Question about Microwave Ovens
Microwave oven does not heat
Thanks for the possible cause information. I checked per your instructions and found that if I move the door with handle up or down heat turns on - I watched the door handle mechanism making contact with switches. Can you tell me ho do I increase more contact between door handle and switch? I tried to mve the switch assemble but it is screwed tighly with the housing. Thank you.
  • Anonymous Jul 19, 2008
    when you open the door light do not come on , and when you push start the make a sound
  • Microwave Ovens Master
  • 9,086 Answers
Found brand & model in your other thread:
> Whirlpool Gold Microwave Model GH7155XHS
Did you see the door switch file at my site I pointed you to?
With the door shut, you gently loosen the door switch mount screw nearest the switch that is not aligned properly.
Then pull back slightly on the door switch mount, and while holding it back, retighten the screw.
The door switch mount is also called the latch board. On the exploded view, it looks like there may only be one screw.
You have to look it over and figure out how to adjust it based on the way it's constructed and which way it needs to go.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jun 20, 2008
I was given a Russell hobbs microwave combi Ct/la30 without an instruction manual and I've just discovered the microwave has stopped heating. It sounds as if working. Thanks in advance
There are multiple possible causes for the problem. Here's a partial list: magnetron, high voltage capacitor, high voltage rectifier, power relay, inverter board (if an inverter oven), thermistor on magnetron (if so equipped), and on some units, a door switch.
Dec 07, 2016 | Russell Hobbs Microwave Ovens
Need to Replace Door Handle for KitchenAid Over Range Microwave Hood Combo KHMS147KSS
can u send me the pic of door and the handle of ur oven at khader_abu@yahoo.com........
Jun 01, 2008 | GE Advantium SCA1000H Convection /...
How to remove the outter door frame on the GE Microwave
http://www.repairfaq.org/sam/micfaq.htm
for both queries this site would help somethin i think.. tpugh information is very huge please see if it is useful for u
Dec 25, 2007 | GE Advantium 120 Convection/Microwave Oven
No heat generated in microwave or convection oven mode
I just read that starting the microwave as usual and then slightly pressing in the handle (you can hear the heater(?) come on will make the heat come on. Tried it and it works. My repairman told me it needed a new magnetron ($700) but that was totally wrong. I will be trying another repairman to replace handle mechanism.
May 11, 2013 | Sub-Zero MW24 Microwave Oven
My microwave oven heats up sporadically. One time it does, then next time it doesn't.
its possible you might be a door switch problem...when you try to heat the food,an it dont work ,lift up on the door handle ,see if it starts working...you might need to replace the door switch or switches...
Nov 05, 2009 | Danby DMW773 Microwave Oven
Jenn Air Microwave Error Code
Hello Hec1152,
I have found the manufacturer contact information for you, but could not find information about the error code. If everything works fine, but the microwave is not heating your food, then the problem is most likely the magnatron or one of it's components, which sadly to say is the most expensive part to replace. Please feel free to contact the manufacturer via phone or live chat to get more details as to what the error code means.
If you would not mind, could you please rate my help. I would greatly appreciate it.
Nov 29, 2008 | Jenn-Air JMC7000 Microwave Oven
Microwave oven stopped working
OMG!!! This was perfect. I had the same problem. Timer was on but the fan nor the table turned. Just when I was about to take the thing and chuck it in the trash, I thought I'd give the above method a try. I turned the microwave on, and nudged the door sligthly upwards.... miracle! it started to work. to make it permanent, I took the door off (the cap on the inside of the door, on the upper hinge needed to be removed with a flat head screwdriver, very easy, just pry it off). Once I took the door off, I placed a small washer on the bottom hinge to raise the door slightly. Put the door and hinge cap back on... and Voila! The microwave works now. Thanks for the help guys...
Jan 20, 2008 | Frigidaire FMV156DC Microwave Oven
Microwave will not heat food
Found this under Maytag instead of LG, but will be happy to help.
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Magnetron diagnosis is here: http://gallawa.com/microtech/mag_test.html
Dec 08, 2007 | Maytag MMC5000 Microwave Oven
Microwave oven not functioning
Dec 04, 2007 | Magic Chef CMV1000B Microwave Oven
Not heating
Normally the fuse(s) in a microwave will kill all power to the unit and render it "dead", as opposed to just limiting operation. The most common causes for it to run without heating are a bad door switch, a bad relay or connection on the control circuit, a bad connection on the "FA" magnetron terminal, a defective high-voltage transformer, a defective magnetron or a shorted high-voltage diode. One thing you could do is to try gently pushing down on the door handle or the door about 1/32 of an inch or so and se if it heats then. That would indicate door switch trouble or alignment. This test can easily give you a false "positive", though. I hesistate to offer any more specific instructions unless someone is an experienced and informed DIYer or more. Even still, I would want to steer a person toward my Web site, which contains important safety info and free DIY tips. But I cannot, since such a referral would violate the terms of this site.
Oct 07, 2006 | Samsung SMH7174BC Microwave Oven
Microwave Ovens Logo
97 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
