Click here1. and read it carefully.And here is your
3110c file.Thsi is the only way and after doing this make sure that you should not transfer files via blue-tooth and if possible do not use mmc of more than 512mb.Good luck
take the memory card and sim off firstTry switching on the phone by using any other BL-5C battery If it works fine without the memory card then it's most likely a faulty or corrupted card.
You should try formatting it to see if that solves the problem, if not replace the card with a new one.
You can't "flash" that model yourself at home.
The only thing that you can do with it is to take it to a nokia care point for repair.
Yo! Your phone already has a software problem or it has been infected by a virus. i advice you see a certified engineer to reload the software of the phone and that will clear the problem. Thanks
may be it could be affect by virus and OS files maybe deleted. So try it..
when the mobile is switched of press caller button(green) * button and 3 button at a time and switch on power button. do not leave till the three buttons till process is completed. (do not forgot to charge your battery before u do this, or connect to charger)
if the problem is not solved take it to any Nokia Mobile store to get repair
ThanQ
My nokia 3110c is not switching on. while switching on its blinking for 3 times and with white flashes and not working.what i have to do? can i update my cell without going to switching on? please give the quick solution please
