Question about Magellan GPS
My unit just shuts off and will not turn on again until I plug it in as if to recharge the battery. I checked the battery when I first turned it on and it said the battery was fully charged.
    Genius:
  • 1,036 Answers
Hi there!
It probably does need a battery replacement.
Even though it may show fully charged, and even test as fully charged, it may no longer have the capacity to deliver it for any sustained period.
If you think of a comparison between a 12V car battery, and a 12V alarm battery. Both show full charge, and the same output voltage, the difference is the available plate area. This is reduced due to degredation, and will no longer provide the same output.
Hope this helps.
If you want to make the battery last longer, charge for the recommended time (as was the first charge), then run the battery right down before charging.
If this solves the issue, Please rate as Fixya! thanks.
Posted on Jun 20, 2008
While mowing along my blades stopped turning. i shut the pto off and tried again. i noticed the battery light comes on when i turn the pto on. i let the machine cool off and tried again. the pto turns on...
Did it work right after you changed battery? It sounds like your regulator/rectifier isn't recharging your battery. When the battery isn't charging properly the pto wont work for long. If you have a multimeter, hook it up to battery while unit is running and check voltage on battery. When idle is high you should see more charge and vice versa. Please exercise caution when doing this. Hope this helps.
Aug 01, 2013 | Garden
Tip
HTC increase Desire battery life.
<span>Preparing...<br />With the phone in the on position.<br /><br />Fully charge the battery with the phone on... (until the led turns green.)<br /><br />Once the led turns green, unplug the charger until the led goes off. <br /><br />After the led goes off, plug the charger back in. When the led turns green , power off the phone.<br /><br />now.... with the phone fully powered off...<br /><br />1. Unplug the charger. <br /><br />2. Wait until led goes off. <br /><br />3. Plug charger back in until the led turns green. When it turns green, unplug the charger again and go to step 1.<br /><br />4. repeat steps 1 and 3, 10 times. This may take anywhere from 30 seconds to 30 mins per cycle. Typically only about 1 minute. though.<br /><br /><br />DO NOT DRAIN THE BATTERY. The goal is not to empty the battery and recharge like ni-cads (those have memory, these don't). These are lithiums, so we need to do the opposite...</span>
on Jul 11, 2011 | Cell Phones
Brand new, never used. Plug into wall to charge and just get flashing red light. After 16 hrs on charge, still flashing red and when turn on, screen blinks then shuts down.
check that you have the battery in the correct way
if it has batteries like AA , AAA or what ever the negative terminal of the battery goes against the coil spring so if you have them all facing the same way, that may be why they are not charging
the screen shutting down at this stage would be cause the batteries are flat
of course you could always bet new fully charged rechargeable batteries and put them in correctly to see if the rest works
Apr 30, 2017 | Sylvania SDVD7015 7 in Portable DVD Player
Shure P2R body packs keep shutting off on their own in middle of show. Have to turn switch off and then back on to get them working again. Very tedious during a performance.
If the switches are being bumped off that would be obvious. Less obvious is that some people try to run these on rechargeable batteries... That is NO-NO as the voltage of the rechargeables is lower and after a short time the rechargeables degrade and will act as you are seeing. Use ONLY ALKALINE batteries. Another problem MIGHT be the battery connections are marginal and vibration breaks the contact momentarily causing unit to go off and stay off. Battery clips are a pain in these units.
Apr 15, 2011 | Shure P2r Personal Monitor Hybrid Bodypack...
PALM WILL NOT TURN OFF
Hold the power button until it shuts off. Holding the power button down for a long time constitutes a "hard shutdown" and most of todays gadgets do shut down by actions such as this.
If not, then wait until it dies then recharge it. If you don't want to wait, carefully take out the batteries then put them back in. After you turn it on again it should be fine.
Dec 29, 2009 | Palm Tungsten E2 (Multilingual) Handheld
My MPC t2300 laptop wom't turn on.
The Transport T2300 has an internal battery that will run the laptop for several minutes after the main battery goes dead. This feature allows you to save your work and shut down safely. If you run the laptop until both batteries are dead, even a brand new battery can't start the unit again. You have to follow this procedure:
1.Unplug power cord
2. Remove any attached periphal components including the cd rom and/or floppy disk module if you have one. Both remove with a push button switch located on the bottom of the unit.
3. Plug in power cord and charge the unit for a minimum of 24 hours straight. 30 hours is better. This whole time will be spent slowly recharging the internal back up battery.
4. Once that is done, unplug power cord again and reinstall any floppy/cd drives. Plug power cord back in now and charge for at least 24 hours again.
If your backup battery is dead, you can't charge the main battery or turn the unit on. The longer you charge, the better. We had one unit here that had to be on the initial battery backup for 72 hours before it finally took hold. Then, one overnight recharge on the regular battery and all was well.
If you need drivers or manuals for the 2300, all are available on cd at mpcsupport@cox.net for around $9.50 including shipping, handling, and owners manual
Apr 11, 2009 | MPC Computers TransPort T2300 Notebook
Frozen not doing anything
allow your battery to discharge for few hours and as soon as it gets low battery indicator until it shuts down , plug and recharge this again this will resolve your prob, as if it was refreshed.  it only hangs for a while, but it will soon recover..
cheers
Nov 25, 2008 | SanDisk Sansa Clip MP3 Player
Beeping and shuts off
maybe battery is dead(?!), how about with the adapter(if it has one)?
Aug 31, 2008 | Samsung S850 Digital Camera
Garmin 478 powers up then 3-5minutes powers down then i will turn on again then will turn off again
Hello mrbill254,
The rechargeable battery in your GPS receiver may be going bad. Over the lifetime of the battery the amount of operating time you can expect in between charges will naturally decrease until the battery gets to a point where it is no longer able to power the unit. That may be what is happening.
Unfortunately most GPS batteries are not considered to be user replaceable. You should contact Garmin to find out about battery replacement service.
Best Regards!
Ken
"Go Ahead. Use Us."
Jun 18, 2008 | GPS
Battery will not take charge from wall unit
Remove the battery for several minutes, replace the battery and plug the wall socket in, leave it for several hours. The battery is probably too dead to do anything, and recharges very slowly. If this doesn't work, try a replacement battery, before you send the unit in for repairs.
Jun 15, 2008 | Garmin zumo 550 GPS Receiver
GPS Logo
182 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
