Portable Bluetooth 4.1 Receiver Wireless Multipoint Connection Audio Music Adapter with 3.5mm AUX Port and Hands Free Calling for Home Audio Music Streaming Sound System https://www.amazon.com/Charm-Bluetooth-Multipoint-Connection-Streaming/dp/B01G8219Y4/ref=sr_1_1?ie=UTF8&qid=1482465666&sr=8-1&keywords=Charm+sonic
Formate ur memory card ad then try again you it will work
Nokia 6300 you have to reinstall the bluetooth device in the nokia servies center.and then you can receive dates from other phones.[or] copy the datas to pc and formet the memorycard........
Its because your phone memory is running low and when you receive files via bluetooth it comes via message which by default uses phone memory. To solve this issue got to messages and click options button then go to settings > others and under Others menu change the Memory in use to Memory card from Phone memory and you will be able to receive files via bluetooth.
Thanks !!
SOURCE: my nokia 6300 doesn't receive
if you are paired correctly with the person who is blue toothing you than make sure that you have enough memory for what ever it is they are bluetoothing you.
If the file or files are big check that you have enough memory left and that they leave thier phone connected to yours until the download is complete.
Thank you for using FixYa!
I hope that I helped you & that this post is helpful to you at most!
Don't forget to rate! :)
