Question about Canon PC1061 Copier
Canon PC1060 Have a PC1060 with paper exit sensor popped out of place. what is the easiest way to remove platen and get to the fuser. Any general explanation would greatly help. Thanks T George
  • Canon Expert
  • 1,326 Answers
The fuser comes out the left side, not from the top of the copier.
Posted on Aug 11, 2008
I have a Canon imageclass D880 multifunction, error"Paper Jam, slide platen..." I can see the paper deep within the machine ( fuser?) but cannot get to it to get it out.
Hi marcbachm177,
Please follow the steps below on how to remove paper jams inside printers in hard-to-reach places, a pair of medical forceps is often useful.
1. Take off 3 plastic covers one above exit area-slide top to left to access screw. Remove lower exit cover and side cover -unsnaps with 2 pins and there is one more cover I think over the fan that needs to come off.
2.Locate black plastic sheet covering a circuit board carefully pull this back-disconnect 3 plastic connectors that lead from the heater to the circuit board.
3. Using a offset phillips #2 screwdriver remove 3 screws that hold the fuser to the frame.
4. Carefully lift fuser up and out toward the exit area.
5. Pop off black cover remove 2 screws from top of fuser, disengage cover lid locks with a small screwdriver, lift upper fuser heater - be careful NOT to damage plastic heater membrane. remove paper jam and reassemble.
Hope it helps.
Thank you for using FixYa.
Aug 17, 2011 | Office Equipment & Supplies
Need to identify where paper sensors are in paper path. Can not clear paper jam. have totally cleared paper path removed all necessary parts even removed covers and blew machine off. also, sensor for over...
its probably exit sensor which is in the right hand corner just above fuser. hard to get to will need to remove fuser,front small square cover and prob exit cover ull see actuator and a long shaft which will lead u to a sensor.it will prob out of place or covered in dust.
Feb 24, 2010 | Ricoh Aficio 180 Laser Printer
Display says rec.paper jam,slide platen left
in service mode manually recheck all paper transport sensors...
Mar 17, 2009 | Canon Office Equipment & Supplies
How to remove the scanner unit on Canon PC1060
you sould not have to remove the scanner unit to clear a jam in the fuser
open all doors and remove anything marked green
remove the the cartridge assembly if it will come out
open the fuser section (usually a release that takes pressure off of the fuser rollers
remove the paper feed cartridge
you now should be able to follow the paper feed path from the time paper goes i until it comes out
if you are not sure of path take a piece of card stock and simulate it goig through feed ara
there are small microswitches/ poto eyes that sense paper lok for an small pieces also clean thes poto eyes with q tip and rubbign alcohol
reassemble
unlug from the wall then plug back in and turn on p roblem sould be solved
Jan 05, 2009 | Canon PC1061 Copier
XEROX 6110 coloer printers
Xerox 6110 Code Description A1-1 to A1-32 All indicate a paper path problem, etc. in the ADF A2 ADF exit problems A3 Irregular size documents A5 ADF interlock A6 ADF single sheet document reset A7 Platen interlock A8 ADF exit interlock C1 Tray 1 jam C2 Tray 2 jam C3 Tray 3 jam C6-1, C6-2 Jams related to duplex C6-3 Registration sensor, re tray 1 C7-1, C7-2 HCF feed problems C7-3 Tray 1 feed problem C8 Paper stays in tray or duplex or HCF C9 Bypass feed problem E1-10 to E1-25 Internal jam E1-6 Paper on registration sensor E2 Reset signal happened. Might read E-2 something else E3-30 to E4-14 Exit jam E3-6 Exit jam E4-10 to E4-14 Inverter sensor not actuated E4-15 Inverter sensor E4-40 to E4-45 Duplex entry sensor E4-6 Inverter sensor E5 Front door interlock E6-1 Tray 1 interlock E6-2 2 tray or duplex interlock E6-3 HCF interlock E7-2, E7-3 Duplex interlock E8-6 to E8-15 Duplex entry sensor F1-1 Sorter entry