Question about Maytag Atlantis MAV6000 Top Load Washer
Washer leaking There is a small amount of water on the floor on the right front of the machine when clothes are washed. Not every time just once in a while.
    Problem Solver:
  • 5 Answers
Jreeves,
Just wanted to let you know that is where the water pump is located on your washer. The shaft seal may be going out on it. Or it may be possible that the machine is shifting too hard and the hose that connects to the pump could be leaking check out both of these ideas. If you should have to replace the pump it will run you about $30-$35.
Posted on Jun 23, 2008
Washer is leaking water from the bottom right side
check your hot cold connections going into the washer might have to take top part off to seee inside might just be a rubber seal
Mar 17, 2013 | Maytag Washing Machines
My Frigidaire front load washing machine feels warm/hot even when I chose the cold wash cycle. My clothes are even hot at the end of the cold cycle.
its the hot water fill velve leaking,,,,your getting a small amount of hot water as well as the cold water when it fills up the washer,,, change the water velve
Jun 08, 2010 | Frigidaire ATF6000ES Front Load Washer
Intermittent water observed under machine
Difficult if not seen. Most common water on the floor senario is a drain pump leaking:or a perrished pipe from friction.or sometimes, water backs up from the house drainage system due to a restriction.
Sep 25, 2009 | GE WJSR2070B Top Load Washer
Leaking washing machine
maybe to pump leaking or a hose has come off for the rinse cyc that flushes the fabric softner into the tube if its a smaller amount of water.....try this select a wash cyc let it fill up and wash for a short time then inspect the front of unit for water if no water push cancel/drain and let it drain insp front still no water then I would check for a loose hose or a cut in a hose
Sep 06, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Tromm Washing Machine small leak
Front load washers will always have some water in them. if, it leaking out, you may either have a bad seal, these are double drums, you may have a leak at the discharge house coupling at washer
Jul 02, 2009 | Washing Machines
Leaking Washer Machine
this is joyce
This sounds like a center seal kit, they run around $80.00 they are complecated to install so I would suggest getting someone to install for you.
thanks,
joyce
Feb 06, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Small amount of water from washer
ck around pump at place motor shaft connects ..that is mot likely place
Sep 12, 2008 | Kenmore 24032\24036 Top Load Washer
Brown spotting on washed clothes
chances are if you have eliminated anything thats got in by accident that the drum bearings are about to go, the drum bearings are protected by a water seal, this has started to leak and is now washing the grease out of the bearings back into the wash, you may also find a small amount of water on the floor, if you also remove the back and look behind the large pulley you may also see brown water marks running from the center of the outer drum
the next step will be a very noisy spin, like a rumbling noise
DRUM BEARINGS sorry
Oct 15, 2007 | Washing Machines
Front loader washing machine = black streaks on clothing
I am a recently retired engineer of 20 years once you have ruled out anything getting inside the machine by accident etc, like something in pockets or greasy overalls, then its likely to be the drum bearings, has the machine started to get noisy on the spin the drum bearings are covered by a rubber seal, this seal gets damaged or worn and water leaks into the bearings themselves washing out the grease back into the drum where the washing is, you could also notice slight water marks on the floor underneath the machine on the floor, take the back off and look for water marks coming from the drum outer casing behind the pulley, these marks will be brown and will originate from a small drain hole, if any of the above change the bearings before any real damage is done, either to the clothes or the machine, as repair can be expensive? sorry, hope i have helped you as to where to look at least,
Sep 18, 2007 | Kenmore 46462 Front Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
136 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
