Question about Toshiba 52HM95 52" HDTV Projection Television
Loud hum with ramp up and ramp down sound
My 52HM95 was purchased in 12/05 and still has a great picture. It recently deveoped a loud objectional hum during operation. When I turn the set on there is a 3 second ramp up sound like a table saw turning on and the same sound when I turn it off. I have purchased the Service Manual and learned there are actually 3 fans. The manual has parts lists and exploded views but does not have any detail about replacing the light engine.
How can I tell if its a fan or color wheel problem?
Please email me at raywinberg@comcast.net with any suggestions. Ray
  • Ray Winberg Jun 20, 2008
    Thanks Mike for the speedy answer. I am an Electrical Engineer and have mechanical ability but I think replacing the light engine is a little beyond what I am comfortable tackeling.
    The service manual says "When the Light Engine Unit is replaced with a new one, adjustment is required. Adjustment is made from the service mode. The adjusting items consist of of CWDL, CWDH and DMDB"
    Do you know if this adjustment is really required or is it a simple matter to replace the light engine.
    Has anyone heard if Toshiba is standing behind this light engine problem for longer than the 12 month standard warentee?
  • Ray Winberg Jul 24, 2008
    I ordered a new Light Engine for my 52HM95 from Partstore.com on July 15 for $456. Now I learn this item is backordered and they now show 8/16/08 as a ship date.
    Toshiba's web site is showing an extended warentee on the Light Engine for certain models but not mine. One other little aggravating problem is my TV rests on the Toshiba special stand and the TV must be raised about 5 inches in order to get at the 13 screws to remove the back. I plan to use books as shims. Just hope a new light engine is a good investment. Ray Winberg
    Champion:
  • 206 Answers
It is the color wheel but the bad news is Toshiba will not sell the color wheel for this model, you have to but the entire light engine. part # 23405474 for about $500.00
Posted on Jun 20, 2008
  • Mike Owens
    Mike Owens Jun 20, 2008
    I'm The Lead Tech here at Maier Tv in Spokane WA. when we replace a light engine we almost never have to adjust them, they seem to work fine right out of the box, It may sound complicated but on a scale of 1 to 10 we put this light engine replacment at about a 4. there a a few conection and about six screws that hold this in and all the conectors will ony go in one spot
Loud HUM from 1963 Wurlitzer 2710 when plugged in
If you observed a vacuum tube with the symptoms you describe, it requires replacement but there may be other failed components as well.
Dec 27, 2013 | Audio Players & Recorders
Toshiba 52hmx95 dlp tv. took back cover off. the fan cooling the lamp,makes a loud humming noise.read that fan is hard to get.(this is a three wire.only finding two wire.)is there a three wire fan i can...
maxie99,
Fan is available at https://www.encompassparts.com/webwiz/wwiz.asp?wwizmstr=WEB.SEE&partnumber=6475656&smodel=52HM95 for about $80.00. Replacement should be as simple as unplugging the fan cord and removing a couple screws to remove. Do the work with the unit unplugged from the wall. Reverse the procedure to install the new unit.
Thanks for using FixYa and the great rating.
hardrocko
Oct 19, 2010 | Toshiba 52HM95 52" HDTV Projection...
Our TV is making a loud humming noise. We think
It's likely your color wheel rather then your fan. I've replaced quite a few of these and the fans are usually good. Get and estimate - I generally charge $250-350 Total
also google your model # and color wheel to investigate further.
Oct 24, 2009 | Toshiba 52HM95 52" HDTV Projection...
My set started humming recently. Not real loud,
Hi, sounds like a bad color wheel, a technical repair that should be done be a trained repairman, cost around $250-275 installed
Aug 17, 2009 | Samsung HL-S5087W DLP TV
GU1500XTL loud humming sound during the cycle, getting louder
The run capacitor on the main wash motor needs replacing. Eventually it will just hum and overheat instead of rotating, so better replace it now before it overheats.
I doubt you can acces it easily yourself, as it may be away from the motor, and have to be tracked down.
Aug 05, 2009 | Whirlpool 24 in. GU1500XTLS Stainless...
Replaced bulb and now no picture and a loud humming sound
replaced the light engine. yhis set is probably not cost affective to fix.
Apr 03, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Loud humming noise
this problem is sif coil & sound releted 5.5 crustal &releted pf try this
Jun 21, 2008 | Sanyo DS19330 19" TV
GE SidexSide PSS26SGPASS Makes Humming Noise
GE refrigs have a variable speed evaporator fan motor that is controlled by a computer board on the back of the refrig. now the noise you are hearing is most likely the fan motor ramping up and down in speed (some of my customers say it sounds like a ghost). if its a continuous ramping up and down then the speed cotroller on the board is bad and must be replaced. if its just an occasional sound then thats normal and nothing to worry over.
Btw the reason the noise stops when the door opens is because the fan shuts off when you open the door.
Dec 19, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Toshiba 52HM95 52" HDTV Projection Television Logo
260 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
