Question about Panasonic DMR-ES25 DVD Recorder
Unit failed to read any discs
My unit all of a sudden fails to read any discs. It just makes noises that sounds like something is stuck. Then gives the message that its a proper disc. Its does this with any DVD, CD, or blank DVD.
  • 6 more comments
  • tfarrs Jun 21, 2008
    My unit all of a sudden fails to read any discs. It just makes noises that sounds like something is stuck. Then gives the message that its a proper disc. Its does say no read
  • Anonymous Jul 25, 2008
    Same problem, all of a sudden it doesn't read any discs, and sounds like something is stuck, like a scratch on an old record.
  • Cindy Mericle Aug 06, 2008
    I have exactly the same problem, all of a sudden would not read discs, and makes noise like something is stuck. Does anyone know if this can be fixed, and where to take it? I really like this particular recorder. Thanks, Cindy
  • thinktank9 Aug 29, 2008
    Seems like a common problem. I just tried to use mine and it makes a series of 3 short noises like it wants to spin a disc and then says "No Read". Anyone know if there is a recall or known defect??
  • Anonymous Aug 31, 2008
    Yes, I have had this problem on a DMR-ES25 and the identical problem
    on a DMR-ES15.  I had the DMR-ES15 sent in for repair and they replaced the drive, worked great for another month, then broke with exactly the same problem.  So I have had this problem 3 times with 2 units.  I sent it in again for a repair, fortunately it's still under warranty.  I've been using Sony DVD-R's.  Oh by the way, funny thing -- DVD-RAM writing and reading still works perfectly; it's just DVD-R's that I can't write or read anymore.  More precisely, I sometimes can write onto a blank DVD-R but then if I try to go and record a second program on that DVD-R, it usually fails (and makes crunching noises in so doing).
  • kokaman Sep 20, 2008
    Same problem for me. Unable to read disk, says "no disk". Just makes a ka-chunk sound for about 3 times, then quits. Same for any type of disk. My unit is out of warranty, unfortunately :(. Does anyone know of a good, quick fix for this problem?
  • Anonymous Sep 20, 2008
    ALL of us have similar problems. The best solution... Throw the ****** away! The DVD-R drive is TOTAL ****! Panasonic knows this. It would be a great machine IF it had a better quality disc recorder. These problema are from failed motors, software and mainly failed lazers inside the disc drives. I'm on my fifth unit and have had it with these Panasonic DVD-R recorders. I'm moving on to another manufacturer.
  • Anonymous Sep 28, 2008
    Well, I guess I'm not alone. Mine just bombed on me during a recording this morning, it allowed me to stop the recording, even though it wasn't recording anymore; then it allowed me to eject the DVD. I get that same issue we've all experienced; grinding noises -as if it's spinning once, twice and the 3rd spin sounds heavier and just stops "No Read" error on display.
    Even when there's no DVD in the tray, it still says there's one in there. I tried to find a way to reset the device, but it's no where in their User Guide until I came across this posting.
    I went from a Toshiba to a Panasonic DVD Recorder and this is my 2nd Panasonic as the 1st one died too. I had an extended warranty with the store I bought it from, which only swapped my device out with another for the same price. Not sure if I still have that warranty as I cannot find my documentation.
    I know standard warranties through Manufacturers are 1-yr and that right there is just stupid. If this is a Known problem, it may happen with other consumers with other recordable devices and other manufacturers.
    ANYONE Know a GOOD Manufacturer?????? Not sure I want to go back to Toshiba or Panasonic now. Maybe I should have just paid for the most expensive - SONY brand. Got any suggestions??
My unit all of a sudden fails to read any discs. It just makes noises that sounds like something is stuck. Then gives the message that its a proper disc. Its says no read.
Posted on Jun 21, 2008
I have the same problem. I am shopping for another. DVD recorders are not reliable at all. I'd rather use VHS recorder until I can get a hard-disk recorders.
Posted on May 04, 2010
Frigidaire FRA186MT2 beeping noise
sounds like you have a problem with the temperature probe - system defaults from temp to a time cycle if the probe fails
Nov 28, 2013 | Refrigerators
After moving to a new location the refrigerator makes a noise after being plugged in. It sounds like it's trying to turn something or move something inside and it is stuck or not spinning properly. What...
The compressor is tripping on high head pressure, or is seized. Make sure the fan is free of debri underneath the unit, make sure it is cleaned out. If it still wont start, do not leave it on. Unplug it. It is possible the compressor start capacitor coincidentally failed.
Nov 02, 2013 | Washing Machines
Six disc changer will not play, eject, or load. making eject noise nothing happens.
it sounds like the photo sensor has failed this unit detects disc and loads them if it blows it thinks it has a disc and will try to eject it over and over
time for a new stereo sorry
Jun 25, 2010 | JVC KD-G110 CD Player
When the fan runs it sounds like something is
Replace the fan. Probably bearings in fan are failing.
Nov 15, 2017 | Avanti (BCA5105BG) Beverage Cooler
Makes a noise when turned on. won't accept disc.
From what you describe it sounds like the drive is misaligned or something is indeed stuck in the drive. Contact Sony and see if the unit is still under warranty with this site: https://service1.us.playstation.com/rma.htm?_flowExecutionKey=_c2308ED2C-FEB8-9F46-F2FC-3B0BEF105507_k57A0E825-5B8C-90E2-97B6-B9F7B76FB5CC
Jan 16, 2010 | Sony Playstation 3 (PS3) Console
The dvd player part of this unit doesn't work. When you insert a dvd it makes a sound like a dull beep as the unit appears to try to read the dvd. Then "Read" comes up on the display then there is a...
Hi
Thanks for using FixYa. When a Panasonic is giving "no read" and there are loud "clunking" or "chugging" noises this usually indicates that the lens is dirty or has failed. Other problems may include a failing or failed Digital PCB or some problem with the ribbon cables from the DVD Drive to the Digital PCB (on 2006 models such as the DMR-EZ models there is some problem with the ribbon cables to the DVD Drive on-board controller board.
Please check this picture for ribbon cable connections--
Click on the picture to Zoom In.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Nov 09, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
My nintendo wii game disc suddenly stopped reading all discs
It sounds like the actual laser / dvd-rom unit has failed. This is unfortunately fairly common. Please call Nintendo at : 1-800-255-3700
Aug 31, 2009 | Nintendo Wii Console
My Teac DV-L800 player won't read any pre-recorded movies,the unit makes a whirring noise for a couple of minutes before coming up with read error.However if i put an audio cd in the unit it read this...
The optics are either dirty or are starting to fail. Higher laser power is required to read DVDs. Try opening up the unit and cleaning the lens using a cotton swab and alcohol. If that fails, the unit will need to have new optics.
Dan
Apr 08, 2008 | Televison & Video
SRD4900 Sylvania DVD/VCR Combo
Well first of all, why the hell would you press play when there was nothing in it???
Feb 01, 2008 | Durabrand DUR7 Portable DVD Player
Gear making a grinding noise
Not too good news I'm afraid. It sound like the fuser gear has failed. Generally the fuser unit (hot section or hot rollers in the back) need to be replaced. Usually when the gear has worn or failed the fuser rollers are also worn and need to be replaced. The gear can be replaced seperately but is a very risky operation and usually results in parts in the fuser unit falling appart due to age and wear, so it is best done as a unit. If possible do not run the machine as it can cause damage to gears around the fuser unit. The best option is to find out how much a fuser unit and labour to fit would be at your local service centre.
Jan 29, 2008 | Brother IntelliFAX 4100 Laser Fax
Panasonic DMR-ES25 DVD Recorder Logo
648 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
