Question about Amana Dryers
Brand new dryer timer does not move dryer wont heat
  • sistertiff Jun 22, 2008
    i found out that one of the two switches on the circuit breaker was not supplying power, guess I will have to replace the circuit breaker.
    Genius:
  • 1,028 Answers
Be sure wired correctly and has 240 volts between outer lugs and 120 between outer lug to middle lug (or burnt wire from not being properly tightened when installed)also try resetting breaker
Posted on Jun 22, 2008
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
Dryer wont stop buzzing
follow this steps and fix it. God bless you
Timer
The timer could be the problem. To check this, turn the timer to a timed cycle say 30 minutes or so then time it. If in 30 minutes the timer hasn't moved and the dryer is still on, the timer is bad and need replaced. If in 30 minutes the dryer is off, the heating element is your problem
Heating Element
This is the most likely cause for some dryers timer not advancing. Some dryers have two heating elements and if one goes out the timer will not advance if you use it on an automatic cycle but you will still feel heat inside the tub. replace the heating elements
Jul 09, 2013 | Dryers
My dyer wont heat and timer wont move changed the thermal fuse and cleaned all the lint out of the blower box and put in new venting pipe
Make sure you have 240 going into the dryer. If one side of the breaker is tripped it is posible for the dryer to run because the motor runs on 120 volts ac. The heat uses 240 volts. Next check the heavy red wire coming out of the timer. Remove it from the timer and attach a lead from an ohm meter to that leg on the timer. See if you can get a reading from any other leg on that timer. Move the dil to various spots on the timer and keep checking for continuity. If you cannot get a reading from that terminal to any other terminal on the dryer then you have a bad timer.
I did a few homemade movies today and posted them on my youtube channel:
http://www.youtube.com/watch?v=hbez7kjzNic&list=UUKBjalPycKRmo4Mz9vRsydg&index=3&feature=plcp
http://www.youtube.com/watch?v=AoVmPvUG_7o&list=UUKBjalPycKRmo4Mz9vRsydg&index=2&feature=plcp
Mar 07, 2012 | Whirlpool Inglis IP8200 Dryer
Hi,my problem with the dryer is that it not heating any more and i can't get the timer on
send the model number,open the door,look around the opening of the dryer not on the door and i can look up your dryer,i don't understand what you're saying about the timer?if the timer isn't moving on auto or more or less setting it wont move if there's no heat,also i either need the model number or is it gas or electric
Jul 15, 2010 | Kenmore 63942 Dryer
New Dryer and there is no heat and the timer is not moving !
you need to first check your power do you have 240 nstraight across your receptical? i would flip breaker on and off. see what happens...what was wrong with your other dryer?
May 04, 2010 | Roper REX4634KQ Electric Dryer
Whrilpool washer/dryer stack the dryer doesn't get hot
You will find that the drier wont get hot because the timer is not forwarding onto the heating part of the cycle. Possibly if you click one click at a time, you will possibly get to the heating part of the cycle but its not safe as it wont go any further. Install a new timer and you will be happier I'm sure.
Sep 28, 2009 | Dryers
Model WED5300SQ0 not heating and timer not working
Well with moving it around and all it could have any number of things happened. If it wont tumble, no lights, no heat or anything check that the plug has 240volts to it. then check the wiring going into the dryer may have broke wires or anything like that. but I would check the plug first if it has no power what so ever. If you check the plug and it doesn't have power check the breaker to see if it is tripped.
Sep 03, 2009 | Whirlpool LER5636P Electric Dryer
It runs but timer wont advance dryer wont heat.
did you change out the limit switches? they control the heat to the element... and it sounds like you need a new timer
Jan 22, 2009 | Whirlpool GGQ8831L Gas Dryer
Timer Does not Move
FIRST CHECK YOUR VENT IS CLEANED OUT THEN SEE IF TIMER MOVES WHEN PUT TO A TIMED CYCLE. IF SO MEANS VENT CLOGGED UP. IF STILL NOT MOVING MEANS TIMER CONTROL BAD. COST ABOUT 80-100 FOR PART. YOU COULD DO YOURSELF IF SOMEWHAT HANDI.
COULD BE ORDERED FROM SEARS PARTS DIRECT BY YOU.
OTHER WISE CALL SERVICER AND MAY COST 200.00 TO REPAIR. HOPE THIS HELPS
Feb 22, 2008 | Kenmore 62602 Electric Dryer
Dryers Logo
44 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De GO PATS
Are you an Amana Dryer Expert? Answer questions, earn points and help others
