Question about Maytag Dehumidifiers
Codensation Removal Condesate water will not drain through the garden hose adapter. Container fills up and has to be manually emptied. The hose does not have any inclines or sharp bends.
  • irzboss Jun 27, 2008
    My solution, i.e., tapeing down the float in the container so that the dehumidifier would not shut off when the container was filled with water allowed the water to drain out the hose.
    Novelist:
  • 121 Answers
Try making sure the tube that came with the dehumidifier has no blockage. Some Dehumidifiers have the hose screw into the side of the bucket and drain from there. Most newer ones have a plastic tube that comes with them that attaches where the condensate water drains. Good luck - Tech101
Posted on Jun 24, 2008
Hose connected but not draining and bucket filling
I am also an air conditioning tech, with same problem and same soleus dehumidifier problem. you must remove the plug and install the drain line hose adapter. Hose must lay flat and have no "hills" for water to drain. With this done pull your drain pan out and set aside. look under right side facing the dehumidifier and you will see a small spout. Has a lip like a little tea pot. Plug that spout. I used a foam ear plug used in work shops. Now give the front of dehumidifier a slight rise on front wheels about the thickness of a pies of cardboard 1/8 to 3/16 of an inch. Now put drain pan back in an start up. The problem is the drain pan was made with very little differance in pitch between the the hose drain and the bucket drain. Remember to check your drain hose periodically and the air filter also. Good luck
Sep 09, 2011 | Soleus CFM-40 Dehumidifier
I have a new Frigadaire dehumidifier , 50 pint, which I have connected to a garden hose to be emptied into a drain in our basement. So far, after, two weeks, it fills up with water and we have to...
I'm really surprised that Frigidaire didn't know what the problem was. The drain tubing at the hose connection is clogged or the hose itself is clogged. When this happens, water is diverted to the bucket.
First, turn the unit OFF & unplug it.
The hose clog is easy to solve. Simply remove the hose and either look thru it for light at the other end or blow through it. Make sure the hose is no longer than 5 feet.
To clear a clog in the drain hose connector, you will need an 18" long plastic Zip Tie or something similar (NO wire coat hangers, though) that is appropriately sized to fit in the hose connector tubing.
Carefully insert the Zip Tie and continue to insert it, until you reach a bend in the tubing. You will need to gingerly work the Zip Tie past this bend, until the Zip Tie bottoms out or you run out of usable Zip Tie. Slowly remove the Zip Tie while rotating (twisting) it. This will dislodge any clogs. As you each the inserted end of the Zip Tie, be prepared for some water to follow.
Completing the above, should solve the problem. Then call Frigidaire and tell them how to solve the problem.
Hope this helped you. Please let me know. Thanks.
Jul 06, 2011 | Dehumidifiers
How do i make it continue to run with no bucket so it does not fill and and so i don't have to empty it
Attach a length of garden hose no longer than 5 feet, to the threaded drain hose connection that was supplied with your unit, to carry water to the drain.
1. Remove the drain-hole cover on the back left side of your unit.
2. Connect a garden hose to the threaded drain hose connector.
3. Push hose connector tightly to the drain-hole on Rear Grille with the arrow on the tab pointing UP.
The hose attachment will accept a standard garden hose fitting.
Do not over tighten the hose when connecting it to the hose connector,
use a rubber washer and tighten by hand firmly without stripping the
plastic threads.
When being attached to hose connector drain hose connection,
do not bend or kink the hose. The hose should lie flat from the
dehumidifier to the drain.
Jul 04, 2011 | LG LHD45EL Dehumidifier
I own a Whirlpool Dehumidifer Model Number AD 70USS1. I have a drain hose connected to the unit, however, recently the unit's internal collection bucket fills with water to the point that the...
superstee - You're having to empty it because either the drain hose you have connected to the unit is clogged or the drain hole a the hose connection is clogged. Therefor, the water is drained into the tank, rather than the drain hose. Also, the drain hose would not be any longer than 5' and must drain down, as the dehumidifier does not have a pump. It relies totally on gravity.
Remove the hose and check it for clogs. If clear check the drain hose connection, using an 18" long appropriately sized Zip Tie. Carefully insert the Zip Tie and continue to push it in until you reach the bend in the tubing. Gingerly work past this bend, until the Zip Tie bottoms out or you run out of usable Zip Tie. The while slowly pulling it out, rotate the Zip Tie. This will dislodge the clog. As you reach the end of the Zip Tie removal, be prepared for some water to follow. CAUTION: BEFORE DOING ANY OF THE ABOVE TURN THE MASTER ON/OFF SWITCH TO OFF AND UNPLUG THE UNIT.
The above should solve the problem for you. Please let me know. Thanks.
Jun 08, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
I have a Maytag model M7DH65B2A dehumidifier that has worked well for several years. However, when I hook up the hose to drain off the water when we go on vacation the water still fills up the built-in...
Hi Graham. Check the hose and the opening to the hose through the base of the dehumidifer. There is probably some debris in there causing this aggravating problem. J.
Jul 31, 2010 | Maytag M7DH65B2A Dehumidifier
The drain hose is not draining. I am manually having to empty the bin.
Hello my name is Heath it will be my pleasure to assit you. If the hose is plugged it will not drain disconnect the hose and use compressed air or a garden hose to flush the hose out with water.
Jun 16, 2010 | Dayton MDF65AE Dehumidifier
Our unit is hooked up to a hose drain had has been
proably trash in your diverter (the thing that allows water to run to tank, or hose) try a pipe cleaner or blow with air, is it electronically controlled? or is there a valve?
Apr 03, 2010 | Dehumidifiers
Whirlpool dehumidifier drains into the bucket, not the garden hos
I had a sililiar problem. I think I tightened tthe hose after putting a new rubber gasket on hose fitting, Also checked angle of hose.
Jul 26, 2009 | Maytag M7DH45B2A Dehumidifier
Drainage bypass to hose not working
I taped down the float in the container so that the unit would not shut off when the conainer filled up. The water now is going through the drainage bypass .
Oct 05, 2007 | Maytag M3DH30B2A Dehumidifier
Dehumidifiers Logo
149 people viewed this question
Top Maytag Dehumidifiers Experts
Michael Van Der...
Michael Van Der...
Bill Long
Steve
Are you a Maytag Dehumidifier Expert? Answer questions, earn points and help others
