Question about GE DCVH515EFWW Electric Dryer
Sand in Dryer
My sons swim trunks had sand in the pockets, which got in the dryer. It sounds like there is sand behind the drum. Is there a way to remove front to get the sand out?
SOURCE: lg dryer - front load - making a grinding noise
I also have the same problem as klrlesimmons, exactly as described. Sounds like sand is rubbing as the drum turns, and also sounds out of balance.
Repairmen replaced upper and lower glides and also the plastic bearing but not the entire bearing assembly.
Frigidaire Gallery, Model Number 417.49012890
Posted on Nov 02, 2010
FRANKSFIXIT
  • 72 Answers
SOURCE: Squeeking noise
Here's a possible troubleshooting fix I just sent to someone else that quite possibly has the same problem you have there now.
Hope it helps you out as well, as it is a bit long, but I'll post the whole reply I sent them and you can use whatever parts of it that will work for you.
My name is Frank...
Regarding your possibly broken dryer.
I'm hoping that this info below helps you out even though I know I won't be able to repair/fix your dryer myself personally. Reason why - I'll explain further down.
I've repaired a few gas dryers & washing machines as well in my time. I can honestly say that I'm as close to being an expert as they come - esp when it comes to making repairs on existing dryer parts that can no longer be purchased as they are either obsolete, or way over-priced.
This is what I do for a semi-retired hobby, and sideline self-employed FIX-IT business. Named appropriately - FRANK'S FIX-IT SHOP. It's only an online fix it at present. Keeps me busy instead of being bored to death.
Electric clothes dryers are typically made the same as gas dryers - as to the mechanical drum part. Only thing different in a gas unit is the 110VAC electrical igniter or element, and the gas delivery system that provides the drying heat to the dryer itself.
All else is basically the same...
In an electric clothes dryer all the power comes from the 220VAC source as to the heating element, etc. The mechanical parts are typically the same as that of a gas dryer.
Having said this - the problem with your dryer can only have one of possibly 2 things wrong with it - seeings it's no doubt 220VAC totally electric, unless you actually have gas where you are there, which is rare in Florida these days!
If after you start the drying cycle you quickly open the dryer door, and you notice the drum is actually rotating - until there is the loss of electric power via a safety door switch that kills electric power to the drum motor activity - then there is NOT a problem with a broken drum belt.
If your dryer is older then say 10-15 years, and you really use it alot - then maybe there's a possibility of a broken drum belt (cost is around $10-15 for a new belt part depending on model - usually - and that does not include labor to install it).
Usually you'll hear the motor whining, but no drum 'noise' or movement. Dead giveaway as to a broken belt.
I had replaced 2 belts and 1 IDLER wheel on my own 30+ year old gas Kenmore dryer before selling it, and then picked up a more recent newer model GE washer & gas dryer that someone was just giving away for free. My 30+ year old Kenmore washer had just died on me at the same time is why I upgraded. Can't pass up a great freebie deal like that everyday! Never had to fix anything on my Kenmore washer during the time I owned it - it was GREAT!! I miss it dearly now.....
Though they were both newer GE models I really don't care for GE anything, as I think they are poorly built, as well as is their refrigerator brands as well.
Don't buy GE anything if you don't have to!! You heard it here from me and I know. My GE washer already broke a belt not even being 8-9 years old, and it was hell to replace, and never worked right afterwords as for the water pump part. Very POOR design! Oh well...
The gas dryer works fine, but the lint collector is not anywhere as good as my old Kenmore was. Poor design in my opinion.
I'm looking for another Kenmore or Whirlpool (set) model now, as they are the best. Kenmores are made by Whirlpool btw, just in case you didn't know that. The best in the business!
As to your other possible noise scenario -
The only other weird noise scenario you'll experience if it's a Kenmore dryer is when the drum "spring loaded track IDLER wheel" goes bad. This drum IDLER wheel is located under the drum itself at the back part of the drum and rides in a groove in the drum itself. It also helps to stabilize and counter-balance the drive belt-loaded turning drum that rides on this drum IDLER wheel as it turns. If your dryer does have the rear drum IDLER wheel system, then it just depends on the make and model. Kenmores & Whirlpools are designed this way. Very good design I might add!!
