Question about Canon PowerShot SD1000 Digital Camera
SD 1100 HAD CAMERA LESS THEN 2 MONTHS,HAVENT DROPPED IT,WAS SHOOTING PHOTOS, TURNED OFF AND LENS WOULD NOT RETRACT
  • ceedub Jun 20, 2008
    HEY GOOD NEWS ,I GOT THE SD 1000 TO WORK BY PLUGGING IN TO COMPUTER AND STARTING UP,TOOK 2 TRYS,THANKS
  • gabriellax3 Jul 10, 2008
    the lense cover does not open. therefore i cannon take pictures.
    the covers are blocking the lenses. =[ i need help !
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 480 Answers
Hey ceedub,
According to the manufacturer if the lens won't retract back into the camera it is caused by the memory card slot/battery cover was opened when the power was on. If this is the case to fix this you should close the memory card slot/battery cover, and then turn the camera on and off. If this is not the cause there is most likely something obstructing the movement of the lens (i.e. sand), and I would try blowing compressed air into the side of the lens to try and dislodge whatever it is. If this doesn't work I would have the camera looked at by an authorized service technician. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Posted on Jun 25, 2008
My camera battery died while I was shooting and the lens was out_ new batteries but now I am getting a lens error message!_ the lens will not retract! help!
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Oct 02, 2010 | Canon PowerShot A470 Digital Camera
The lens will not retract. A message says "lens error, restart camera," but the camera will not restart. The camera is a Canon PowerShot S3 IS. I can hear a "whirring" or motor noise when I try to start...
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some simple things that you can do to try to correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Feb 17, 2010 | Canon PowerShot S2 IS Digital Camera
Canon iXUS 750 approx 3 years old. Getting E18 message. Lens will not retract, unable to take photos. Camera not dropped.
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Oct 12, 2009 | Canon PowerShot SD550 / IXUS 750 Digital...
Lens will not retract, camera was not dropped,
Leave the batteries out for a while and then try turning camera on..hopefully its resets the camera and retracts lens.
Jul 07, 2009 | Kodak EASYSHARE Z1285 Digital Camera
Canon A540 powershot freezes with Zoom lense still out.
Probably the most common failure for all digital cameras, a lens error. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 08, 2009 | Canon PowerShot A540 Digital Camera
Sony dsc-w5 lens not returniing
May 17, 2009 | Sony Cyber-Shot DSC-W5 Digital Camera
Lens error
Same problem here - the forum posting on the SD 500 seems to be a bit more active (for the same problem).
http://www.fixya.com/support/t102982-e_18_problem
I have been trying to get some images or a service manual for the SD 700, with no luck...
Mar 15, 2008 | Canon PowerShot SD700 IS Digital ELPH /...
Bent lens.
The complete service manual costs US$21.00 and we can upload. The Lens block may be expensive at US$120.00-3 weeks and needs confirmation. Regards, Siva
Sep 21, 2007 | Sony Cyber-Shot DSC-S40 Digital Camera
Ricoh Caplio R4 Lens
This is an easy fix for a camera shop. Just tell them that your lens is off track, and needs to be aligned. It should cost less than $50.00. If you are really good with electronics, you can attempt it yourself. Just let me know if you need the schematic to the camera. Best regards, Bill
May 20, 2006 | Ricoh Caplio R4 Digital Camera
Canon PowerShot SD1000 Digital Camera Logo
61 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
