Question about Vacuums
I have Electrolux canister vac. The suction end pops open everytime it loads up.
Http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=689886
Generic problem for all Vacuums
Posted by wmcox on Jun 20, 2008
I have Electrolux canister vac. The suction end pops open every time it loads up.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. In the door there are vacuum lines that could be pinched or bent and are not letting air through to the bag, the system is designed that if the bag get to full or the air flow is restricted it will pop the door open and save the motor from burn out. This is repairable and nor to expensive and to check with the local vacuum cleaner dealer in your area or to call the Electrolux cust serv @ the factory for further information. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://electrolux.com/ Customer Service 1-800-896-9756
Electrolux Home Care Products – North America
P.O. Box 3900 Peoria, IL 61612
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 25, 2008
How do I get reverse suction with the electrolux epic 6000?
I have no idea just what reverse suction would be or how to get it from ANY vac. If you're looking at getting the blowing air from the vac instead of suction, then simply move the hose from the suction end to the exhaust end.
May 25, 2014 | Electrolux Vacuums
My Electrolux canister vac has no suction
You have a blockage somewhere in the unit from pickup to end of line where dirt is stored, only a blockage will cause this.
Dec 14, 2012 | Electrolux Vacuums
We have suction at the outlets but when we plug the hose in we have no suction at the carpet vaccuum head.
Is there suction at the end of the hose? If not, the hose is clogged. Generally the blockage is located near the handle, but sometimes at the other end. Occasionally, if something long, like a straw, is sucked up, it will get caught somewhere else in the hose that's impossible to get to.
You can try to hold the wand end of the hose directly to the CV tank and turning it on. This should clear the clog. If not, hold the handle end to the blower of a shop vac or canister and turn it on. The other end should be either in a large plastic bag, inserted in the in port of the vacuum, or directed outside.
If there is suction at the end of the hose, the most likely place for a clog is at the elbow on the power nozzle or just behind the brush. This can be cleared by using the handle of a wooden spoon or similar blunt object to push the clog back out toward the brush.
If none of these help, take the vacuum to the nearest Aerus Electrolux store for assistance.
http://www.aerushome.com/storelocator/
Jan 16, 2011 | Electrolux Central Vacuum
My Electrolux guardian C135 vac has lost suction. replacing the bag does nothing. removing the HEPA filter has no effect - what do you suggest? Will a replacement HEPA filter make any significant...
No you have a clog in the hose, wand or at the power head. Remove the hose wand and power head from the the vacuum. Turn on the vacuum, put the palm of your hand over the hole in front, you should feel plunty of suction. Then replace just the hose and put the palm of your hand over the end of the hose. If you do not have suction the clog is in the hose. You can try putting the hose on the blower port to blow out the clog or use the wire from a coat hanger. If you have suction, then add just the wand and repeat. If you have suction, then the clog is in the neck of power head, you will have to use a coat hanger to clear it.
May 08, 2010 | Electrolux Guardian Bagged Canister Vacuum
Electrolux 2100 vac dies when you attach hose even with new bag.
If the bag full light keeps coming on, you can first try adjusting the dial on top of the vacuum cleaner. If that does not work, then you need to change the control valve. This is an internal component of the canister and is directly below the dial. You will need to follow the instructions on a previous post to open the Electrolux plastic canister vacuum, and remove the bage cage. Once you remove the bage cage you can change the control valve, and this will solve your problem with the bag full indicator.
Mar 31, 2010 | Electrolux UltraLux 2000 Bagged Canister...
Electrolux model 2100 shuts off with slightest suction blockage
This is exactly the symptom you would expect from a defective bag control valve. The actual control valve sits under the dial on top of the vac and often cracks internally. It can be replaced in about 15 minutes by a good tech with genuine parts from AERUS Elctrolux dealer or repair center.
You can open the vac front to rear like a **** shell by sliding the bumpers out the front with the bag door open, however you must be careful not to disturb the wiring harness and to mark wiring locations. The body must be carefully realigned for closure. If it is not perfect you will not be able to slide the bumpers back in.
Dec 16, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Have an electrolux 2100 canister vac, it has lost suction power thru the years. no clogs in newer hose or in sweeper. even with new bag, filter and belt only increases power minimally.
Have you ever over the years replaced your brushroll ? Have you tried dropping a coin thru the hose from one end to see if it comes out the other end ? Have you taken the wand loose from the elbow ( the swivel part of your carpet sweeper) to see if there was a blockage ? Does the motor make a strange noise ? Have you ever had a tune-up on your vac.
You might think about taking your vac to your Aerus/Electrolux shop.
Joe
Nov 19, 2009 | Electrolux Vacuums
How to open legacy canister
Take out the bag and keep the door open.
While the bag door is still open, turn the machine upside down so you are looking at the serial number.
Pull the cord out one foot.
Use a puddy knife and put it between the rubber side rails and the **** end of the machine.
Use a hammer or malett to hit the putty knife from the back of the rubber bumber toward the bag door.
Pull the rubber bumber stright out on both sides.
Once both bumpers are out pull the lower body of the canister from the **** end toward the intake of the machine.
Once the bottom is open you can then service the motor, cord winder, switch, and all other components.
For all the parts to fix the machine visit: http://evacuumstore.com/c-69-electrolux-accessories.aspx?manufacturerfilterid=0
Dec 10, 2009 | Electrolux Guardian Bagged Canister Vacuum
EL7020A ELECTROLUX VAC SHUTS OFF AFTER 10 MIN
The symptoms you describe are typical of a vac that has a blockage (hence poor suction). It cuts out because it's over-heating. You need to check the hose, the filters and anywhere else where something may have got stuck. Blockages are often caused by things like paper clips, but can be caused by something as apparently harmless as a piece of paper which gets stuck and then debris builds up behind it and causes a log-jam.
Feb 10, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Vacuums Logo
138 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