Some, or all GE dryer models may have a rear drum centering bearing assy instead - and in addition to - a front (Support, 3 glide front drum bearing part# 2359 & a Drum front slide bearing part# 2305 times 3 needed). If this/these front support/slide bearing part(s) goes bad usually the "felt duct" will need to be replaced as well. It not only helps to seal and quiet the drum that runs on the Support part, but it also helps to keep clothes from getting in-between the Support C part and helps prevent clothes from getting damaged. If those (3) friction sliders wear out or fall out, and take out or damage the "felt duct" as well, then the noise will be horrendously LOUD.
The front part of the GE drum models usually rides on a separate front panel support assy which can be made of a plastic C shaped device with anti-friction pad strips to help in frictionless rotation of the drum. A cheap but pretty effective design that does away with a front IDLER wheel, or pair of IDLER wheels as it were at the front of the dryer's frame which houses the door assy as well.
Though my Kenmore replacement drum IDLER wheel only cost me around $17 many years ago I see they now are anywhere in the $30+ range. Ouch! If it's the GE rear bearing assy that has gone bad - another Ouch as that part runs around $50+. Just depends on where you are and parts availability.
Most Kenmore/Whirlpool model dryers with the rear spring loaded drum IDLER wheel design do not have a ball bearing design, but rather have a typical cheaper brass bushing design instead, and when the grease lubricant dries out or they become dirty from picking up dirt in the air such as lint from the drum, etc then they begin to SQUEAL or WHINE very loudly.
The longer this goes on like this the hotter the drum IDLER track wheel gets until it melts the "typically" molded plastic housing, and then it really makes a lot of noise, and could actually lend to the drum belt breaking - as due from the added friction & stress from the binding wheel. It can also damage the front "felt duct" material as well. I had to repair mine as best I could as they had n factory replacement part that I knew off.
The only other mechanical parts that could possibly make any squealing type noise would be the electric belt drive motor or the heat blower motor being gas or electric. If the heat blower motor uses a cheaper brass sleeve shaft bushing bearing that would be rare, but could be a noise source as well. The belt drive motor rarely rarely would ever go bad!!
I hope this info helps to narrow down your problem if you are not able to at least open the top up to inspect the dryer yourself. Always unplug the 110VAC power before opening any cover or panel part up though!
That will not only prevent any electrical shock hazard, but will also keep the gas from turning on by mistake - as by solenoid design - if your dryer is gas.
I suspect this is what's wrong with your dryer.
Again - I hope the info helps you out...
Best regards,
Frank
Posted on Mar 05, 2008
IFIXALL
  • 868 Answers
SOURCE: GE,Dryer,dbxr463ed1ww,
It sounds like the belt broke off. Unless you have replaced even just the belt before,you need a experienced repairman, trust me.....
Posted on Jun 03, 2008
TheMobilian
  • 8220 Answers
SOURCE: squeaky dryer drum...felt thing came off how to replace it?
Squeaking is cause by the drum bearing worn out and telling the tale. As it get thinner and thinner it begins to rub against the metal outer casing it is embellished in. To inspect it you must rmove tyhe front and get the drum out. Start by opening the the door and removing the screws holding down the top. Then raise the top and get the screws out thathold the front on. Use the rear acces panel(if applicable) to get the idler loose or access that idler from the front.e24a4b7.jpg
Posted on Jan 13, 2009
  • 163 Answers
SOURCE: Dryer has trouble starting and makes a deformed hum sound
your motor is going bad.
Posted on Mar 08, 2009
Heilsa Pellet Stove Manufacturers Information
pellet stove tp440 Pool & Spa Heaters Questions & Answers ...
www.fixya.com > Forum > Tags > pellet stove tp440
Pool & Spa Heaters pellet stove tp440 questions and answers. ... for a manual orinformation on this stove it is an older stove we just don't know how old. ... heilsa pellet stove model qcps-28000 my pellet stove is smoking how to change ...
