Question about Xerox WorkCentre M-24 Color Copier
WorkCener 24 reset to factory defaults
I just took in a WorkCenter 24 and would like to erase everything andreset to factory defaults. I know this question was posted in April but the solution wasn't. I appreciate any help you can give!
Thanks
Vardata
    President:
  • 2,072 Answers
That has to be done with the diagnostics software. That has to be on a laptop computer to access the NVM. Once connected to the machine from the computer, you can reset the NVM and all other settings back to default.
You can try shorting the NVM battery to reset the memory but I would NOT recommend that move .
Posted on Jun 20, 2008
I dot know how to reset my ipad
A factory Reset will wipe all the data stored on your iPad...everything will be restored to factory default, which basically means it will be just as you got it out of the box. It can be done by following these steps:
1.)Start by selecting 'settings'
2.)Than select 'general'
when in general scroll down to bottom of the page to 'Reset' and select it.
3.)Than you have the option to do a two things as far as Resetting your iPad.
a.) 'Reset All Settings' - This will preserve all your data but will restore all factory defaults..
b.) 'Erase All Content and Settings'. This will wipe all data and restore to factory defaults.
If you're giving the iPad to someone else or selling it...choose b.
Apr 12, 2015 | Apple iPad (16 GB) WiFi Tablet PC
How to factory reset a cricket LG-D321 android phone
  1. From the Home screen, tap Apps filedownload.do?fileid=bd_n-1398765054560 > Settings filedownload.do?fileid=bd_n-1398765054561 > General tab filedownload.do?fileid=bd_n-1398765054562 > Backup & reset filedownload.do?fileid=bd_n-1398765054563
  2. Tap Factory data reset to erase all data and restore default settings.
  3. Tap Reset phone > Erase everything to perform a factory reset. Your device will restart when the reset is complete.
Note: This process will erase all data from your phone's internal storage.
Aug 13, 2014 | Cell Phones
How do i format my xperia?
Hi Laila,
To factory reset your phone you will need to do the following:
Press and hold Camera key + volume up key+ power button together
The phone will format itself to factory default, if this does not work then you will need to navigate to:
Setting -> Privacy -> Factory data reset -> Reset phone -> Erase everything.
Please let me know if this helps,
Thanks,
Hunter Quinn
IBM Technician
Jul 15, 2014 | Sony Ericsson Sony Xperia Sola Red, 8gb,...
How do i reset my LG 6200 to factory or so that EVERYTHING gets erased before I give it away
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Dec 17, 2012 | Lgic LG6200 Cell Phone
Zte x500 factory reset
Default 4 Digit user code: 1234,1122 or 0000
Dec 06, 2012 | ZTE Cell Phones
I hard reset my att pantech z990 and it didnt default back to factory settings, It has no settings at all
Oct 05, 2012 | ZTE Avail-Z990 Avail At&t Unlocked Android...
I want reset the factory default of my switch HP Procurve 2510G
To reset using the CLI, run the command "erase startup-config". When prompted, say yes to reboot and that will restore the procurve switch back to factory settings after it starts up.
Mar 08, 2011 | HP ProCurve Switch 2510G-24 24-Port...
Camera no flash eventhough set to manual flash
First thing to do is to reset the unit, either hard reset or soft reset will do this will not erased any saved picture on your camera, but better to do a backup for incidents of accidental erasing it. This will reset the camera settings into factory default.
Hope this helps
Let me know.
Nov 23, 2009 | Kodak EasyShare C513 Digital Camera
I dont know how to delete all the contacts
You could reset everything back to factory settings if your starting from scratch. Go into settings and find 'master reset', as long as your sister hasn't changed the phones default lock code when prompted for phone code enter, '00000' or '00000000' one of these is default. Then phone will turn off and reboot and will be as fresh as the day it was first purchased.
CAUTION: if there is anything you dont want to erase DONT DO THIS as it will erase everything back to factory default!
Apr 23, 2009 | Cell Phones
Erase
hi daisy bay,
the player does not have a reset button, the way to get the device to factory default and erase everything is by opening the device and removing the battery for a couple of hours. but before doing this, you can always use its data cable to connect it to a PC and remove all of the contents of the player.
hope this helps out.
-voodoo
Apr 11, 2009 | Digital Media NS-2V17 MP3 Player
Xerox WorkCentre M-24 Color Copier Logo
567 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
