Question about Motorola Mobility RAZR V3c Cellular Phone
Start up problems
I try to turn on my phone and it stays in the Motorola Screen. I close the phone and it remains in that same screen without changing to turn off the display like it would normally. I cannot do anything else but this.
And the phone is fully charged.
Go get a replacement - your phone is entirely crashed and can't do anything else. Just went to the AT&T shop today.
Posted on Jun 22, 2008
Black screen on Droid A855
pull out the battery wait ten to thirty seconds then replace the battery switch on then check it
Mar 23, 2012 | Motorola Mobility A855 Droid
Last night the screen for my Motorola V365 stopped coming on. I hear the usual musical tones when the phone is turned on or off, and the keys light up for a few seconds as usual, but the screen remains...
there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Take care.
Aug 01, 2010 | Motorola Mobility V365 Cellular Phone
Frozen ''hellomoto'' screen on Razor V3c when turning on phone
You have a couple of options:
Take it to a motorola repairer or try to update the firmware on your phone. As you cant get it to go past the Hellomoto screen a hard reset would not possible.
Apr 05, 2009 | Motorola Mobility RAZR V3
Motorola Headset Out of range...
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select HS815 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Dec 23, 2008 | Motorola Mobility HS815 Wireless Headset
Blank Screen. Phone powers up right, and is useable.
if the screen of that phone is not broken change the flex, if is broken change the screen
Nov 19, 2008 | Motorola Mobility RAZR V3
RAZR V3M thinks it's always open - Screen will not turn off
in the top right corner you are suppose to have a little circular magnet that changes the screen when the phone is open or closed. I just changed my housing yesterday and took the magnet out and put it in my new housing but for some reason i have the same problem as you. so maybe you lost the magnet when you replaced the lcd and if that is the case then you are screwed. try have Motorola fix it, don't tell them you replaced the lcd
Dec 04, 2007 | Motorola Mobility RAZR V3m Cellular Phone
Motorola Razr problems.
is your phone been dropped or wet? need to check it with service centers near your place
Sep 22, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Motorola Razr V3 display problem
Solution this same thing happened to me - cause LCD screen going out = it's weak and thats the sign that it is giving up. To Temporiley to keep it on: take the battery out and back cover of battery off place phone in ICE section of Freezer ( NOT IN THE ICE )by the area where it gets cold leave it there for 10-minutes, then take it out after 10-minutes wipe everything up put the battery back on and restart phone & wah'la it's working....
Aug 14, 2007 | Motorola Mobility RAZR V3
Logo stays on outside display window of cell phone
I'm having the same trouble, and I've found it's because the v3 no longer recognizes the opening and closing of the phone itself. You see, when you close it, something is triggered that tells the phone to shut off the main screen and change the outer screen to the usual mode where it shows the time. You can also test this by trying to take a picture and closing the phone - the external lcd no longer doubles as a second camera display to easily take pictures of yourself. I dropped mine into the toilet, and I'm not sure if there's anything to do but take it to a tech. Sounds and looks like a hardware problem to me.
Jun 28, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3c Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
