKYBOX MODEL#MBV1976AAB, I HAVE HAD THIS UNIT FOR ABOUT 3.5 - 4 YEARS AND NEVER HAVE I HAD A PROBLEM I LOVE IT. LASTNIGHT I FILLED UP THE MACHINE WITH ALL OF OUR FAVORITE BEVERAGES I WOKE THIS MORNING TO FIND THAT IT ISN'T GETTING COLD IN FACT YOUCAN HEAR THE UNIT ON BUT NOTHING IS GETTING COLD. PLEASE TELL ME WHAT CAN I DO I HAVE SPENT A LOT OF MONEY FOR THIS PURCHASE NOT TO HAVE IT DIE ON ME IN SUCH A SHORT WHILE.PLEASE E-MAIL ME AT: ALYSIA.FITZ@YAHOO.COM
Posted on Jan 13, 2009
To solve the Maytag Skybox Cooling Problem you need the "Refrigerator Relay & Overload - 4387835" that can be found at: appliancesone.com (http://store.appliancezone.com/servlet/-strse-54954/Compressors-Relays-%26-And/Detail).
This relay/overload is a Whirlpool and yes different then what is in the Maytag skybox, but it will work and there is no other option.
First take off the old one. Then put on the new one. . .its similar looking but different.
You have to take apart the old round looking piece to get the wire off and put it on the new thin rectangular piece and connect it to the top prong
And the other small "box" looking piece connects to the bottom two prongs with similar connections to the old one
Maytag skybox not cooling need name of place and parts number for serial 10170778EJ. Model MVB1976AAB
before replacing parts. unplug it and from back and under neath get all the dust out,best to blow air in there to remove dust than plug it back in and leave it on number 3 setting for 6 to 8 hours than if cold you can adjust the settings.
or part location is at www.maytage.com/skybox parts
Good Luck Im pretty sure you won't need to buy part's after air cleaning
Apr 08, 2010 | Maytag SkyBox MBV1976A Beverage Dispenser
Compressor runs constantly, fridge cools, but not as cold as new
If unit is running constantly, and not nearly as cold as it used to be, most likely a freon leak. Possibly a partially frozen over evap too. If evap is mostly clear except for about 5% of it, most probably a freon leak. Changing controls will probably not fix anything. Need to look into this a little deeper.
Good Luck and hope this gets it done for you.
May 10, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag MBB1954GES not cold. Fresh food area warm, motor not on. Freezer OK.
Check the freezer fan is running with the door switch pushd in by hand, check the back wall of the freezer for frosting if it's frosty check the defrost system eg defrost element, Defrost termination stat and defrost timer. If the freezers running perfect check the fridge difuser/damper and see if it's open this is the part that opens and closes the vent between the freezer and fridge to allow cold air into the fridge. The Damper is up the top left corner of the fridge. cheers.
Mar 26, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Hi my skybox stop cooling
The SkyBox operates with two individual systems. The dispenser assembly, the LED indicators and the circulating fan operate on a low voltage circuit. The circulating fan runs anytime the SkyBox is plugged in.
The cooling system operates on 120vac. The cold control inside the beverage compartment is an on demand switch that sends 120vac to the compressor when cooling is needed. There are no parts available for the compressor, so if it determined that power is reaching the compressor, the windings are ok, a 3 in1 hard start kit (Supco URCO210) can be installed by a qualified service technician.
Mar 16, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag skybox start relay is bad
you need to change the overload relay ---- there is a company called appliancezone.com
they sell the overload relay unit with all the parts for $26.00
email me back if you cant find it---- put in the model # for the skybox unit and you will see the item
item # 4387835
this is the problem -- if this relay goes bad the compressor will stay on and not supply cold air to the unit ----
Dec 16, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Skybox not cold
Sorry but it sounds like the same thing that happened to mine and my diagnosis by the repair guy was that the compressor is bad. The cost of repair? $400! Maytag only covers the compressor for ONE YEAR!
Nov 11, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Skybox parts
you need the numbers off the compresser to get the BTU of it before that question can be answered. But your right this is a non replacement part (you cant buy it) it may cross but need cooling capacity first
Jul 28, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag SkyBox
For the soda name tags, I pulled logos off the internet and printed them the correct size on 20-pound paper. Different paper gives different translucence, so you might have to experiment to get the right amount of light coming through.
PS: thanks for the part no. on the relay
Apr 21, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag SkyBox MBV1976A Beverage Dispenser Logo
498 people viewed this question
Top Maytag Retail Supplies Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Bailey's...
Bailey's...
Are you a Maytag Retail Supply Expert? Answer questions, earn points and help others
