Gateway flat panel TV will not turn on, the front on and off switch doesnt work at all and when you use the switch in the back the front on and off switch lights up but tv still will not turn on. Is
Flat screen television will not turn on
    Sergeant:
  • 260 Answers
This sounds like you have lost your power supply. The more expensive the equipment, the more sophisticated the power supply that converts the power from your outlet into your television. There could have been a lightning strike that has disabled the tv. Or it could be a faulty outlet.
Before called for a technician, I recommend plugging the television into a different outlet. use a good quality extension cord if necessary. You may find that your outlet is not polarized correctly. If this does not work, please try our premium service or use our online listing of technician for a professional near you.
thanks and good luck :)
Posted on Jun 20, 2008
Why my gateway srs wow plasma tv that turns off on its own n sometimes doesnt turn back on
Fault with the main power supply regulator board.
Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis.
Aug 05, 2014 | Gateway PLSM50TV 50 in. Plasma Television
Replacing a power switch on a gateway tower
The plastic front of your computer is the Front Panel
http://support.gateway.com/s/PC/R/1009566/1009566nv.shtml
Slip this off to access the Power On Button assembly, which has the Power On switch inside it,
Outside view,
http://support.gateway.com/s/CASES/GERSHWIN/8016200R/8016200Rmv.shtml
Rear View,
http://support.gateway.com/s/CASES/GERSHWIN/8016199R/8016199Rrv.shtml
-> FOLLOW Anti-Static Procedures -> BEFORE reaching inside, your unplugged from power, computer.
If you do not know, post back in a Comment
Now look at the Rear view of the Front Panel again.
The LEFT Side Panel removes.
Looking at the Rear view of the Front Panel; note that the LEFT side of the Front Panel, is towards the Bottom.
See the three TABS sticking up along this edge?
One at the Bottom, one in the Middle, and one at the Top.
Flat plastic TABS formed out of the Front Panel itself.
Another point of view.......
The metal framework you see that the CD/DVD drive/s are in, is the Optical Drive Bay.
Look at the Optical Drive Bay, and towards the Top/FRONT.
See that flat TAB sticking in from the Front Panel?
Now come down to the Middle of the Front Panel.
See how out at the bottom of the Optical Drive Bay, there is a TAB sticking in from the Front Panel?
See the TAB at the Bottom?
They hook on the metal framework of the computer case.
They go through SLOTS in the metal framework.
The Tabs are pressed to the Inside of the computer case, OR to the outside of the computer case.
This action brings a hooked end on the end of the TAB, to the Middle of the slotted hole it\'s in, and then the Tab is free.
Suggest start with the Bottom TAB, press on it when hooked end is free of slot; then do the same for the Middle TAB.
Now perform this on the Top TAB.
The TABS are pressed to the inside, or to the outside, and pressure is put against them towards the Front Panel.
Push on the Tabs, to push the Front Panel away from the computer case.
Once all three TABS are free, the Front Panel will swing out, and remove.
Power On switch is mounted to this metal case,
http://support.gateway.com/s/CASES/GERSHWIN/8016038R/8016038Rmv.shtml
Me?
I would open that case, and take the Power On switch itself, out.
Then see if I could find a replacement, or one that I could live with,
http://www.ebay.com/sch/i.html?_nkw=atx+power+switch
Direct link to Hardware Reference Guide,
http://support.gateway.com/s/Manuals/Desktops/8512041.pdf
Let\'s see if it works.
If not here is the Gateway Support page for it.
http://support.gateway.com/s/PC/R/1009566/1009566ul.shtml
8512041 - Gateway Hardware Reference Guide (5-Bay uATX Case)
Go to Pages 37, and 38. (Top of Adobe Reader in page number box)
For additional questions please post in a Comment.
Regards,
joecoolvette
Apr 19, 2013 | Gateway GM5472 PC Desktop
Sanyo dp50747
sounds like a mainboard problem
Jan 31, 2013 | Sanyo DP50747 50 in. Plasma TV
Hi ive got a teco 32 LCD television it doesnt seem to be responding to the remote and also the buttons on the the tv.on the screen it keeps saying 'Switching to DTV' and wont go off that.we have tried...
One of the things I'd try ( I can't say for sure if you can or not because you didn't provide a model number) is to disconnect the front panel buttons.
You can only do this if it leaves the infra-red still connected.
Turn the unit on with the remote.
This will eliminate a stuck front button as the cause.
If the infra-red transistor is part of the front panel board, you cannot use this method to eliminate the front panel as the possible cause.
Mar 12, 2011 | Televison & Video
The front glass broke.. where can i get another?
Every screen I've ever sween for sale is more expensive than a new tv itself. I'd try ebay or google and see if you can find one that doesnt work.
Thanks,
Michael
Feb 06, 2011 | Gateway GTW-P42M102 Television
Main board green light blinking at 5 flashing intervals
researched your problem a little, it sounds like a burnt out board. It doesn't look too good for parts either. google your symptoms and you will see a few hits on your exact issue
Jan 29, 2010 | Gateway GTW-P42M303 42 in. Plasma...
TV blinked out and now it doesnt come on?
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to jah2mil@hotmail.com if you require further assistance.
Feb 26, 2009 | Akai LCT2715 27 in. LCD Television
RCA F32648
if it is a universal remote control , u need to reprogramer
May 02, 2008 | RCA F32648 32" TV
Televison & Video Logo
70 people viewed this question
Top Televison & Video Experts
