Question about Acer Aspire 3000 Notebook
Cd/Dvd Drive my dvd rom drive won't write to dvd disk i've try to reinstall the driver it helped but i still get's so far then say burning failed i tryed clening the lens but nothing seams to work please could you help me or tell me if my dvd drive is damaged
  • puma26579 Jun 21, 2008
    my dvd drive is a rw drive i have burnded disks before on it but now it will only burn so far then buning faited i try reinstalling driver cleaning the lens could you help me or is my drive damaged
  • Anonymous Jun 23, 2008
    Can I get driver of ( PHILIP) dvd ron for my computer.
    Genius:
  • 2,028 Answers
You need to read on the drive and see exactly what type of drive it is. A DVD-ROM drive is read only and will NOT burn DVD's. The drive needs to read DVD-RW, in order to burn DVD's.
Posted on Jun 20, 2008
DVD RAM change to CD Rom when i inset a disc
Check your computer drivers for that drive. It may be a driver error. It has happened to me before and I fixed it by reinstalling the drivers. It should be a software issue if you can still read CD disks.
May 16, 2012 | Computers & Internet
Dvd drive won't open
http://www.pchelpforum.com/cd-dvd-rom/75829-dvd-drive-wont-open.html
click here and read the many solution, aplly one which will suits according to your problem
thx
Jan 07, 2012 | Dell Inspiron 1501 Laptop
Dell inspiron 2600 disk drive doesn't recognize disk in the drive
if the dvd drive not recognised in windows explorer
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driver or
hope this helps you
Sep 30, 2011 | Dell Inspiron 2600 Notebook
MY , CD/DVD LAPTOP DRIVER DOESN'T WORK. IT CAN
goto run and type "compmgmt.msc"(without quotes) and select disc management if the dvd drive is showing below the hard disks means your dvd drive is working fine only thing you have to do is to right click on the CD-Rom 0 and change drive letter and paths to it
.if the CD ROM option is not seen in disk management then you have to go to the device manager option under computer management and expand cd/dvd -rom drives and you will find your dvd drive model if not that means that your dvd drive has got hardware problem
Aug 06, 2011 | Dell Computers & Internet
I have an ACER Extensa 4220. My OS is Windows 7 Ultimate 64-bit. My problem is: After OS installation the CD/DVD drive is working well--able to read disc in general, able to install softwares or driver via...
Purchase a new (or used) disk-drive that is compatible with your Acer notebook.
Remove the current disk-drive, and set it aside.
Connect this "alternate" disk-drive, and install Windows onto it.
Then, test the CD/DVD drive -- if it still gives problems, then you have a "hardware" problem with the CD/DVD drive, and trying to make any "configuration" changes within Windows will have *NO* effect.
Jun 01, 2011 | Acer 4220-2346 Notebook
Installing Vista on new hard drive- CD/DVD Driver not found
Are you installing from the SONY-supplied "System Restore" CD/DVD disks, or from a "generic" Vista DVD-ROM?
The SONY disks _should_ have the correct drivers for your notebook computer.
Dec 08, 2009 | Sony VAIO VGN-NR220E/S Notebook PC
My aspire DVD drive will not work
I see ..if it reads the cd and dvd-s it is probably good and all you have to do is to reinstall the program that u use to burn disks ..but about the second issue with the sound ..try to reinstall the sound driver ..maybe its corrupt ..also look at the settings in the sound driver to see if it isn't maybe locked on left from balance ..but if you cant figure just reinstall the sound driver too ...
By the way if you was using vista program to burn dvd an cd ...just reinstall the whole machine ..it might just fix all the problems..I suspect that its bug-ed
Aug 02, 2009 | Acer Aspire 5100 Notebook
My cd/dvd driver is not working on my hp notebook
Go to HP's support website, find your laptop, and get the missing driver, or find out what brand your cd/dvd drive is and go to the manufacturers website to get the driver. I hope this helps!
Jul 24, 2009 | HP Pavilion dv9000z Notebook
DVD/CD-ROM drive missing
Problem with missing dvd-drive with Acer 5101 solved.
Problem was that depending on boot, even bios couldn?t detect dvd-drive. I
opened my laptop and found out that there were one small screw that wasn?t
connected to anywhere. I opened the screw that locks dvd-drive in to 2.5? slot. In the back of the
dvd-drive is L- shaped peace of metal. One of it?s screws were already dropped
and 2 that were left were loose. I tightened those screws, but drive back and
got my laptop working fine.
http://www.vapaakoodarit.fi/~puontis/cd-drive.jpg
Please feel free to post this solution to other forums as
well.
Jul 12, 2009 | Acer Aspire 5100 Notebook
DVD Rom Drive Won't Play Some CDs...
Couple of possiblilities. Hardware or software.
You can go here to get the latest drivers for your system , just put in the serial.
http://support.gateway.com/support/drivers/dlcenter.asp
Or here
http://support.gateway.com/support/drivers/ddaStep.asp?platform=10022&model=10651&os=&type=&st=browse
If it is listed correctly in the system , it is probably starting to fail. You can try cleaning the laser lens GENTLY with a cotton swab and alcohol.
Also you can try and flash the firmware of the drive. The format of DVDs change slightly over time sometimes making newer ones unreadable. Here is a site with flash utilitys for your drive.
http://tdb.rpc1.org/#GSA4082N
If you still have issues , you may need to replace the drive. Cheapest one I could find was $179
http://www.notebookparts.com/products/description.php?II=11272
Might be cheaper to go with an external one if you can get one cheap.
Mar 01, 2009 | Gateway MX7118 Notebook
Acer Aspire 3000 Notebook Logo
134 people viewed this question
Brian Sullivan
Brian Sullivan