sensor F1-6 Sorter exit sensor F3 Paper size not available for sort/stack F5 Sorter interlock J1 Add toner J3 Replace copy cartridge J7 Replace copy cartridge J8-1 Wrong copy cartridge installed J8-2 Copy cartridge EEPROM L6 Auditron or other counter problem L8 Platen glass temperature is too high L9 Communication problem between interimage erase/edge lamps and main board U1-1 Main motor drive problem U2-1 to U2-4 Scan home sensor U3-1 Lens sensor U4-1 Open fuser thermistor U4-2 Fuser did not warm up properly U4-3 Fuser temperature too high U4-4 Fuser problem. Staying on too long U4-6 High fuser temperature U5-1 Sorter bin home switch not activated U5-2 Sorter bin home switch stayed actuated U5-3, U5-4 Sorter bin home switch U6-1 ROM problem U6-2 RAM problem U6-3 Low battery U6-4 Incorrect value in NVM. Reinitialize main board with code 20-96 U8-1 to U8-6 Problem with exposure lamp, lamp sensor, lamp board
Jan 03, 2009 | Office Equipment & Supplies
Canon D880 Printer/Fax
remove lower exit cover and side cover -unsnaps with 2 pins and there is one more cover I think over the fan that needs to come off.
3. using a offset phillips #2 screwdriver remove 3 screws that hold the fuser to the frame. carefully lift fuser up and out toward the exit area.
4. pop off black cover remove 2 screws from top of fuser, disengage cover lid locks with a small screwdriver, lift upper fuser heater-be careful NOT to damage
Nov 15, 2008 | Canon imageCLASS D880 All-In-One Laser...
Paper jam
make sure that the exit sensor is realese down.generaly u ca check the sensors not to have pull out
Nov 11, 2008 | Canon Office Equipment & Supplies
Fuser
on the paper exit end of the copier you must remove 3 plastic covers
1. one that the paper exits and lays on 2. upper cover {have to slide upper half of copier to left to get to the screw} 3 small plastic cover pops out right behind where paper lays as it exits.
pull back black plastic sheet
undo 3 connectors
remove 2 screws with a phillips #2 offset screwdriver
fuser lifts up and out-very tight quarters here go slow and easy
need any further assistance just ask!!
May 06, 2008 | Canon ImageClass D880 Copier
Canon D880 fuser
With an offset #2 phillips screwdriver and some patience you can do this- we have been fixing PLENTY of fusers on the imageclass series-you can get the fuser out thru the exit side of the copier.
1. UNPLUG COPIER , pull platen to left with grey lever
2.remove one screw for upper plastic cover cover pulls down and out
3.remove 2 screws on lower exit cover this comes up and out
4.remove small plastic cover on left side of exit assembly as you face end of copier.
5.pull back black plastic sheet to expose 3 connectors one plugs into circuit board two plug into heater or fuser assembly. unplug these
6.with your offset driver remove 3 screws holding fuser to frame of copier -these will be pointing up.
7. lift fuser up and carefully work out of copier.
check for stuck papers or damaged fuser film sleeve.
To reseat fuser and replace panels go slow and easy the panels fit back in kinda funky it takes a bit of tinkering.
We do not turn the copier upside down to remove the fuser and have replaced about 20 of the fusers or installed a new fuser sleeve.
Good luck and ask all ya want if more assistance is required.
Apr 05, 2008 | Canon ImageClass D880 Copier
Paper dents
I believe you have two problems. One the dent you are talking about unless I see it I don't know for sure but I believe this is minor and something you need to live with. The paper goes through a fuser which uses a teflon sleeve over a heater surface and a lower pressure roller made of rubber. It may be that you need a new lower pressure roller they get little cuts in them sometimes. Two the spots are probably from a faulty toner cartridge. It has a leak.
Feb 13, 2008 | Canon imageCLASS D761 Copier
Canon PC1061 Copier Logo
239 people viewed this question
old marine
old marine
