Sony 40" plasma 8 years old. whole screen swifts every second since installing video 1 and 2 source?
  • 3 more comments
  • rstmaurice Jun 20, 2008
    Sony Monitor model PFM 42BI
    Unplugging the monitor and everything attached to it did not solve the problem.
  • rstmaurice Jun 21, 2008
    yes it did not work
    hard reset did not resolve the problem
    Already tried that solution and it did not solve the problem the cables are ok and I had changed them just in case
    Sergeant:
  • 275 Answers
Hey please go to this website www.worldofsony.com
there you will find customer support for your place. i hope it will solve you.
Posted on Jun 21, 2008
    Genius:
  • 1,036 Answers
Is this a new set-up, or have you always used it as it is?
It could be source #1 and#2 are both feeding the input and causing interference. You need to switch between the two, or turn one source off.
Posted on Jun 20, 2008
  • Richard Perkins
    Richard Perkins Jun 21, 2008
    It could be the chip controlling horizontal hold if it keeps scanning.
    You may have caused a spark-overload when unplugging or plugging in systems while on.
    In that case it needs a tech to take it apart and trace the issue, unles you are trained in repair of electrical systems.
  • 2,071 Answers
This problem of yours is common , if your unit is getting old ,all the solder joint is loose or cold solder or maybe it crack already ,you reheat or resolder this all ,,the power supply section ,,the horizontal section and the vertical section ,,if all of these are already solder then operation it will be normal again..this is not cost too much,this is very best of the problem of yours...if my answers help you understand the problem , please rate as fixya..
  • LORETO LACARON
    LORETO LACARON Jun 20, 2008
    crack or cold solder is very dangerous of the unit because correct current flows to the circuit cannot pass due to a crack of solder or higher current cannot supress or limited and cause burnt of the spare parts and that's why abnormality comes out,like swift interference ;automatic shot off of unit and many problem .If this cannot be stop and your unit will be dead set ;due to burnt spare parts, stop this as early as possible ,by reheating what im state above...
  • LORETO LACARON
    LORETO LACARON Jun 21, 2008
    unfortunately it is hard to diagnose your problem like this ,.best thing you do get it by a computer technician ,who will be able to diagnose it for you..
  • 426 Answers
I would change the resloution of your screen (via display properties) that should help, if not let me know and i will see what i can dig up
    Sergeant:
  • 243 Answers
What exactly are you hooking up through source 1 and 2. Follow this link:
User Instructions
note: p54-110 is english. It includes all langues so you need Adobe reader and it may download an updated language pack. You want to make sure the resolution and frequency are correct. refer to page 79 from the above link for acceptable resolutions and frequencies.
Keep me updated.
Thanks,
Lee
  • 1 more comment
  • Nathan Ayers
    Nathan Ayers Jun 20, 2008
    have you tried looking at the frequency posted in the manual. If you answer my previous questions i can assist you further.
  • Nathan Ayers
    Nathan Ayers Jun 21, 2008
    Have you tried any of the solutions that I have given you? Or seen my questions for you?
    Thanks,
    Nate
  • Nathan Ayers
    Nathan Ayers Jun 22, 2008
    is the video card set to the proper frequency?? whatever the resolution was by the specified hertz?
    Master:
  • 788 Answers
If you unplug video 1 and 2 does it still do it? If not then either your cables are not grounding properly or there is a problem with one of the board or ICs in the TV. Try only 1 of the two inputs at a time then switch to see if you can determine if a certain input or device is causing your problem.
    Genius:
  • 1,142 Answers
Did you try doing a hard reset to the device
    Brigadier General:
  • 3,614 Answers
Have you try to unplug the unit for a while./?
  • 2 more comments
  • micromaster
    micromaster Jun 21, 2008
    Video card has become slightly loose in its slot, or that one of the
    cables – possibly the cable going from the monitor to the video card –
    has worked a little loose, or has a bent pin. Bent pins can often be
    properly repositioned by hand, or with the aid of a simple household
    tool like a tweezers. If the cable and connection appear to be okay,
    power down your system, unplug the computer’s main power cable, pull
    off the computer’s outer case, and try removing and reseting the video
    card.
  • micromaster
    Monitor is plugged into an old surge protector or buzz strip, which may
    mean that the monitor is being supplied with insufficient or ‘dirty’
    (uneven) power. Is there a power light on the surge protector, and if
    so, is it flickering? If so, try plugging the monitor directly into the
    wall, or into a brand new power strip.
