Rank: Guru
Rating: 85%, 116 votes
has it worked before? if yes, try to power cycle everything. turn off everyhting then turn on the modem first, then the router, then the computer/s.
if you have power cycled everything already and you still can't access the internet using the router,
- access the router's setup page by logging to
http://192.168.1.1 (leave the username blank and the default password is "admin")
- if you're using a cable connection, set the connection type to "automatic configuration - dhcp" and enable the mac address clone
- if you're using a dsl connection and you have a username and password from your isp, set the connection type to "pppoe" then enter the complete username (ex.
username@comcast.net) and password given by your isp.
- check the "status" tab of the router and see if there's an internet ip and dns, if so, you should be able to connect to the internet
hope this'll help you.
ciao!