General Infrared Sauna Heilsa Sauna Supplier, Find Best ...
www.alibaba.com/general-infrared-sauna-heilsa-sauna-suppliers.html
Suppliers who can match your search. .... Outdoor Spa,Sauna Room,Jacuzzi,Swimming Pool,Sand Filter .... Infrared sauna room,Portable steam sauna,Infraredheater,Pellet stove,Clothes dryer ..... updates on topics such as trending hot products, buying requests and supplier information - sent directly to your email inbox!
Good Quality Far Infrared Sauna Supplier, Find Best Good ...
www.alibaba.com/good-quality-far-infrared-sauna-suppliers.html
Suppliers > .... Outdoor Spa,Sauna Room,Jacuzzi,Swimming Pool,Sand Filter ...Infrared sauna room,Portable steam sauna,Infrared heater,Pellet stove,Clothes dryer ...compare heilsa infrared sauna with good infrared sauna accessories ..... buying requests and supplier information - sent directly to your email inbox!
Jan 06, 2016 | Pool & Spa
Is it posible to get ink stain off dryer drum
Sorry they way to remove a ink stain from the drum (becuase of the heat it's "baked on) is to sand the drum down which will leave raw metal causing the drum to rust
It could be sanded down and repainted but you would need to go to the auto parts store and get some paint for engines since its desiged for high heat
Good luck
Gene
Jul 29, 2011 | Maytag MDE308DAYW Electric Dryer
My dryer is leaving black marks on all my clothes and it sounds like sand or beads are rattling in the drum.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Jul 17, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Kenmore 80 series electric dryer. metalic sound/burning smell
When i put clothers in my dryer it does not move and it make a sound when i push the start buttom
Feb 24, 2010 | Kenmore Dryers
Kenmore Elite He3 dryer..fine on timed but leaves cloths wet auto
find the metal sensors in the drum
scratchem up with sand paper
especially if you wash rugs, sneakers , or anything with acyrlic
Oct 05, 2009 | Kenmore Elite HE4 Electric Dryer
The dryer dispels sand and dirt after each cycle- I think it needs to be cleaned?
do you see marks on your clothing if not the problem may not be with the dryer but the washer. do you live in a sandy area? with kids check the pockets of item before washing generally not a very good chance of dirt or sand coming from the dryer
Aug 19, 2009 | Frigidaire Dryers
Lg dryer - front load - making a grinding noise
Mar 22, 2009 | LG DLE3777 Electric Dryer
Front loading dryer making a'sandy, grinding' sort of sound
possible problem has a dent on top of panel and is grinding on drum and top panel ,, do not put anything on top of dryers ,,,
Nov 08, 2008 | Kenmore Elite HE4 Electric Dryer
Sand from beach in my dryer
Unplug your dryer and remove the lower panel under the door. There a several screws under the bottom edge of the panel that you will need to remove to get the panel off. HINT: if you prop the front feet of the dryer up with a couple of block of wood (like a a piece of 2 x 4) it makes accessing the screws much easier. With the screws removed, the panel will drop down, then off. Remove the blower fan assembly cover (this is where the lint screen inserts into). NOTE: You will need to take the lint screen out BEFORE you remove the blower fan cover. There are as many as three screws holding it in place. The sand is probably caught in the blower fan ducting and is getting kicked up when the fan turns. Vacuum this area out and it should take care of the problem you are having. NOTE: Since you have the panel off, this is also a good time to clean and inspect your dryer interior and ducting. If you have any questions, please post back and let me know. I hope this helps you.
Aug 04, 2008 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
I own a whirlpool gold dryer about 4 years old. I empty the lint catcher frequently. I noticed however, that sand has accumulated inside the dryer, I hear the sound when the dryer starts tumbling. How...
not as hard as it will sound here we go
remove the lint filter
remove the 2 phillips screws at the filter housing top you will see these screws after you have pulled out the lint filter
unplug the dryer
remove the back panel
on the left side is the lint filter housing it is held in place with 4 1/4 inch screws remove them
lift up on the filter housing and pull forward you will find the sand inside the filter housing use a vac to **** it out and reassemble the dryer, no more sand
Apr 26, 2008 | Dryers
GE DCVH515EFWW Electric Dryer Logo
714 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