  • micromaster
    have you got my post..?
  • micromaster
    let us know which one of this solution have tried..
    Thank you..
My sony bravia LCD 40 inch is appearing 2 straight lines on the screen and they are perpendicular to each other. These are now permanent lines and they are disturbing when watching tv, what could be t
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 16, 2014 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
I have had a Hitachi 42" Plasma screen TV for almost 3 years and recently it has had problems. When you turn it on, the TV only stays on for about 10 minutes, and then the screen goes black with the...
The signal from the STU to the Hitachi box is going in the wrong direction.
Is the adaptor that you have switchable? If so, flick the switch in the
other direction and this will fix it. If the adaptor is not switchable get
one that is. Then set the STU output to RGB.
Hope this Helps. -CA
Jul 14, 2008 | Televison & Video
On my Sony Bravia KLV-S40A TV I have a message "VIDEO 1". How do I get it off the screen?
On the original SONY remote press display to remove that---if left on long enough it will actually burn that image into the screen--button on almost any Sony Tv remote will remove or clear it.
Oct 25, 2012 | Sony BRAVIA KLV-S40A10 40 in. HD-Ready LCD...
Television screen is green
Is the picture in a green shade or the whole screen is simply green?
if the second one is currect - the connection to the video source is lost. some tv do a blue or a green screen in order to prevent that anoying sound that the old tv used to make.
try to reconnet your source (PC or a DVD player, whatever you can).
if it works on other devices - your device is probably damaged.
Jun 10, 2012 | Sony KP-53HS30 53" Rear Projection...
Hello, My Hitachi 42" plasma is about 5 years
A description of the fault may help with an answer.
Sep 18, 2017 | Hitachi 42PD7200 42 in. HD-Ready Plasma...
My Trinitron's mostly fine, though it's a few years old, but it has a strange display issue. It's almost as though the picture is "zoomed in" about 8%, cutting off about 1 to 1 1/2 inches of...
This problems u are having it is not the causes by the tv,because ur tv it is a analoge CRT tv,don't have this functions zooming in or out or the problems just causes only 8% cutting off edges of the tv pictures only.If the problem it is happening to ur analoge tv it will have no vertical hold at all.The devices u are connected to the tv and using have zoomming in or out buttons or ajustment buttons of the sizes of the picture on the screen.Used the devices remotes controls to readjust ur zooming or pictures sizes adjutment.
May 04, 2011 | Sony FD Trinitron WEGA KV-34XBR800 34" TV
My Sony LCD HDTV, 60", about 6 years old, times out after about 35 - 40 seconds and I lose video and audio while the power light blinds. After about 35 - 40 seconds I get video back and a few seconds...
Try this...... Remove the front panel to access the bulb. There are 2 screws on either side of the tv right behind the screen. You may be able to remove them with just your hands. It will make sense when you see them. Once they are loose the panel will pop off. There are 2 magnets that help hold it on, so just pull gently. In the middle you'll see a another scew that you need to loosen. Slide the bar off, remove the cover and you'll see the black box that holds your bulb. There is an allen screw on the left side that will need to be loosened. Once that is loose, the whole unit slides out. Is the top of the vent screen really dirty? If it is, flip it over and try dusting it off with a soft brush, maybe a tooth brush. Try to keep most of the dust out of the bulb itself though, just be gentle. Pop it back in with the reverse order.......
Jan 23, 2010 | Sony KDF-E60A20 60 in. LCD HDTV
I have a 3 yr old Panasonic 42" Plasma
it might be coming from the actual audio/video source. try hooking up a dvd player or gaming system and see if it still does it.
Jul 11, 2009 | Panasonic TH-42PWD7UY 42 in. EDTV-Ready...
61 Inch Sony Plasma KE-MR61 needs to be repaired
Ke series makes that an early plasma TV
that old will probably be throw away or requires the replacement of the whole printed circuit of the TV
or power source
if chinese built that circuity may no longer be available
any local mobile TV repairer can check that TV out for you
check out the internet for sony corporation south africa
for parts availability
Mar 30, 2017 | Sony WEGA KDE-61XBR950 61 in. Plasma HDTV
Computers & Internet Logo
David Payne
David Payne
