Question about LG 17LX1R 17 in. HD-Ready LCD Television
Samsung LNS4041D will not turn on
The TV just makes clicking sounds when we attempt to
turn it on. Can you please help with a suggestion for a repair.
Thanks
  • 5 more comments
  • Anonymous Feb 01, 2009
    Hi I have the same problem, did you have any luck fixing yours?
    thank you
  • hhurst221 Feb 09, 2009
    Mine quit about 3 days ago, would take about 10 minutes to turn itself on after clicking on and off. Sister in law had the same problem last month (she got her's when we did) she paid $ 500 for repair.  We called samsung and they gave us a local repair shop and said we could pay for repair and then send them diagnostics to see if they would refund. But I might just forget it and not have a TV. Anyone else had this problem?
  • archov Feb 19, 2009
    Hi shandra 101 I have the same problem, have you had any luck fixing yours?
    thanx
    Same problem, any luck anybody?
    thankx
  • spudster1313 Apr 20, 2009
    same problem 42" less than 2 years old
    same problem 42" LCD same model would take ten minutes to come on now it won't come on at all just does the double click & four light flashes continuously every ten seconds or so
  • mrpopcorn May 11, 2010
    Just to clarify - do the resistors HAVE to appear bulging or leaky for this to be the fix for this issue? I have the same problem but when I look at my motherboard cm812,cm811,cm817, and cm806 all look fine. They are the original 1000uF 10V resistors but they appear to be ship shape. I have sound but no video. TV clicks like it's going to start, sometimes I get a flash on the screen like it's trying to light the fire, but then poof no video.
My Samsung LN-S4041d starting clicking and within two days would not turn on. I found an article online concerning the same problem with leaking capaictors. I pulled out the motherboard and my capacitors cm812,cm811,cm817, cm806 were leaking and/or bulged. I went to radio shack and purchased 4 1000uf 35v replacements. It took about 45 minutes to install, which I had never done before, and the TV works perfectly. It cost me $1.59 for each capacitor, $9 for a soldering iron, and $4 for rosin-core solder. Hope this helps your situation.
Posted on Jun 02, 2009
  • kyuss300 Aug 10, 2010
    This is dead on. Thanks a ton, saved me a much $$. I live in Montana and there is no TV repairman closer than 150-200 miles. Thank you
  • 36 Answers
Seems powersupply capacitor is leaking.
try replace cm812,cm811,cm817, cm806. All 1000uF 25V 105c
Posted on Mar 15, 2009
My Samsung LN-S4041d makes a clicking sound when trying to turn it on. No picture just a series of clicks.
Is it the power supply?
thanks, Bill
Posted on Nov 25, 2008
I don't have any experience in soldering, so it took 4 hours and $20 in Radio Shack (including solder iron) for me to fix this issue with help from solution 1 (from http://www.fixya.com/users/sadan007)
Thank you much!!!
Posted on Aug 07, 2010
Okay it looks like there are 2 main power issues with these Samsung units - one is the clicking issue where the capacitors mentioned need to be replaced, the other is a cold solder joint where there is no clicking and the joints need to be re-soldered. Thanks to Madhu http://techreport.com/forums/viewtopic.php?f=37&t=62360&st=0&sk=t&sd=a&start=390#wrap for discovering this. Following his advise I re-soldered the cracked joints AND replaced the capacitors while I was in there.
Posted on Feb 22, 2010
Hi my tv sounds like it start but it wont como on i change the power board but still did the same what could it be thanks
Samsung 52" TV Repair - Won't turn on Clicking Sound ...
? 9:37
https://www.youtube.com/watch?v=2WpSJy_kANs
Apr 13, 2012 - Uploaded by Kathy Burton
It makes a clicking sound several times before it turns on, seems to ... Samsung 52" TV Repair - Won't turn on Clicking Sound ...Maybe it took a little longer than that, but I was happy. ... My TVworks like new. ... Samsung No Start / Clicking Repair - 52" LCD HDTV - Duration: 8:26. by clipdan 169,453 views.
TV Will Not Turn On - Troubleshooting Help for Finding ...
? 2:32
https://www.youtube.com/watch?v=kEDVc-BXf0I
May 1, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV that Will Not Turn On - Troubleshooting Tips for finding symptoms and ... hi my tv flashes red and bluebut wont turn on.
Dec 12, 2015 | Televison & Video
Verticle lines across top of screen
This is a problem with the vertical circuit and because it "repairs" itself, sounds like either a poor solder connection or a failing capacitor. This is a fairly common problem that is easily resolved. If you have repair experience, you can fix this yourself. Please verify the model number and whether or not you plan on attempting the repair and I'll supply additional details.
Thanks,
Dan
Jun 11, 2010 | Daewoo DTQ-25S2FC 25" TV
I can't get the tv to turn on. The power source is working fine and the tv was working in the store when I purchased it. Any suggestions??
Only to contact the store and get it either replaced or fixed. Fiddling with it or attempting to open and repair it voids any warranty
Please rate my help++++Thanks for using Fixya
May 29, 2010 | SVA-USA HD4208 42 in. HD-Ready Plasma...
Sound distortion comes and goes...
First of all, try to have this repaired under warranty. Usually these sets have a 1 year warranty. Second, make a recording of the problem. That will help the servicer to understand the problem.
If you are not successful at the warranty repair, the first thing to look for is a power supply problem or poor connections at the audio amp area. I will attempt to locate more details while you persue the warranty claim.
Please keep us posted.
Thanks,
Dan
Sep 19, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
Stupid tv!
Sounds power supply board is bad in your TV and most probably replacement of all electrolytic capacitors in power supply board will solve the issue.
Take TV to local TV repair shop for repair.
Thanks.
Aug 30, 2009 | Akai LCT3201TD 32 in. LCD Television
Clicking sound in back of tv when you try to turn it on
Sounds like this could be a dry soldering joint in the TV power circuit. This can easily be repaired with a small soldering iron and soldering wire.
Best wishes,
Graemevm
Jun 06, 2009 | Philips 27PT543S 27" TV
Sound went out
Please help ! I moved my Samsung hcn4226w and reconnected. The picture is fine but, no sound now and cannot use all functions on the remote. Any suggestions would be great. Thanks.
Jun 29, 2008 | Samsung HCN4226W 42" Rear Projection...
Tv doesnt turn/swith on
Without a Make or model it's hard to say, but I would have to say it's the IFT which is the High Voltage Transformer.
Jan 17, 2008 | Televison & Video
LG 17LX1R 17 in. HD-Ready LCD Television Logo
3,163 people viewed this question
Computer Repairing
Computer Repairing
